Old 03-14-2012, 09:40 PM   #1
Mr. B. OP
Climate Controlled
Mr. B.'s Avatar
Oddometer: 151
/5 switchgear help please
Some of the wiring has come loose (out of its socket) on the headlight/horn switchgear side. Does anyone have experience
with how those attach? Any help would be greatly appreciated.
Mr. B. is offline   Reply With Quote
Old 03-15-2012, 03:21 AM   #2
JonnyCash
turd polisher
Oddometer: 1,601
Each of the wires has a tiny ring terminal on it, which is in turn held to its proper switch terminal with a very tiny little screw. You need a surgeon's fingers to do it.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 03-15-2012, 07:59 AM   #3
Mr. B. OP
Climate Controlled
Mr. B.'s Avatar
Oddometer: 151
Thanks Jonny, I thought there must be something that holds the wires in.
I dont see any screws yet, maybe I need to tear it down further.
How do I access the screws? Do I pull the circlip that holds the horn
button in? Anything to watch out for in doing that, like springs flying out?
Thanks again for any help on this.
Old 03-15-2012, 09:41 AM   #4
Mr. B. OP
Climate Controlled
Mr. B.'s Avatar
Oddometer: 151
Figured it out
I finally took everything apart. Mine are soldered to brass ferrules pressed into the plastic housing.
Old 03-15-2012, 12:30 PM   #5
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
I was going to chime in here and tell you how I fixed mine. The small screw that holds the switch actuator in has to be removed then you can push out the switch plate using the wire from the back, then re solder what needs to be re-soldered. This of course for those who read this in the future....As you already figured it out.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 03-15-2012, 01:41 PM   #6
Mr. B. OP
Climate Controlled
Mr. B.'s Avatar
Oddometer: 151
Can of worms
Well....in the process of handling this old switch several other OLD and BRITTLE wires decided to break at the base of the ferrule.
So it a rebuild and clean up some of the wiring.
Does any body have a source for the wire loom sleeve from the switch to the bucket? Mine was maybe 6" of sleeve and the rest elec. tape.
I'd like to clean up this mess while I'm into it. I'd like to avoid shrink tube if I can help it.
Old 03-15-2012, 03:31 PM   #7
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
How much do you need?
Do you need color coded wire as well?
I have all this by the foot.
contadct me through the website
robertv@wirewerkes.com
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 03-15-2012, 04:18 PM   #8
Mr. B. OP
Climate Controlled
Mr. B.'s Avatar
Oddometer: 151
Emailed you......Thanks
Times are GMT -7.   It's 12:01 AM.
