Old 10-23-2012, 06:57 PM   #16
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,452
Tip for removing grips.
I start at the thumb end and using bull nose plyers pull and maintain tension while cutting with a blade and you can avoid making any contact with the heated grip wires and film.
I also love ProGrip superbike grips ( they are gummy soft , have great cushion and wear like iron)
I do not glue the grips on. I use safety wire in 3 spots and that works just great on both grips.
Now it is easier to change grips or do repairs in the future.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 12-30-2012, 10:59 AM   #17
SlowRide13
Veteran n00b
SlowRide13's Avatar
Oddometer: 1,336
Thank you leadingedge!
Originally Posted by MBronskill View Post
The lesson: Don't trust those two solder joints even if they look good. Somehow the original soldering job was inadequate and even if the wires are firmly attached, the solder joint may not be conducting properly.
Yep, mine looked fine, but no worky. Added gorilla-globs of solder, and now *toasty hands*
Many thanks, leadingedge! If I was a better man I'd send you $50
Pete
F800GS Grin Machine
KTM690E Grrr Machine
XR600R Oakey Mtn in the mud http://www.youtube.com/watch?v=bzoU2NpkaoA
www.hoofrehab.com
SlowRide13 is offline   Reply With Quote
Old 12-30-2012, 11:16 AM   #18
leadingedge OP
Trailing along...
leadingedge's Avatar
Oddometer: 33
Pete
LMFAO! It's the thought that counts.
leadingedge is offline   Reply With Quote
Old 12-30-2012, 03:07 PM   #19
JRWooden
Oddometer: 4,292
I have a dead one in the garage I need to try this on.....
"re-wetting" solder joints (heating the joint hot enough to melt & reflow the solder)
that look good is an old trick that has saved my butt more than a few times....
Old 12-30-2012, 04:29 PM   #20
SlowRide13
Veteran n00b
SlowRide13's Avatar
Oddometer: 1,336
Originally Posted by JRWooden View Post
...that look good...
Hmmmm. So I reckon it's obvious this was my first time?
F800GS Grin Machine
www.hoofrehab.com
Old 02-08-2013, 04:37 PM   #21
rockinrog
rockinrog's Avatar
Oddometer: 2,920
Thanks for the write up.
As usual I have trouble with the simple steps.
My question is how do you remove the plugs without bitching them up?
I put some pressure trying to just pull, but felt like I was about to snap them.
EDIT: The plugs are fastened onto the grip... you just pop them off and then you can see the release which is on the back of the plugs.
rockinrog screwed with this post 02-08-2013 at 05:36 PM
rockinrog is online now   Reply With Quote
Old 02-24-2013, 03:43 PM   #22
Kaw4Life
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,745
Mine quit a long time ago but I was not willing to pay the money for the replacement. Thanks for the write up I will get on this and let you know what I find.
Kaw4Life is offline   Reply With Quote
Old 03-23-2013, 04:16 PM   #23
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 492
Keep us posted and pics never hurt
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 04-15-2013, 07:49 AM   #24
abhalz
Oddometer: 1
heated grip
Is there any possibilities to repair the heater strip as i accidentally cut it while changing the grip on the throttle side...
abhalz is offline   Reply With Quote
Old 04-16-2013, 12:40 PM   #25
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
I resoldered the connections, and then tested with a multimeter... Current is definitely flowing through the grip, but it still isn't getting hot! The right side heats like a champ... I'm confused now. Any suggestions?
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 04-16-2013, 02:00 PM   #26
DasMatti
DasMatti's Avatar
Oddometer: 264
Did you measure how much Ohms your grip has?
The foil is just another form of a heating-wire. So you need a certain resistance (I think 8.2 Ohm) to get it up to temperature.
cheers,
Matti
DasMatti is offline   Reply With Quote
Old 04-28-2013, 12:01 PM   #27
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
Hey guys,
I had the same issue so I decided to follow that step by step repair process. Guess what? It works again... Thx a lot for this awesome help. I'm keeping 250$ in my pocket
I would say that the hardest part was to roll out the grip to access the wires. For the rest, it was a piece of cake
BMW F800 GS 2009
Ckeck out my ride reports
Air0ne is offline   Reply With Quote
Old 04-28-2013, 01:56 PM   #28
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 390
new grips
Worked for me. My left grip was intermittent. it looked ok. But I resoldered both joints and it works fine. I replaced the grips with aftermarket ones. nice soft dirtbike ones. I purchased 2 sets and used both RH grips. Used hair spray to glue them on. Super glue at the ends to seal. Then a little silicon to make sure no water gets onto the grip.
I was a bit worried at first that the new ones were a bit thick. But they warmed my hands up fine. Will try them in the cold in a couple of weeks when I head south.
Kiwi Tinkerer is offline   Reply With Quote
Old 04-30-2013, 08:16 AM   #29
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
Hi guys,
It's me again.
After several hours, my left grip went off again so I soldered back the connections... and again, it went off after a couple of hours...
What's happening? any idea? vibration?
The way I fixed it looks similar to the first pic (no monster globs )
BMW F800 GS 2009
Old 05-17-2013, 10:08 AM   #30
Air0ne
Adventure reader
Air0ne's Avatar
Oddometer: 163
Ok guys, I solved my problem...
My connection was cut at the main connection so I had to solder deeper inside the grip to make it work. Now all is fine :)
I can give you pics if someone needs...
BMW F800 GS 2009
Times are GMT -7.   It's 07:56 AM.
