Old 09-15-2012, 04:54 AM   #241
Clev
Oddometer: 1
Bonjour a tous!
Hi everyone!
I'm really not a specialist in batteries...
I've read several pages of this thread, but it's hard to find a summary.
In few words, at this moment, what are the best solutions to replace the original battery on a f800gs?
Thnks for your help!
Merci!
Claude
Montreal qc
____________
Clev
F800GS, WR250R
Clev is offline   Reply With Quote
Old 09-18-2012, 08:47 AM   #242
tdcarter
tdcarter's Avatar
Oddometer: 79
Originally Posted by WayneC1 View Post
It would also help knowing what machine it is and the VR type, but it does sound like the BMS is disconnecting the battery and the VR cant keep the output voltage at a stable acceptable value, Oh the joys of development of new systems
Machine is a Honda ST1300. Not your typical adventure bike, but enough adventure for me at the moment. Got some long distance trip coming up. Want to be able to have a few nights camping away from it all, but still have electric to run a cpap so I (and camping neighbors) get a good nights sleep.
Tried 30,000 mfd 25v caps. Not enough of a carrying capacity to keep the V/R on track, as V?R huunted for voltage, caps just adjust and also and went with the flow. Thought of trying to make a constant source by using 11 half size nicd cells, only bring them online when bike engine is actually running.
Otherwise all is beautiful. Plenty of capacity. Left pair of 45w headlights running off battery for 2 hours, still had plenty of juice to fire engine. Next part of build is heater circuit with remote start for cold weather and then a low voltage cut-off. Save battery from pre-mature death and me from needing a jump start and/or trying to push start a beaST.
When they don't make what you want, or sell it at a fair price, build your own.
T
tdcarter is offline   Reply With Quote
Old 09-18-2012, 01:51 PM   #243
JRWooden
Oddometer: 4,292
Originally Posted by JoelWisman View Post
... Speaking of un-vetted...... I have modified two F800GS charging systems by inserting resistance between the stator and R/R. I ended up going with 0.09 ohms and saw peak charging power go down to 379 watts, idle charging power was not measurably affected. Stator temperature is the same at idle but down 9C at 4,000 RPM which is better then expected.
One rider is local and the other hales from AZ. Both riders are sworn to silence to maintain warranty i.e. this test is blind to even BMW lol.
Assuming these bikes don't explode in the next 2 months, or have the stators fail, i'll post how I made the changes and others can jump in on the experiment if they decide to....
Joel:
If you're still out there ... did you hear of any explosions or failed stators ...
or did you loose touch with these guys when everything else blew up?
9C is enough to make a big difference in stator life expectancy!
JRWooden screwed with this post 09-18-2012 at 01:58 PM
Old 09-18-2012, 08:52 PM   #244
WayneC1
Oddometer: 2,630
TDCater
The battery needs to remain online / in circuit to provide filtering of spikes from the charging system. Your basic problem is the cut off voltages for the BMS you have built and the stock VR are different & need to be matched. Look at the F800GS stator threads, there is a series pass VR from eastern europe which may be better for you, either way the stock VR is clearly not capable of operating with your setup.
In terms of power for camping though and protecting the starter battery it would be more normal to run a dual battery system with the second battery providing the camping power & either a manual or automatic switch into the charging system for charging during the day as per Campervans etc
WayneC1 screwed with this post 09-20-2012 at 07:12 PM
WayneC1 is offline   Reply With Quote
Old 09-20-2012, 11:53 AM   #245
tdcarter
tdcarter's Avatar
Oddometer: 79
TDCater
Your basic problem is the cut off voltages for the BMS you have bilt and the stock VR are different & need to be matched. Look at the F800GS stator threads, there is a series pass VR from eastern europe which may be better for you
Thanks, will look into the regulator. But changing the cut-off would not be a benefit to the battery. Need to generate some artifical load/charge between the two... I think.
It would be more normal to do that if I was using lead-acid. One deep cycle, one shallow cycle, keep them seperate so that voltage difference won't let one drag down the other. But the beauty of LiFe is that you can have both of those benefits, high CCA, high storage potential and add in high discharge/charge cycle ability. LiFe keeps a very flat discharge till it's almost all gone, and it hurts it very little to cycle it from almost all the way down to back up full. So why not use it that way, plus it's less space then dual's + switching + wiring + etc... Campervans had the space and load capacity to carry dual batteries, not so much on the bike.
New solution to an old problem, but there is more then one problem to solve it appears.
Old 09-20-2012, 07:24 PM   #246
WayneC1
Oddometer: 2,630
Generating an artificial load is not the answer, matching the VR cutoff to the BMS and having the battery in float is the answer, a series pass VR would potentially give a smoother output
As for the battery isolation between camping load & starting load the principles remain the same whether you use LifePO or lead acid. The LifePO simply reduces the size & weight & improves he viability of set up as the RTW guys have found
Old 09-24-2012, 04:48 PM   #247
Sydney Andy
Oddometer: 47
Yes, but measure or have someone else measure how much parasitic current the XT600 draws key off, crunch the numbers to tell how long the battery will support this before needing charged. The 12 will start the XT600 even when it is almost dead, but going to zero% charged will harm or destroy the battery. .
.....thanks mate, been away on holiday and am just getting back to this now. The 16 sounds like the peace of mind i am after....!!
Sydney Andy is offline   Reply With Quote
Old 12-17-2012, 03:59 PM   #248
mookymoo
Mookish Mook
Oddometer: 4,396
What impact does A123 going t*ts-up have on our choices?
mookymoo is offline   Reply With Quote
Old 12-17-2012, 04:02 PM   #249
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,239
Shorai and EarthX both use Asian manufactured prismatic flatpack cells. The ones using circular cells are likely the ones that will be impacted most.
I will be testing an EarthX 18AH battery soon in my 990, that has built-in BMS and fits the KTM 990 OEM battery location with no foam shims needed (the "C" body).
cyborg is offline   Reply With Quote
Old 12-17-2012, 05:57 PM   #250
battman
Oddometer: 10
Ahh the misinformed, igno is bliss i guess
shorai uses the flat cells, yes, and overstates the capacity and cranking amps by 40%
EarthX uses A123 cells
and, they do NOT use a BMS
battman is offline   Reply With Quote
Old 12-17-2012, 07:07 PM   #251
_cy_
Oddometer: 6,380
has anyone heard from Joel? really miss his input as he's one of the sharpest tech's on Adv.
some false information posted above ... Earth-X has an internal BMS. Shorai like most lithium battery mfg uses lead acid equivalent ratings. main problem I've found is mfg tend to size their batteries for summer use, not winter.
in the middle of doing regenerative discharge tests to measure actual amp hour capacity for Shorai, Earth-X and GPS LiFePO4 batteries.
here's the link http://www.advrider.com/forums/showt...757934&page=19
for most folks... my recommendations is stick with AGM... unless one is willing to spend the extra $$$ and brain cycle learning cold starting procedures. it's not unusual to save 5-10lbs ...compared to carbon fiber piece, going with LiFePO4 is some of the most cost effective way to drop lbs.
your winter heated gear uses real amps ... short rides can drain off amps with heated gear without allowing time to charge battery backup. resulting in not enough reserve amp capacity to start bike next morning.
_cy_ screwed with this post 12-17-2012 at 07:19 PM
_cy_ is online now   Reply With Quote
Old 12-17-2012, 07:24 PM   #252
cyborg
cyborg's Avatar
Oddometer: 5,239
True about Shorai. On EarthX where do you get your info?
read here:
http://earthxmotorsports.com/our-batteries/
The Sales Manager of EarthX (_cy_ knows who) told me they were prismatic too, but I can't find that in writing. She also told me the EarthX meets the true stated ampacity and I will be testing my hard to start KTM990 below freezing with their 18AH "C" shell. My 18aH Shorai will not start first time below freezing. EarthX claims theirs will. Testing soon.
Old 12-17-2012, 08:11 PM   #253
_cy_
Oddometer: 6,380
read here:
results of regenerative discharge tests (amp hour) for Shorai says otherwise. following link above to check out results of tests, which are slowly coming together. each test cycle takes 3-4 hours depending on which battery. so quite time consuming...
are you referring to Joel's discharge tests using an undersized shoria LiFePO4 battery against properly sized lead acid batteries? and no it's not Joel's fault for using undersized Shorai battery, as that's what size was recommended. my recommendation is to use a LiFePO4 battery 75% less original PB amp hour rating.
discharge tests on Earth-X coming up soon... will post results in LiFePO4 testing thread ... link in sig
_cy_ screwed with this post 12-17-2012 at 08:24 PM
Old 12-17-2012, 08:24 PM   #254
JRWooden
Oddometer: 4,292
Originally Posted by _cy_ View Post
.. has anyone heard from Joel? really miss his input as he's one of the sharpest tech's on Adv...
Joel is indeed the man, but no longer works at a BMW dealership.
My guess is his new job keeps him from being as active here on the forum
Old 12-17-2012, 10:16 PM   #255
cyborg
cyborg's Avatar
Oddometer: 5,239
I'm going strictly by what is the largest battery that will fit in my KTM 990, in the Shorai case it's the LXF 18A-BS12, and then will it start my bike first crank at and below freezing like Lead/Acid would. Answer: Gen 1, Nope. Gen 2, Nope. Always needs the "warm it up with current draw" rigamarole to get it going. A hassle and hard on the starter and electrical system with sagging voltage. I was an early adopter of the Shorai and Shorai has treated me well, I have no complaints with them as a company and Dave Radford has been great. The problem is their battery still won't do the job for me and I don't want to have to use an external balancing charger to top it off. That defeats the "drop in replacement" idea.
EarthX says they are not overrating their batteries and when I recently asked for the largest AmpHour battery they had in the case that fits my bike, in this case the EXT36C (because I am skeptical of the Li batt ratings), they said why spend the money because their batteries are NOT overrated, and for me to try the recommended size EXT18C. They said if I was unhappy in any way they will upsize me with no hassles.
Interesting note: The Shorai LXF 18A-BS12 weighs 1060gr/2.34lb and the EarthX EXT18C weighs 950gr/2.09lb with BMS inside! How they can get more power with even less weight than the Shorai is a mystery to me.
Regardless of test benches, the acid test (pardon the pun) will be when the bike gets some good cold-soak all day outside in sub-freezing weather while at work, then trying a start. If the EarthX does it, I'll be a happy rider since I'm an all weather, year round motorcycle commuter. Temps are in the upper 30's now in my garage and the bike jumps to life first crank with the EarthX and does not start right off with the fairly new Shorai (the 3rd Shorai in the bike). I'm waiting for it to get colder to really test the EarthX.
Times are GMT -7.   It's 05:04 AM.
