Old 04-11-2012, 12:35 PM   #166
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
Originally Posted by BlueLghtning View Post
So question, if I'm on a multi-day camping trip without access to electricity and need to charge small electronics at night, what battery would work best to start safely in the morning? This would include BT communication headset and maybe a phone or camera. Would try to minimize what I left charging and the draw from any of these devices should be pretty low.
I use powergorilla.. charged during a ride:
one of the advantages is that you can charge directly and safely in the tent.
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 04-11-2012, 08:43 PM   #167
DDT Rider
Oddometer: 473
Thanks for the tip!
On the specs for this item, I just read that "Powergorilla cannot be charged with any mains charger which is less than 16V"
Does a GS/GSA charge this thing adequately?
DDT Rider is offline   Reply With Quote
Old 04-11-2012, 09:39 PM   #168
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,121
BlueLightening... Funny running into you on this thread!
I too was reading up on batteries to replace the Yuasa in the Terra Mostro, not dying, just long in tooth and I want a spare on the shelf for when it goes. I'd already decided on the Antigravity and ordered one, but got hooked on this thread once Joel mentioned he was going to test them. Thanks, Joel for all the work on this. Really outstanding. I seemed to have made a decent choice, imagine that.
Regarding the overnight charging of little electronics -- I used to be much more concerned about that, but after a total of 16 weeks of ipod / intercom / camera battery recharging nightly off the (tiny) DRZ batteries on the Mobius trips, sometimes in temps down into the 30's, I don't worry so much any more. We've got stock aftermarket AGM batteries in those bikes, but they're really small. I've never had a hicough starting the bikes in the morning. The only times we've had to bump start have been when we've left the headlight on during lunch, the heated grips (overnight), or had a dead stator. I can't imagine the Antigravity 12-cell I bought for the Ducati will do worse than those wimpy DRZ batteries.
Thanks DR Rock. It is funny running into you here also. I hadn't kept up on your Mobius trips lately, but after spending last week riding with Northern Traveler (Scott) on the tetS loop, and him bringing up your trips, I started going back to catch up. We picked up my wife another XT225 and myself the Husky after not having DS bikes for about a year and we have certainly missed it.
I have charged several things off my Vstrom battery like the camera, BT, etc and never had trouble either on long over night camping trips, but for some reason, I've been a bit more hesitant on the Husky even though its got a YTX14-BS battery stock and that's actually a fairly good sized battery. I guess I was thinking it was a lot smaller then it really is. Thanks for your feedback and I'm looking forward to catching up with you guys on the Mobius trip again.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 08 WR250R,
Hers: 07 Ninja 650R, 13 CRF250L,
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 04-13-2012, 11:50 AM   #169
ebrabaek
Oddometer: 4,728
As promised.... Surgery is happening.... but I thought that I'd start a diff. thread and post a link here.... rather than clog Joels thread.... R/R....replacement here...
http://www.advrider.com/forums/showt...4#post18448804
Erling
Old 04-13-2012, 01:11 PM   #170
Tirespin
Tirespin's Avatar
Oddometer: 241
Joel, thanks for all the testing, interesting reading. I'm looking forward to more results with the Antigravity.
My main concern is the risk of a full drainage situation. I have had lead/acic motorcycle batteries (and car/boat batteries) drained very low, and with a jumpstart I can ride home, and recharge if needed. I assume the life of the battery is affected, but they're "good enough" for a good while after that, and there was no meltdown or smokeshow.
What is the real world risk with one of these? If I leave the key on and walk away, and need a jumpstart when I get back, will the battery be fried? Will there be a smoke show? Or best yet, a firework show?
Cyborg, can't these batteries be mounted any which way you want? No liquids, so they don't need to be "right side up". If so, the 16 cell battery will fit the KTM if it's mounted on it's side. Antigravity says "4.25″ Long x 3.25″ Wide x 5.25″ Tall", rotate it and you have 5.25 Long x 3.25 Wide x 4.25 Tall, which is smaller than the Yuasa. You may need to extend a cable.
Originally Posted by cyborg View Post
I worry if I got the Antigravity (claims for motors up to 1300cc), it too wouldn't have the power needed for first-crank cold weather starts, and another $220, poof!
Specs below:
OEM battery: Yuasa YTZ14S, 11AH, CCA 230, $200
6.0L x 3.44W x 4.38H, 8.6lbs
Antigravity max Cranking Amps model that will barely fit for Width in my bike.
YTZ10S-12, 12 AH(PbEq), 360 CA, $220
6.0L x 3.5W x 3.75H, 2.5 lbs
from: http://antigravitybatteries.com/?page_id=2267
Skip 2010 KTM 990 Adventure R Fuel and Maint Log
Tirespin is offline   Reply With Quote
Old 04-13-2012, 04:14 PM   #171
JoelWisman OP
JoelWisman's Avatar
Oddometer: 1,392
Thanks for all this testing Joel. I was doing some research on the Shorai batteries when I came across this thread.
My 2009 Husky TE-610 let me down last week on the 2nd day of a 2k mile trip when it failed to start after lunch. I was thinking at first I had a charging issue as I had replaced the stator cover just before the trip and had been in there messing with the wires etc, but now thinking it was just the battery that went bad as its resting voltage is now about 11.5 volts and drops down to 8v under starting load and won't charge up. This is the FI model, so even after jumping it off when it happened, it still wasn't running correctly. Anyway, since I wasn't certain it wasn't just a battery issue at the time and I was still pretty close to home, I decided just to be safe to go back home and grab my wife's BMW F650GS to continue the trip on. I figured I'd research it more when I got home which I'm doing now.
So now I need a new battery for the Husky and was trying to decide if a LifePo4 battery was really worth the extra money over a sealed AGM battery. The Husky is actually pretty new to me (bought 1 month ago), so not even sure how robust the charging system is and what voltages it puts out when idling or running at like 3-5k rpm's. It also seems to be a pretty high stress starting on a battery or that battery was already on its way out and I just didn't realize it. Most times I had to go into N to start the bike as it really seemed to stress the starter while in gear with the clutch pulled in. Who knows, maybe with a new battery, I won't have any starting issues and it will spin over a whole lot faster.
BlueLghtning, lithium batteries are ideal for engine off charging of accessories for 1 very big reason. All lead acid batteries age at a greatly accelerated rate if kept in any state then full. A lead acid battery that's kept full 24/7 would last 10+ years. Kept at 80%, perhaps 3 years, kept at 50%, maybe a year.
Many other things affect lead acid life so you will not be swing one last 10 years, but you get the idea. Drain a lead acid partially when you get to camp, leave it partially discharged over night, you have just removed a small chunk of its life.
LiFePO4, as with all other lithium chemistry will actually live slightly longer if always kept slightly discharged. 50% is the ideal state of charge for long term storage, where if like other lithium chemestries (which engineers claim it is, but not out long enough to be 100% certain, just 99% certain) it will sit unharmed for decades.
One thing to take into account is PBEQ amp hour versus real amp hour.
Shorai lists it's LFX18 as having 18 p hour PBEQ, but that is total bull shit. Read Shorais FAQ or measure with fancy equipment and you wil find the LFX18 only has 6 amp hour. Accessories use REAL amp hours, as does everything on the bike.
Shorai has a BS explination for this, and there is a grain of truth to lithium performing better regarding amp hour, but only a grain. Shorai multiplies there real amp hour by 3 to come up with their specs which for real world use is totally bogus.
Antigravity does this too, but to a lesser extent. In antigravitys case, they rate their YTX12-16 15 amp hour PBEQ, but in reality it is 9.2 amp hour.
NOW why PBEQ might be a useful term if Shorai wasn't rapeing people with it, is there is some difference to how lead acid performs versus LiFePO4.
A high quality Deka or Odyssey lead acid battery will not start your bike once it has less then 30% capacity left. It would continue to charge your phone for its full rated amp hour, but you can't run it below 30% and have it still deliver enough current at a high enough voltage to actually start your bike.
The Antigravity battery will start my Capo with only 5% of its charge left.
The Antigravity YTX12-16 has 9.2 real AH. It will start my 50 c engine with just 0.47 AH remaining. Though it's cutting it close, I have 8.3 amp hour I can use for charging accessories / tuning lights with the engine off.
The Deka ETX14 needs 30% capacity left to reliably start my bike. It has 12 real amp hour, but only 8.4 are usable while still being able to start my bike.
Antigravity rates the YTX12-16 15 amp hour PBEQ. Against a cheaper battery or at a higher discharge rate, I could see this being accurate. There is no Chinese lead acid battery that that I have ever seen that would make Shorais 3x factor for PBEQ realistic, and that is one of many reasons I am pissey at them.
For charging accessories I would pick a bigger LiFePO4 battery then any of the manufactures reccomend. For doing this with the TE, at least a 12 cell Antigravity, but ideally a 16. And if money is no object, Antigravity makes a 20 cell that will fit in a YTX 14 case, and shortly a 24 cell which I really want :)
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 04-13-2012, 04:39 PM   #172
BlueLghtning
Oddometer: 5,121
Thanks, that makes perfect sense about dragging down the life of a lead-acid battery with charging stuff off of it at night and why the LiFePO4 would do better at that.
In the end though, I couldn't convince my wife that a $200+ LiFePo4 like the Antigravity was worth the extra $130 over a sealed AGM So I decided to at least get the MotoBatt MBTX12U due to how it performed in the the "Texas Toast Battery Cook-Off" - Thread 1 & "Texas Toast Battery Cook-Off" - Thread 2. For the AGM's they tested, the MotoBatt far succeeded most of the others, so that made me feel good about ordering it. It came in today and I hooked it up and everything. Never tried one before, so we'll see. My cheapo meter says its charging at 14.2-14.3 at idle, so hopefully the Husky has a decent charging system on it.
Funny thing is the Scorpion battery which she has in her F650GS didn't do as hot on those tests. Maybe when that thing pukes on her, she'll be more inclined to get a LiFePO4 battery herself. That's been another bike that has been tough on batteries.
Regardless, I'll follow this thread and see what other things you turn up, especially on how the AntiGravity battery works for you. Might have to try to put one of those in the Vstrom when its battery dies.
Old 04-13-2012, 10:58 PM   #173
WayneC1
Oddometer: 2,477
Joel, good testing, you take my pedantic title hands down, It was needed to see how they stacked up in the real world
Like you I thought the PR claims were pushing the limit too far in the push to get to market with these new battery types,
The owner of AntiGravity impressed me though with at times brutal honesty
Re regulators, it is not just the F8's running these regulators, they are fitted to most of the F&G 650 singles as well, part No's below
(only the X's with smaller alternator are different)
Twins
F650GS - 61312346550 voltage regulator AGM Battery
F800S - 61312346550 voltage regulator AGM Battery
F800ST - 61312346550 voltage regulator AGM Battery
F800GS - 61312346550 voltage regulator AGM Battery
Singles
F650CS - 61312346550 voltage regulator
F650CS/M - 61312346550 voltage regulator
F650GS/M - 61312346550 voltage regulator
G650GS - 61312346550 voltage regulator
XChal - 61317707943 voltage regulator
XMoto - 61317707943 voltage regulator
XCoun - 61317707943 voltage regulator
I encountered problems with the VReg on the 650GS single quite a few years back & looked into the problems & found they suffered thermal drift up to 15.5v & then at a point dropped out & fed what looked like raw alternator output which I concluded was thermal overload protection. I solved the problem by relocating the VR from under the motor to beside the cylinder as per the 650X models.
I can confirm in operation the regulated output is 13.8 to 14.2 v, good to see the chance that later VR's are possibly being changed
A contact with SvceMgr background as per yours & I discussed it at the time & combining our knowledge we concluded the machine was intended to be fitted with a gel battery & the regulator was spec'd to that but they were then fitted with the wet cell in production. He also recalled a TSB on regulator testing which specified a stationary test at engine operating temp & any regulator which went over 14.2v was deemed faulty. I have not been able to track down & sight the TSB to confirm his memory but have immense respect for his knowledge & ability as many others do over here.
It is worth noting US owners in particular seem to be getting low battery life on the singles & that includes those fitting AGM. Wet cells require more regular checking than normal with the inner cells requiring top up more than the 2 outer cells indicating possible overheating
Re replacement regulator's, like you I dreamed of a suitable series pass VR but did not track one down, The shindengen
FH019 in the link below seemed a suitable unit but am unaware of any retail sources, Many Japanese bike owners & early F650 owners with the lower alternator output are using the FH012 with good success & the connector kits available are making the swap easy
http://www.shindengen.co.jp/product_...o/catalog.html
In another part of their web site shindengen indicate they are working on series pass regulators, perhaps with your background & ability you may be able to get further information from shindengen
As for me, I picked up a Shorai as they were the first to reach our shores at a realistic price, so far so good but your testing has showed caution will be needed in times of emergency & a check on cell balance is in order.
WayneC1 screwed with this post 04-13-2012 at 11:20 PM
WayneC1 is online now   Reply With Quote
Old 04-13-2012, 11:45 PM   #174
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,196
Yes you can mount them any way you want. Now that's thinking outside and sideways of the box!
Why didn't I think of that?
Oh, yeah, I wasn't looking at the "Antigravity Small Case" versions. I could cram the "480CCA" in there (again, probably derate that claim by 2) but that would still be super-strong, and spendy ($289)!
However, I think I'll still hold off for a bit more torture testing here, and also my Shorai's are starting my bikes solid now that the temps have gone up into the upper 40's and 50's F. No urgent need to blow more bucks on a different brand/type for awhile - just to have the ultimate bestest battery ever.
A agree the Shorai's ratings should be halved, or true capacity doubled in the same case (for cold weather starting) and have said as much to Shorai Tech, but practically speaking my LFX18 still starts the 990 very strong most of the yearly seasons and never had one strand me yet in 14,000 miles or so over the last year, including rough offroad.
Let the games continue!
cyborg is offline   Reply With Quote
Old 04-14-2012, 09:40 AM   #175
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,176
One man'e experience with Ballistic. http://advrider.com/forums/showpost....&postcount=421
It would be interesting to know the cause.
Sparrowhawk is offline   Reply With Quote
Old 04-14-2012, 07:05 PM   #176
WayneC1
Oddometer: 2,477
Yes, would be interesting, these are the failures we are likely to see in electric vehicles as we work out how to build & maintain them
Old 04-14-2012, 09:02 PM   #177
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Originally Posted by WayneC1 View Post
Re replacement regulator's, like you I dreamed of a suitable series pass VR but did not track one down...
Here is one...
http://roadstercycle.com/Roadstercyc...Regulators.htm
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 04-14-2012, 10:15 PM   #178
WayneC1
Oddometer: 2,477
Interesting, they are light on spec though & the manufacturer http://www.cycleelectricinc.com is not much better
One worry is for the CE601 in the install instructions they specify 2 different output voltage ranges for different models
"All “L” model regulators should run between 13.7~14.1 Standard models should run 14.2 to 14.6"
Would be worthwhile asking for more details on spec, would need to do it by phone as there are no email contact points on their web site
Old 04-14-2012, 10:47 PM   #179
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Different model. On the website I posted its the 605 model which isn't on the mfg site.
Old 04-15-2012, 08:00 AM   #180
LukasM
Oddometer: 5,415
The Compufire 55402 is the most popular 3 phase series regulator, lots of people are using them on Aprilias, Triumphs and other bikes with problematic stators.
I think a guy on ADV from Venezuela bought one and was going to install it on his F800GS that kept burning up his rewound stators? Not sure what happened to him.
LukasM screwed with this post 04-15-2012 at 10:55 AM
Times are GMT -7.   It's 03:05 AM.
