Old 12-02-2012, 09:07 AM   #2311
EOD3MC OP
What will break next
EOD3MC's Avatar
Oddometer: 4,839
Cheyenne and I are registered...
BreeAnna is stuck in the middle to young to ride her bike and too big to ride Cheyenne's.
EOD3MC is offline   Reply With Quote
Old 12-02-2012, 02:40 PM   #2312
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,839
Got started on some overdue maintenance on the KTM today.
First part was the transformation from fully assembled
To stripped down...
First thing to do was swap out the headlight bulbs...with the commutes to work being pretty much in the dark for the next couple months, I was hoping to get a bit more light so I'm upgrading them to PIAA Super Plasmas. We'll see how well these work.
Then on to the oil change. This time i'm installing an oil tank drain hose so future oil changes won't require pulling the fuel tanks and associated hardware.
Before
After
(The extra wrap of tape is a little protection for where the hose bends near the bash plate)
The Magnetic drain plug for the tank had me had me a bit concerned...but the filters and other drain plug were clean...
I'd post the picture of everything reassembled...but it's not...figured I'd finish tomorrow...Still plan to re-connect the O-2 sensors and complete a couple other tweaks I've been meaning to do...
Overall...nice day
Old 12-02-2012, 03:02 PM   #2313
macaroni
Oddometer: 812
Damn nice setup for the drain hose, I'll have to remember that one. If I had known you were wrenching today I would have come lend a hand.
Nice seeing everyone last night at the RTE!
"...and now it's been raining like a cow pissing on a flat rock for a few days." -WVhillbilly
macaroni is offline   Reply With Quote
Old 12-02-2012, 03:05 PM   #2314
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,839
Matt...if you plan to go with the drain hose, you will only need the fittings. I have enough hose left over for another one and your welcome to it.
Old 12-02-2012, 03:14 PM   #2315
macaroni
Oddometer: 812
Awesome!
Old 12-02-2012, 03:45 PM   #2316
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,988
Hey Dave-O...the boot is on top of the trash can, feel free to stop by and pick it up anytime. Also when I get the DRZ back together I need you to take it for a ride so we can trouble shoot that noise...I think its one of the speedometer related parts. No more wheelies though! I need to finish that thing up...I am getting tired of taking it a part. I still need to do the rear wheel bearings, lube the rear suspension linkage, rebuild the shock, change the oil, and flush/ bleed the brakes. It won't be long until I am able to ride again and I still have a lot of shit to do!!
blaster11 screwed with this post 12-02-2012 at 03:50 PM
blaster11 is offline   Reply With Quote
Old 12-02-2012, 05:00 PM   #2317
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,404
Eagle Bay Update
Don cut the logs blocking the new trail and mileaged it at 1/2 mile. He ran it 3 times and only crashed once. It needs a little more trimming here and there but is all rideable albeit a bit tight. With the additional mileage, the long loop with all options is 12 miles. Run it in less than an hour and your doing good.
I am guessing no one will oogle my personal best of 2:45..
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 12-03-2012, 09:00 AM   #2318
gastone
R.I.P. sweet Angus
gastone's Avatar
Oddometer: 2,354
It ain't the bike, it's the rider: http://advrider.com/forums/showpost....ostcount=18935
Just so you know, dude is on a Ninja 250... with clip ons. Mad fucking props.
Originally Posted by VACommuter View Post
I'd be cranky too if I had to blow 500 horses!
VAC
You can bet your sweet ass and half a titty...
gastone is offline   Reply With Quote
Old 12-03-2012, 06:31 PM   #2319
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,839
Got the KTM back together today...accomplished a good bit of maintenance done.
Upgraded the headlight bulbs
Changed the oil and filters
Cleaned the air filters
Cleaned and oiled the chain
Checked chain tension
Installed an oil tank drain hose (no more pulling the tank to change the oil)
checked the wiring for wear spots and found a good one on the main power lead where it had been rubbing on the bash plate
(repaired, armored and tightened up so it's no longer rubbing the bash plate)
Also reconnected the O2 sensors...let's see if that helps the gas mileage...
Old 12-04-2012, 06:24 AM   #2320
gastone
R.I.P. sweet Angus
gastone's Avatar
Oddometer: 2,354
I mailed the check today for the xchallenge. Hopefully it will clear, he can send me the title, and then I can get the bike shipped. I'm shooting for a mid-december delivery, but could be the 3rd week. I've done a little research and in the future I'll probably use escrow.com to handle these transactions.
VAC
Old 12-04-2012, 06:34 AM   #2321
lakota
Geeser
lakota's Avatar
Oddometer: 3,125
congratulations on the new ride
IBA #42016
my ride reports
follow my ride
lakota is offline   Reply With Quote
Old 12-04-2012, 07:01 AM   #2322
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,988
Old 12-04-2012, 07:20 AM   #2323
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,839
By the 16th would be great...you can come out at play at Eagle Bay...should be a whole new off-road experiance
Old 12-04-2012, 07:21 AM   #2324
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,988
I was thinking Hare Scramble....
Old 12-04-2012, 07:29 AM   #2325
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,839
That would be great ...He's young enough to not be in my class so I'm good...otherwise he would whoop my ass...
Times are GMT -7.   It's 06:30 AM.
