Old 04-19-2012, 05:15 AM   #31
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,942
interested...
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is offline   Reply With Quote
Old 04-19-2012, 12:44 PM   #32
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,358
The green seal is fine, but there is a specific brown seal for the paralever. The green seal can be used on the Paralever (backwards), but its use is sometimes a flag that the Tech that put the box together may have built up the gearbox based on it being used for a wet driveshaft. Under that scenario the v notch at the top of the output flange would have been left open. The Paralever is dry, & this notch needs to be filled up.
Here's a photo of my gearbox after the output seal was replaced. Spot the difference.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 04-19-2012, 06:49 PM   #33
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 565
great thread
Great thread Waco !
I look forward to seeing the rest of it.
-Chadley
"It's not a death machine, Mom, it's a LIFE machine" - a motorcyclist
Chadleys1 is offline   Reply With Quote
Old 04-22-2012, 09:38 PM   #34
WacoDirtryder OP
WacoDirtryder's Avatar
Oddometer: 304
I soda blasted the engine and it came out looking good but the trans didn't come that clean does anyone know what I can do to clean it up a little better?
WacoDirtryder is offline   Reply With Quote
Old 04-23-2012, 01:14 AM   #35
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,701
Phosphoric acid seems to clean ok, just needs to be hosed off with water afterwards.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 04-26-2012, 10:10 PM   #36
WacoDirtryder OP
Oddometer: 304
I took the tranny to work tonight and bead blasted it looks great now.
Old 04-27-2012, 07:35 AM   #37
chasbo
chasbo's Avatar
Oddometer: 1,698
Nice job!
You can outdistance that which is running after you,
but not what is running inside of you
chasbo is offline   Reply With Quote
Old 04-28-2012, 04:15 AM   #38
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 565
plastic beads?
My brother gave me his media blaster, and I have not yet bought media for it. Did you use plastic beads ? Anything I should know before buying some media ?
I'll be doing the same type of job as this.
-Chadley
Old 04-28-2012, 08:27 PM   #39
WacoDirtryder OP
Oddometer: 304
Chadley i will find out what kind. I used the blaster at work that soda blaster i bought just didnt cut it.
Old 05-06-2012, 09:37 AM   #40
WacoDirtryder OP
Oddometer: 304
I was able to work on the GS a little this morning since my buddy Mudclod went riding and didnt call me said he found some killer roads though. I got the final drive on and put the pegs also the rear brake pedal with cable on wish i had more time.
Old 05-09-2012, 05:09 AM   #41
WacoDirtryder OP
Oddometer: 304
Well i got the shock on so shes up on one tire but still working on the front.
Old 05-09-2012, 10:32 PM   #42
GypsyWriter
Sarah
GypsyWriter's Avatar
Oddometer: 1,550
Very nice!! The more I see these bikes the more I like them!! This one is promising to be a beauty, looking forward to the final finish!
2012 R1200GS Rallye - Gypsy
2003 R1150GSA with DMC sidecar
Ask A Self-Publisher
Originally Posted by FotoTEX View Post
Life is dangerous. Not doing what you love makes life even more dangerous...
GypsyWriter is online now   Reply With Quote
Old 05-09-2012, 11:12 PM   #43
Dakar83
Dakar83's Avatar
Oddometer: 203
Looking great!,
That powder coating is magic. But how do you keep the soda out of your engine and gear box when blasting? That stuff gets everywhere!
Dakar83 is offline   Reply With Quote
Old 05-11-2012, 08:32 PM   #44
WacoDirtryder OP
Oddometer: 304
I just taped everything up you dont really blast around the carb or exhaust hole anyway and after your thru just take and blow the soda off the motor.But for the real tarnished areas the soda just dont get the job done you have to bead blast.
Old 05-14-2012, 09:30 PM   #45
WacoDirtryder OP
Oddometer: 304
I got the main wiring harness put back on now i need to find a good painter for all the body work.
Times are GMT -7.   It's 12:28 PM.
