Old 02-19-2013, 03:50 PM   #3736
blaster11
Ding fries are done!
blaster11's Avatar
Oddometer: 6,922
Originally Posted by gastone View Post
Crofrog...
when's the suspension workshop?
I like that idea....a lot!
blaster11 is offline   Reply With Quote
Old 02-19-2013, 03:59 PM   #3737
lakota
Geeser
lakota's Avatar
Oddometer: 3,097
me too
IBA #42016
my ride reports
follow my ride
lakota is offline   Reply With Quote
Old 02-19-2013, 04:03 PM   #3738
blaster11
blaster11's Avatar
Oddometer: 6,922
So Lakota what items will you be buying with your 30% off coupon? I am getting a set of heated grips for the HP2. Any update on the 700?
Old 02-19-2013, 04:06 PM   #3739
blaster11
blaster11's Avatar
Oddometer: 6,922
Trails in MD a possibility
Dana has been helping out on this project and it looks like they may be getting some traction.
http://advrider.com/forums/showpost....44&postcount=7
Old 02-19-2013, 04:31 PM   #3740
lakota
Geeser
lakota's Avatar
Oddometer: 3,097
i will be using the coupon to buy the adventure cases. saves about $500.
the 700 should have arrived in New York Monday. Will be going to Bob's Thursday to buy the bags (to be sure the coupon is good) and and check on the bike status.
IBA #42016
my ride reports
follow my ride
Old 02-19-2013, 04:39 PM   #3741
EOD3MC OP
What will break next
EOD3MC's Avatar
Oddometer: 4,801
Crofrog...
Originally Posted by crofrog View Post
I'm just a nerd who likes to play with suspension, but we could probably all get together and check and set sag. Figure out if different springs are needed. See where the forks are in the triple clamps. All the easy stuff.
Who's hosting? and who's bringing the grill?
EOD3MC is offline   Reply With Quote
Old 02-19-2013, 04:44 PM   #3742
Tom250xc
Oddometer: 8
ALCON,
Crofrog is spot on! And Drew from WER and RaceTech are excellent resources. Always set/check your sag, comp, rebound settings...and make sure your fork is located teh same in teh triple clamp (lower - more stable (less head shake) but worse for turning....higher - less stable (more head shake) but better turning) ! And always check the race sag with your balls on the tank with all of your riding gear on (to inlcude your camelback full of water)! And off-road bike manufacturers design suspensions with a typical buyer in mind (i.e., 165lb, 5'10" rider), so dont be surprised if you find you're undersprung. I had go up a couple of spring constants as well as do a revalve job a year ago. I just had the supspension refreshed (you need to do a refresh once a year at least) and reassembling this week, so I will be setting sag and fine tuning comp/rebound this weekend (I take a small screwdriver in my boot when practicing on the trails). Finally, like I said earlier, Crofrog is sharing sage advice so kudos to him! The SMAR gang is lucky to have Crofrog in your ranks.
Tom250xc is offline   Reply With Quote
Old 02-19-2013, 04:49 PM   #3743
blaster11
blaster11's Avatar
Oddometer: 6,922
Disregard what I said earlier about liking the idea....no balls on the tank in my garage! DRZ tanks are metal and cold.....
Old 02-19-2013, 04:55 PM   #3744
Tom250xc
Oddometer: 8
well...........put one of the "hot hands" down there and "git-r-done" :)
Old 02-19-2013, 05:03 PM   #3745
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,345
I had to ask the interwebs about this....
Balls to tank = Balls To The Wall, This Is Not Effektive
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 02-19-2013, 05:20 PM   #3746
blaster11
blaster11's Avatar
Oddometer: 6,922
It got kinda quiet.....your trying right now aren't you?
Old 02-19-2013, 05:47 PM   #3747
blaster11
blaster11's Avatar
Oddometer: 6,922
Sidi boots
So I was looking for some lugged soles for my Crossfire boots and finally found some in stock at Rocky Mountain ATV...ordered! While searching I also found the new Crossfire 2 boots with all kinds of color combinations, not quite sure what to think of them.
Old 02-19-2013, 06:05 PM   #3748
EOD3MC OP
EOD3MC's Avatar
Oddometer: 4,801
Trying what?
Old 02-19-2013, 06:20 PM   #3749
Tom250xc
Oddometer: 8
Trying what?
You really made me laugh EOD3MC!
The next subject for me today is tire pressure. I run between 10-12 psi. However, there are a LOT of variables that need to be accounted for. Such as tires (Dunlop/Bridgestone/Perelli is what I run), aspect ratios (120/100 rear and 100/80 fronts is what I run), Inner tubes (HD/UHD is what I run), terrain (if VERY rocky and fast I run 11-12, otherwise 10, sometimes I'll do 10 if I have new tires but I'm taking a chance when I do), wet or dry (10 if its wet 12 if its dry), slow single track or fast quad track, new tires or worn tires (10 if new, 12 if worn casuse sidewalls breakdown as the wear) and then a sprinking of "best guess". All that and sometimes if I'm screaming through a very rocky mine field I chance getting a pinch flat (it happened just last summer). I've seen guys run betwen 8-14 psi. I think the magazines recommend 10-14psi.
Old 02-19-2013, 10:02 PM   #3750
blaster11
blaster11's Avatar
Oddometer: 6,922
Times are GMT -7.   It's 11:58 AM.
