03-11-2012, 09:43 PM
#1 |
Oddometer: 70
2011 Camhead Spark Plug hassles...
Had a little trouble getting my main plugs out for the 6k service. I've got a 14mm "long" socket but it wasn't quite long enough. I was able to do it by not fully inserting the extension into the socket—just enough contact to engage, but not clicked in—and then retrieving the socket from the hole with a magnet-pointer once finished, but I don't love that as a long-term solution. Looks like Craftsman has a thin-walled long 14mm. Anyone have this? Any suggestions?
Also, can't seem to figure out the actual torque spec for the plugs. I have documentation from previous models that says 23nm but JVB lists the torque at 12nm with the tighten-loosen-retighten regimen. Anyone can tell me the definitive spec? |
03-12-2012, 04:42 AM
#2 |
"Cool" Aid!
Oddometer: 41,491
The Camhead doesn't need a thinwall socket. A regular 14mm socket, or sparkplug socket, will work just fine. As for the torque value, it came directly from the factory manual. Unless there has been a change it is accurate.
Jim
03-12-2012, 07:21 AM
#3 |
Oddometer: 70
Thanks, Jim. I'll go with you and the factory:)
04-23-2012, 08:06 AM
#4 |
IBA, BMWMOA
Oddometer: 188
Has anyone identified an alternative to the BMW plugs for a Camhead (2011 GSA)?
Anyone know how much BMW is getting for 4 plugs? What is the replacement interval?
Christopher Ross 2011 R1200GSA - Helga 1974 R90S - Smokey |
04-23-2012, 12:08 PM
#5 | |
Itinerant jackass
24k is the word on the street.
"Never trust a man what's made of metal! BWDR Cat Herders SMIBS BaldEagleBastards bloochdog screwed with this post 04-23-2012 at 12:13 PM |
04-23-2012, 12:25 PM
#6 | |
"Cool" Aid!
Oddometer: 41,491
![]() Jim
04-23-2012, 12:43 PM
#7 |
Oddometer: 284
Sparkplugs.com is selling the NGK plugs for $7.83/each... traditional or iridium
EDIT (4/24): Bad info... Sorry.
Tom AMA - BMW MOA '07 Honda GL1800A Gold Wing '11 BMW R1200GS "TRIPLE BLACK" '12 Ford F250 Lariat SuperCrew 4x4 Diesel ATCguy screwed with this post 04-24-2012 at 10:23 AM |
04-23-2012, 12:45 PM
#8 | |
"Cool" Aid!
Oddometer: 41,491
Jim
04-23-2012, 12:46 PM
#9 | |
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 1,562
![]() I changed mine at 30,000 miles. They were worn, but really not too bad. I figured since I had already paid for the new ones, and had the original ones out........why not.
'10 Husaberg FE570 '10 BMW R1200GSA "30th anniversary edition" '08 KTM 950SE-R '08 Ducati Hypermotard 1100S |
04-23-2012, 06:03 PM
#10 | |
Oddometer: 284
Ouch! You got me, Jim. I just took the info from the FAQ sticky in section 3.3, which has NOT been updated. :(
Tom AMA - BMW MOA '07 Honda GL1800A Gold Wing '11 BMW R1200GS "TRIPLE BLACK" '12 Ford F250 Lariat SuperCrew 4x4 Diesel ATCguy screwed with this post 04-24-2012 at 10:20 AM |
04-24-2012, 10:22 AM
#11 |
Oddometer: 284
Ok, according to the manual... we need the following plug: NGK MAR8B-JDS
A quick check on the web shows there aren't too many places to get them here in the US as yet. Wunderlich wants almost $20/plug... and I can't find any other brand with a cross-reference. So maybe $16 at the dealer isn't so bad right now.
Tom AMA - BMW MOA '07 Honda GL1800A Gold Wing '11 BMW R1200GS "TRIPLE BLACK" '12 Ford F250 Lariat SuperCrew 4x4 Diesel |
04-24-2012, 11:23 AM
#12 | |
Oddometer: 880
![]() I REALLY like my new Yamaha Super Tenere! ![]() Regards, Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen |
04-24-2012, 01:42 PM
#13 | |
"Cool" Aid!
Oddometer: 41,491
![]() Jim
04-24-2012, 07:39 PM
#14 | |
Oddometer: 329
I emailed NGK for a part number and a quote on an Iridium spark plug for the 2010 - 2011 R1200GSA camhead series and here is what I got back:
As soon as I get a response back from DENSO, I'll post it. |
04-24-2012, 08:43 PM
#15 |
Oddometer: 284
WindSailor... take this for what it's worth, but that's the plug listed in the FAQ Sticky for 1200cc engines. However... that is NOT the plug for my 2011 R12GS.
Look in your Owner's Manual, and it should tell you what plug you need. If I remember correctly, mine was listed on page 152.
