Old 03-28-2012, 06:21 AM   #16
malloy
Oddometer: 778
Question Links
jaak, rocketman1 - I'm glad you were successful with your swaps. I couldn't find the youtube you both mentioned. Actually looked pretty hard . Can you give us a link?
Much obliged.
F650GS (Build Date 11/11)
malloy is offline   Reply With Quote
Old 03-28-2012, 06:35 AM   #17
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,827
Where to Buy the Part
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 03-28-2012, 09:44 AM   #18
matapo
Oddometer: 122
I was also a bit worried when sending money to Greece but that guy still delivers! [/QUOTE]
Enjoy your brand new greek gaiter. You shouldnt worry about buying things from Greece since you r driving a
german motorcycle....
matapo is offline   Reply With Quote
Old 03-29-2012, 04:08 AM   #19
malloy
Oddometer: 778
Thumb
Mr. Head, Thanks for the links.
Old 01-09-2013, 06:22 AM   #20
Cois
Cois
Cois's Avatar
Oddometer: 10
Thumb
I need to replace my ball joint on a 2010 Adventure. I ordered the complete ball joint from BMW dealer as I am worried that the ball joint may be damaged by dust.
I can't find any info on the R1200GS model for this DIY job. I would like to know if anyone has done this before. Any tips?
My question will be as follow:
1. Are there enough vertical play on the system to replace the joint without having to loosen the lower fork bridge or the front spring?
2. Do you need to loosen the break lines thats connected to the lower fork bridge?
3. Torque specs?
Any photos would be helpful.
Cois is offline   Reply With Quote
Old 01-11-2013, 12:26 PM   #21
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,666
I bought the new rubber boot from the guy in Greece, received it inside a week via registered mail, left the obligatory positive feedback and headed outback to remove the snow and retrieve the BMW 2-wheeler from the shed.
I replaced the torn OEM rubber boot in under 15 minutes on my 05 R1200GS, it takes a 20mm open end wrench and a T45 Torx bit, or in my case a large adjustable wrench and a T45 Torx bit.
The job is excruciatingly straightforward and simple and the ball-joint is so large and over-engineered for this machine that I cannot imagine anyone ponying up unnecessarily for a new BMW unit and going through that extra hell unless absolutely necessary.
There are no tricks or anything, no need to heat up the nut to break loose the thread-lock and no need to re-apply any, there is also no need for a torque wrench, the nut is so large that you simply tighten it down real good, you'll know when it's so tight that it won't fall off but not so tight that you twist the front of the bike off.
Just be sure to remove all the old contaminated grease and replace it gobs of new, and leave the blasted lower metal retainer ring off so the boot can spin a little and not tear again.
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 01-11-2013, 01:54 PM   #22
DaneelOlivaw
Irv Seaver BMW; Parts Mgr
Oddometer: 439
We will be stocking this Greek boot soon. 25 units on order to arrive here from Greece in several days. Contact us by e-mail or phone. Limit one per customer. No warranty. Price $36.34.
DaveTownsend@IrvSeaverBMW.com
714-532-3700
DaneelOlivaw is offline   Reply With Quote
Old 01-31-2013, 01:38 PM   #23
DaneelOlivaw
Oddometer: 439
We now have these boots in stock. Quite nice looking. Should be a proper fit on pretty much all telelever and duolever front BMW ball joints.
$32.98 before [(Calif only) tax] or outbound freight
Order via phone or e-mail:
DaveTownsend@IrvSeaverBMW.com.
USA 50-State addresses only please. No warranties.
714-532-3700
Old 02-26-2013, 01:20 PM   #24
gspdbill
noobie allover again
Oddometer: 404
Was all set to order a new ball joint but found this thread, ordered the (Greek) boot from Irv Seaver's. They still have a few in stock.
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 02-27-2013, 10:35 AM   #25
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,041
Originally Posted by malloy View Post
the gaiter is not available as a separate item - thanks BMW
Go over to the car side of BMW and see if you can get any gaiters for tie rod ends. In fact, why not list another manufacturer that provides these as separate parts.
The ball joint can be damaged in minutes/hours after the boot splits. Posting that it might be OK after "only" a week is wishful thinking ... but lots of that happens when the kludge solution is cheap.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 02-27-2013, 11:38 AM   #26
PaulGinAZ
FNG
PaulGinAZ's Avatar
Oddometer: 259
Received mine from Irv Seaver in two days.. now to install it.
-Paul
- All bikes gone... thanks for the memories!
-2013 Yotota Tacoma TuRD (daily)
-1989 VW Syncro Tristar TDi (long-term project)
-Too many bikes and cars in my sordid past to list...
PaulGinAZ is offline   Reply With Quote
Old 07-05-2014, 03:42 PM   #27
birdie_xx
birdie_xx's Avatar
Oddometer: 840
I noticed the boot torn up yesterday...after about 150 mile ride that felt weird.
Normally very stable and easy to control in low speed '09 GSA felt like low air/bad bearings/bad shocks/ bad tires. In a heavy, stop and go traffic the bike was "wandering" a bit...
When I rode faster the bike felt better.
Today I noticed the boot is torn. Could this be the reason for the weird behavior ?
There are no leaks from the final drive and the rear wheel is solid. The air pressure in tires seems to be right as well...
Could I have damaged the ball joint ? What signs of damage should I look for ?
Wander if the rubber itself is enough or is the whole new joint better option...
BTW, the bike has ~ 45K Miles...
Cheers,
birdie_xx screwed with this post 07-05-2014 at 03:53 PM
birdie_xx is offline   Reply With Quote
Old 07-05-2014, 03:58 PM   #28
diabolik37
Push Dumb C***
diabolik37's Avatar
Oddometer: 922
I got the rubber boot from a Fiat truck dealer, but I got a friend that got his from a CAT dealers (he wanted a yellow one to much the rest of the bike)
I also found that if you leave your bike park with the front wheel straight it last a lot longer...
STOP the Planet! I want to get off!
diabolik37 is offline   Reply With Quote
Old 07-06-2014, 01:06 AM   #29
rattis
rattis's Avatar
Oddometer: 1,260
Thumb Worried
How little trust you have to worry about that measly sum.
Normal people are honest, I sent almost 10000 $ to a man I'd never met before to buy me a motor bike , half across the world.
That man is a prince.
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, thrice up now, two 990 Adv and a 950 SER
rattis is offline   Reply With Quote
Old 07-06-2014, 07:04 AM   #30
birdie_xx
birdie_xx's Avatar
Oddometer: 840
I just saw Wunderlich recommends replacing the ball joint on a GS/GSA if the bike has over 30K miles...
Is it just the sales pitch or is it a good idea ?
Times are GMT -7.   It's 12:15 PM.
