Old 02-09-2013, 06:14 PM   #16
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 986
Considering the repair you did, do you think that you could have otherwise replaced the grip(s) w/o damaging the heater element(s)?
I ask because my grips are showing wear, but the heaters are working fine. I tried Grip Puppies but those were too fat for my dainty digits.
Thanks.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is online now   Reply With Quote
Old 02-09-2013, 06:35 PM   #17
leadingedge OP
Trailing along...
leadingedge's Avatar
Oddometer: 33
I've seen guys use the tube rubber replacement grips from cricket or baseball bats on the grips. Try get some from your local sports store and just roll it onto your grips. Should work fine.
leadingedge is offline   Reply With Quote
Old 02-09-2013, 06:45 PM   #18
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 986
Do you mean over the existing grips or as replacement grips?
Old 02-10-2013, 06:34 AM   #19
leadingedge OP
Trailing along...
Oddometer: 33
Right over the existing grips. The rubber cricket bat replacement grips that I've seen guys use is very thin, so you just roll it right over your existing grips.
Something like what the guy in this video uses:
https://www.youtube.com/watch?v=b6L9...e_gdata_player
This guys' technique will also work great for getting the rubber on the grips. Check out the video.
Old 02-10-2013, 07:29 AM   #20
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 986
I see know. Thanks.
Old 02-10-2013, 08:13 AM   #21
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,535
Easy to just put new grips on...just be careful getting old ones off..you can knick heating elements easily. Score grips along length, peel like a banana...carefully cut nubs off heating elements and end of grip, rubbing alchol in new grip, slide on..About 20 minutes
Some say you need two throttle grips..that's BS...just buy a set and install.
Recent threads here on ADV...
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is online now   Reply With Quote
Old 03-29-2013, 11:14 PM   #22
yann L
Oddometer: 41
A huge, HUGE thanks to Leadingedge for that thread, MERCI! I did the repair earlier today and it work!! Time will tell me if it's good or not but it was working after reassembling the grip. P.S. the 2 solders were looking good but electricity was not going thru, re-did the solders and it work.
Second P.S. we had a party at my house tonight and one of the girls forgot her keys in the car...I wish I could have done something for that, but she called the CAA
Thanks again :)
yann L is offline   Reply With Quote
Old 04-01-2013, 07:30 PM   #23
leadingedge OP
Trailing along...
Oddometer: 33
No problem yann L, glad to help!
Thanks again :)
Old 04-02-2013, 12:32 PM   #24
Mikewest
Mike:)
Mikewest's Avatar
Oddometer: 13
Mine on my HP2 enduro are OEM both dont work, any tips to start looking
THX
Mike
R1200GS 2012
HP2 ENDURO 2006
g450x 2009
Mikewest is offline   Reply With Quote
Old 05-05-2013, 07:50 PM   #25
eap
El Adventurero Solitario
eap's Avatar
Oddometer: 3,269
When your grips failed did you blow a fuse? My grips recently failed after a 3 day wet ride. Keeps blowing he fuse so I'm thinking a short. I inspected the external wires and all appear to be ok. Later I did get heat for awhile on the left side, then turned everything off and on resulting in another blown fuse.
Could the short be under the grip and is 'leadingedge's' repair a likely fix? ...or...?
eap '14 R1200GS-LC Thunder Grey
Chesapeake Bay Watershed, Surf Your Watershed
Support Mammograms
"Over the Mountains Of the Moon, Down the Valley of the Shadow, Ride, boldly ride," -From 'Eldorado', Edgar Allen Poe (1849) http://www.eapoe.org/works/poems/eldrdoa.htm
eap screwed with this post 05-05-2013 at 07:56 PM
eap is offline   Reply With Quote
Old 09-05-2013, 06:10 AM   #26
1150nut
1150nut's Avatar
Oddometer: 27
New grips on 1150gs?
By the way, do you guys know if these "newer" grips will fit in my 2002 r1150gs? Is it possible to use the ones you're talking about here in my bike? Is it worthwhile? Thanks a lot!
1150nut is offline   Reply With Quote
Old 10-18-2014, 10:54 AM   #27
B4RcOdE
Oddometer: 2
Hello all!
If one tries the method posted by leadingedge ... is it adviseable to seal the new rubber grips with glue?
because it feels like leaving them unsealed will allow water and dust to infiltrate into the heating circuit...
B4RcOdE is offline   Reply With Quote
Old 10-19-2014, 04:14 AM   #28
WOLVERINE
Keep her pinned!
WOLVERINE's Avatar
Oddometer: 628
I wouldn't worry about dust and water affecting it, shouldn't be an issue.
I did however bugger my grip trying to expose the wires yesterday, which I attribute to my bad vision, so I stripped the grip off nice and easy cutting along the length like previously stated. Didn't cut all the way through the grip and peeled it back. Note throughout the grip itself there are strips of glue in between the heating element of the grip so be careful when taking the rubber grip off. You have to peel them length ways one at a time nice and slow. Now I have to find a grip to put back on, maybe gel.
Ironic thing is I didn't have the suspected broken loose wiring and the left grip still doesn't work but the right does... I did note the resistance of the grip being 5.1k ohms. Not sure if that's normal?
If you think you're free, there's no chance of escape!
2008 R1200GSA
WOLVERINE is offline   Reply With Quote
Old 10-19-2014, 05:00 AM   #29
B4RcOdE
Oddometer: 2
Hey Wolv
You mentioned "gel"... what do you mean? I can't find any rubber grips anywhere to replace my original ones... just a pair of Italian grips from a company called ARIETE...
do you have any more suggestions?
Old 10-19-2014, 08:02 AM   #30
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,463
One question. Some people say "get two lefts" or "get two rights." I never know which.
It doesn't look like you did that. You got one left and one right.
Can someone clear this up once and for all?
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Times are GMT -7.   It's 09:06 AM.
