Old 03-12-2012, 04:36 PM   #1
frichtie OP
frichtie's Avatar
Oddometer: 182
Center-stand [R80G/S]
O.k, here's what came apart this afternoon. The center-stand. Bike is still in the garage. Won't be using it before 2-3 weeks. A few things need to be maintained or replaced. But this afternoon, when moving the G/S inside the garage, the center-stand broke apart. It's obvious that it was fixed before. Badly. Some people buy and use a welding machine and should spend the money on a professional welder instead.... Be that as it may, my center-stand needs a complete rebuilt. Maybe I'll be making one from scratch. I'm a machinist and....I know a few professional welders!
What do you people think? Does anyone here has "blueprints" for a G/S center-stand?
By frichtie at 2012-03-12
frichtie is offline   Reply With Quote
Old 03-12-2012, 05:30 PM   #2
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,704
heck just weld the part back on, no need to go overboard. Just get good penetration, that's the key...at least what I've been told..(LOL)
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-12-2012, 05:32 PM   #3
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,156
Appears to have been welded on both sides.
Perhaps they thought it was easier to bend up some new pieces and attach than to repair the scraped-through bottoms. ??
Anyway, you've got something right there to copy - why would you need plans?
But the stock stands work well enough, and I'd think it would take a while to fabricate a better one. That's not to say the stock stand is that great, but it might prove difficult to improve on.
Old 03-12-2012, 05:37 PM   #4
One Less Harley
Oddometer: 4,704
If worried about the repair, put an inner sleeve in the tube for more strength.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-12-2012, 06:42 PM   #5
frichtie OP
frichtie's Avatar
Oddometer: 182
An inner sleeve will be used for sure. And I'll keep the upper part. But the stand feels kind of...narrow. I'll probably add studs on each side. As seen here:
Old 03-13-2012, 08:57 AM   #6
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,512
A key element to centerstand lifespan is those plastic plugs on the ends. Lose one and the centerstand fills up with water on wet rides and rusts out from the inside. Don't use it for a while and then deploy it and a bunch of rusty water flows out on the ground. Whatever you make, be sure it's not a water trap.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 03-13-2012, 10:08 AM   #7
petefromberkeley
Oddometer: 3,292
Wine bottle corks work perfectly if you loose that plastic center stand plug. I don't know if I will ever need to take mine out, but if I do, I'll need a corkscrew
Nine mile skid on a ten mile ride. Hot as a pistol but cool inside.
petefromberkeley is offline   Reply With Quote
Old 03-13-2012, 10:33 AM   #8
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,479
Doode!!! That looks like one of my repairs!!! I bet it isn't even a G/S stand but a modified one....hope you get it fixed!!
Old 03-13-2012, 10:47 AM   #9
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
Met a guy (American) in Mexico on a trip once who was using that exact location for his "Stash". Said it was fool proof. I saw him 6 months later when he came through Colorado heading back to home so he made it across the border all right.
Tom
Infracaninophile is offline   Reply With Quote
Old 03-13-2012, 12:04 PM   #10
usgser
Oddometer: 2,201
IMO all the airhead stands are junk from day one. On my last R100 I bought a Reynolds Ride Off center stand and a Brown's side stand. Both worked great.
usgser is offline   Reply With Quote
Old 03-13-2012, 02:23 PM   #11
frichtie OP
frichtie's Avatar
Oddometer: 182
Met my welder today. As soon as my metal parts are ready, he'll be welding. He's licensed for welding aircraft engines...
The side-stand will also be replaced. AND RELOCATED!!! But first, timing-chain needs replacement. Front fork springs (progressive). Rear shock (YSS). That'll be enough for one week-end!
Eric
Old 05-01-2012, 04:57 PM   #12
frichtie OP
frichtie's Avatar
Oddometer: 182
Well,
finding someone with the proper tooling for forming a stupid piece of tubing seems to be hopeless. (For what I consider a reasonable cost).
So I decided to replace the lower part of my center-stand with "straight legs". As seen on more recent bikes.
Does anyone here has an idea of the model I should "copy" ?
Many thanks,
Eric
Old 05-01-2012, 05:13 PM   #13
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 984
Straight legs are great for on the street parking...not for off road. Look at an early model K bike for the straight leg version but I would think your bike will get very tired and lay down numerous times if you do any off road, campsite type parking.
Looks like your original was sectioned to reduce the height...as from the factory, the front wheel was about 4" in the air...fully packed bike meant hernia. Better option would be an R80ST center stand..maybe 1" front wheel clearance and you still have the curved ends.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 05-01-2012, 05:21 PM   #14
frichtie OP
frichtie's Avatar
Oddometer: 182
Thanks for the advice!
That is more my kind of work..I'm a machinist. I'm sure I'll come with a good solution.
We all like to get some advices and up to now, you guys have been very helpful!
Eric
Old 05-03-2012, 09:45 AM   #15
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,019
Or spend the money on a new one.
Centerstands break mostly from misuse, i.e. overloaded bike, sliding bike around garage while on stand, etc. They're really only there to use for maintenance.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Times are GMT -7.   It's 01:29 PM.
