Old 12-09-2012, 08:56 AM   #2461
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,961
Originally Posted by joints4sale View Post
Since EB was a bust today, I decided to TRY and mount my cast wheels. Turns out that the wheel bolts for the spoke wheels are too long. Looking on RealOEM the spoke wheels use M10x53 and the cast wheel uses M10x40. Taking the wife's Audi for service in Annapolis tomorrow and then heading to BOB's for the correct bolts.
Since I changed over to spokes I may still have the other bolts in the attic...you are welcome to them.
blaster11 is offline   Reply With Quote
Old 12-09-2012, 09:06 AM   #2462
H14
I Gotta Go!
H14's Avatar
Oddometer: 5,003
Originally Posted by blaster11 View Post
Foots a bit swollen today so I am laying around with it propped up. His bike appears to have most if not all the mods already done so with a little suspension work he will be set. You could always change, Dave's deal was a straight up swap....I am sure someone out there is looking for a well sorted DR. Any interest in going along on the TWVT 04 - 12 May...even a couple of days?
Would love a DRZ but I've gotten too attached to the DR now. I have a hard time letting things go, I guess I need to ride the piss out of it and try to kill and then I can move on.
You know I have a soft spot for the TWVT but our 25th wedding anniversary falls right in the same time frame as your trip and we may be riding to Vermont/New Hampshire then.
http://www.crazyfoxcoffee.com/ Discount code ADV
"IF Comcast was a baby I would shake it."-Bloochdog
H14 and Campcook wandering aimlessly 2-up
2012 Riding the Continental Divide
H14 is offline   Reply With Quote
Old 12-09-2012, 09:06 AM   #2463
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,961
Dave...I guess Shane is officially all done with KTM Hutt.
http://advrider.com/forums/showthread.php?t=846597
Old 12-09-2012, 09:09 AM   #2464
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,961
That will be a nice trip!
Old 12-09-2012, 09:39 AM   #2465
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,381
You'll shoot your eye out..Hiding Keys
Mom always told me two things: 1) you'll shoot your eye out and 2) You'd lose your head if it wasn't screwed on
Being that 2) tends to be true from wallets to keys, I am petrified to think I will be thousands of miles from home and lose my bike keys. So, I usually take a spare set. I've always struggled to keep them somewhat away from the elements.
Of the few holders I've used, most are two small to accommodate the big ass BMW key. But, on rev 2 I've finally found one:
DELUXE MAGNETIC KEY LOCKERS by Bell Model #05905
It's unlikely that you will find flat ferrous metal spot to use the mounting magnet. Since space is a premium, it needs to go! You can pop it the magnet off using a screw driver (it's not glued). Then I put the metal cup/plastic liner on the 3M Scotchbrite buffing wheel. The wheel creates enough heat to loosen the glue on the metal cup so you can remove it. Then just buff down the remaining plastic liner to flat.
Once the back is flat, use 3M Double Sided tape to stick it your favorite hidey hole on the bike.
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 12-09-2012, 09:42 AM   #2466
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,961
DRZ suspension discussion
Dave...here is a good discussion on setting up the DRZ or really any suspension. Get ready because as soon as I get back riding that is one of the first things I plan to do on the DRZ. I will most likely set the sag before I am riding but the other stuff will have to wait.
http://www.thumpertalk.com/topic/269...n-tuning-tips/
blaster11 screwed with this post 12-09-2012 at 09:49 AM
Old 12-09-2012, 09:49 AM   #2467
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,381
Our 25th wedding anniversary falls right in the same time frame as your trip and we may be riding to Vermont/New Hampshire then.
BlastOff Adventures
Old 12-09-2012, 10:06 AM   #2468
EOD3MC OP
What will break next
EOD3MC's Avatar
Oddometer: 4,830
Soon...first I have to finish adjusting the clutch, bars, and guards....then inspect the wiring....then the front tire (seems a bit soft at the moment)....
but the real priority today is getting the christmas lights up...but since it's raining...I guess I just have to keep tweeking on the bike
EOD3MC is offline   Reply With Quote
Old 12-09-2012, 11:08 AM   #2469
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,961
but the real priority today is getting pictures and video of me wheeling the DRZ in front of the house...but since it's raining...I guess I just have to keep tweeking on the bike
Fixed....your not done yet?
Old 12-09-2012, 11:14 AM   #2470
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,961
Just in case you need some inspiration Dave-O.
Old 12-09-2012, 11:51 AM   #2471
motomandan
motomandan's Avatar
Oddometer: 446
TWVT? big bike or little bike?
motomandan is offline   Reply With Quote
Old 12-09-2012, 12:53 PM   #2472
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,830
That just makes this crappy weather worse....
So, since I couldn't "safely" get to the christmas lights, I knocked out a few things on the DRZ
Control levers lubed and adjusted
Hand guards relocated to match the levers
Radiator overflow container cleaned out (had a bit of sediment in it)
Rear light housing cleaned and tightened
Chain adjusted cleaned and lubed
Tire pressure adjusted
explained to neighbor why green bike is now blue
pulled all the plastic and gave it general through looking over......but no riding
Old 12-09-2012, 01:26 PM   #2473
blaster11
Up and Operational
blaster11's Avatar
Oddometer: 6,961
We are taking the little bikes on this trip. Dana says there are about a half dozen alternates which won't be big bike friendly, "95% big pig heaven".
Old 12-09-2012, 01:28 PM   #2474
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,381
Also, since they are "alternates", there is obviously a "big bike" track that avoid those sections.
BlastOff Adventures
Old 12-09-2012, 01:29 PM   #2475
joints4sale
No. Not "That Kind".
joints4sale's Avatar
Oddometer: 3,110
When's the first planning session?
Erik : IBA #40645---BMW135i FOR SALE<---CLICK
"If my life or death depends on getting Bruce or Dana on the phone then I'm gonna die." RFlagg42
2011 TC449, 2014 S1000R, 2010 R1200GSA 30th Anniversary Edition, 2003 Ktm 625sxc(gone), 1999 DR350(gone), 2007 K1200GT (traded for the GSA). 2004 R1150R (traded for the GT)
joints4sale is offline   Reply With Quote
Times are GMT -7.   It's 10:49 PM.
