Old 03-07-2012, 02:46 PM   #1
EastKy OP
EastKy's Avatar
Oddometer: 64
1150 GSA Gas Tank Question
I have a 2004 GSA . When I open the gas lid it has pressure on it, even if it's been in the garage. Any ideas?
'04 bmw gsa
'92 bmw gspd
other bmw bikes
EastKy is offline   Reply With Quote
Old 03-07-2012, 03:43 PM   #2
maalstroom
Ferret Legger
maalstroom's Avatar
Oddometer: 458
Tank vent issue. Does it have a charcoal cannister still? Make sure your vent hoses are clear.
My gears grind more and more each day.
maalstroom is offline   Reply With Quote
Old 03-07-2012, 04:06 PM   #3
EastKy OP
EastKy's Avatar
Oddometer: 64
Yes. Everything is original
'04 bmw gsa
'92 bmw gspd
other bmw bikes
Old 03-07-2012, 05:41 PM   #4
ricohman
Marinoni man
ricohman's Avatar
Oddometer: 1,981
I've found my tank has a bit of pressure from time to time. And its never caused any issues.
ricohman is offline   Reply With Quote
Old 03-07-2012, 07:09 PM   #5
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,148
You shouldn't have any vacuum. That's why the vent hose is there. One of your lines is blocked. Check them before your tank develops a dent.
Regards,
Mark
2004 KTM 950 Adventure
Black is the new orange
mcstark is offline   Reply With Quote
Old 03-08-2012, 11:19 AM   #6
jclark83
jclark83's Avatar
Oddometer: 393
Pull the vent hoses off the charcoal canister. I bet one of them has a few pieces of charcoal in it. You can clear the vent hoses or remove the canister. I would remove the canister.....
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
jclark83 is online now   Reply With Quote
Old 03-09-2012, 09:25 PM   #7
vintagerider
vintagerider's Avatar
Oddometer: 1,968
refer to dealer; refer to DOT and CA emissions rules
vintagerider screwed with this post 06-24-2012 at 03:48 PM Reason: refer to dealer
vintagerider is offline   Reply With Quote
Old 03-10-2012, 05:21 PM   #8
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,451
de-cannister that thing immediately.
I think we are confused about whether you have pressure or are pulling a vacuum?
Pressure is one thing, but a vacuum will cave your tank in and leave a permanent dent for all eternity.
remove the cannister, cap the throttle bodies, put all that junk in a box for the next owner and ride on smugly with the knowledge that your tank can breathe.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Times are GMT -7.   It's 11:46 AM.
