01-19-2013, 05:00 AM
#3256 |
Bring me up!
Oddometer: 2,925
GPX file on GoogleDrive
Here's the GPX track, so folks can get practice loading their GPSs.
Download 2013 Middleburg Tarmac Ride GPX here Click on download Click Save Open windows explorers, transfer file from your computer to your GPS SD card. I've also put it on post #2 of this thread under rides and GPX files. Here's the finale tally I've got Rendezvous point #1: WaWa RT301/RT06 (departing 0840) 5362 James Madison Parkway, King George, VA Blaster Dorito EOD3MC J4S Macorell (RT301/RT225 pickup) RaysGSA RaysGSA Son Rendezvous point #2: Target on RT 17/I95 (departing 0910-ish) 25 South Gateway Drive, Fredericksburg, VA VacCommuter (with Latte)
Nothing (ad)ventured, Nothing Gained Explore. Dream. Discover. Maryland OHV Alliance Dorito screwed with this post 01-19-2013 at 05:52 AM |
01-19-2013, 05:37 AM
#3257 |
Oddometer: 375
Don't forget me!
Tell someone you love them today, because life is short...but shout it at them in German because life is also terrifying and confusing. |
01-19-2013, 05:44 AM
#3258 |
Retired Navy
Oddometer: 3,516
Just me....no AJ
01-19-2013, 06:08 AM
#3259 |
Geeser
Oddometer: 2,165
Any idea where the lunch stop will be?
IBA #42016 CDR 2012 Nova Scotia 2011 Taking Molly to Atlantis Labador Newfoundland Nova Scotia 2010 Trail of an Assassin Alaska 2009 follow the ride on spot |
01-19-2013, 06:27 AM
#3260 |
Bring me up!
Oddometer: 2,925
It will probably be around 1130
Red Horse Tavern LLC 112 West Washington Street, Middleburg, VA
Nothing (ad)ventured, Nothing Gained Explore. Dream. Discover. Maryland OHV Alliance |
01-19-2013, 09:35 AM
#3261 | |
Bring me up!
Oddometer: 2,925
Plan it!
![]() Game ON! Quote:
Linky Here
01-19-2013, 10:38 AM
#3262 |
No. Not "That Kind".
Oddometer: 2,066
For that, I might just join the AMA.
Erik : IBA #40645 "We avoided looking like middle aged wannabes by riding like ninety year old has beens, and in the end our only reward for our exertions was getting to stop." 2010 R1200GSA 30th Anniversary Edition, 2003 Ktm 625sxc, 1999 DR350, 2007 K1200GT (traded for the GSA). 2004 R1150R (traded for the GT) |
01-19-2013, 10:55 AM
#3263 |
Retired Navy
Oddometer: 3,516
Big bikes or little bikes ??
01-19-2013, 11:30 AM
#3264 |
Bring me up!
Oddometer: 2,925
Last year, they really wanted the big bikes...and had the course designed for the pigs.
01-19-2013, 11:43 AM
#3265 |
Are you a Sheeple?
Erik.....Dan said you are so screwed! Your 625 has a high likelihood of killing you with all the power it's making now. Oh and the suspension should work way better as well.
01-19-2013, 11:44 AM
#3266 |
Are you a Sheeple?
Really does it matter....either way it should be a good time and its relatively close.
01-19-2013, 01:26 PM
#3267 |
Oddometer: 40
...rookie question for all you single-track riders w/ handguards. What's the best way to install the full bar type on the throttle side? I have seen some cut off the little lip on the end of the grip, roll back the rubber a little, take a sliver off the throttle tube, and install that way. However, I am worried about dirt and crap getting between the tube and the bars, given the guard bar doesn't cover the hole 100%...if that makes any sense.
![]() Here's a shot of how I did the clutch side. I left the lip on there, heated up a socket and pressed into the center of the end cap (to score out a perfect circle as a template), and then tapped out the center with a drywall cutting tip on the Dremel. It was nerely perfect, but there was a small opening that the Cycra bar didn't cover...so I used a black neoprene washer to seal it off to help reduce the amount of dirt/water that gets in there. That being said, I am just not seeing how to seal up the throttle side, given I can't have rubber on rubber washers binding and sticking the throttle. I am 99% sure I need to remove the rubber lip, but I just envision a big gapping hole that lets in tons of dirt between the throttle tube/bars. Thoughts?
01-19-2013, 02:34 PM
#3268 |
Retired Navy
Oddometer: 3,516
Dana, if I'm reading the route right...we will pass right by Old House Winery...Karen has two bottles of wine ready for pick up...may need to make a small stop to keep MaMa happy
18351 Corkys Lane, Culpeper, VA 22701 3 miles up Stevensburg Road (Rt. 663) from Rt 3 Loading Maps....Comms gear charging... almost ready to roll
01-19-2013, 02:35 PM
#3269 |
Retired Navy
Oddometer: 3,516
01-19-2013, 03:00 PM
#3270 | ||
Bring me up!
Oddometer: 2,925
![]() Quote:
Full disclosure, I've not "test-ridden" the route. It was a compile from two sources. We may love or hate it!
