Old 09-28-2013, 08:17 AM   #6406
lakota
Geeser
lakota's Avatar
Oddometer: 3,156
+1
IBA #42016
my ride reports
follow my ride
lakota is offline   Reply With Quote
Old 09-28-2013, 08:56 AM   #6407
blaster11
I'm back!
blaster11's Avatar
Oddometer: 7,051
Johnny Boys BBQ
So we went to Johnny Boy's last night for dinner and as usual it was very good. They continue to update the place with new picnic tables and now they have a screened in Gazebo with plans for another one. As an added bonus they had an older black guy gentleman there playing a guitar and singing.....he was actually very good and not annoying at all as the volume was just right. He had a good mix of blues and other stuff....I would go back just to listen to him play.
blaster11 is offline   Reply With Quote
Old 09-28-2013, 12:25 PM   #6408
joints4sale
No. Not "That Kind".
joints4sale's Avatar
Oddometer: 3,127
Originally Posted by RaysGSAdv View Post
Where you headed? Is revzilla open on sundays?
Not going anymore. Found a car for J4S jr. for $4k but it needed a $3k repair. Decided to pass.
Erik : IBA #40645---BMW135i FOR SALE<---CLICK
"If my life or death depends on getting Bruce or Dana on the phone then I'm gonna die." RFlagg42
2011 TC449, 2014 S1000R, 2010 R1200GSA 30th Anniversary Edition, 2003 Ktm 625sxc(gone), 1999 DR350(gone), 2007 K1200GT (traded for the GSA). 2004 R1150R (traded for the GT)
joints4sale is offline   Reply With Quote
Old 09-28-2013, 02:36 PM   #6409
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,492
But how were the batteries and stator?
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 09-28-2013, 02:46 PM   #6410
joints4sale
Oddometer: 3,127
About to loose timing.
Old 09-29-2013, 03:45 AM   #6411
blaster11
I'm back!
blaster11's Avatar
Oddometer: 7,051
Wow did things not go well in the garage yesterday....must of been the EMP that screwed things up. Luckily for me though Dorito stepped away for some dinner and when I got home I started back in and amazingly enough most things got corrected so I think I am back on course....S500 here we come! Not so good for Dorito though....it started off with bad batteries on the big truck and ended with rusted out brake lines, at least it happened in the driveway. Maybe a ride to breakfast at Panera's this morning....need to set the tone for the day.
Old 09-29-2013, 04:38 PM   #6412
blaster11
I'm back!
blaster11's Avatar
Oddometer: 7,051
RTE to Sushi 08 October
I figure this will be my last opportunity for Sushi for quite some time since I am going back in on the 10th for more foot surgery but hopefully it will result in . We could do Waldorf, La Plata, or down J4S's way....doesn't matter to me. I am thinking around 6:00 but I am open to other times if it makes it easier for others.
Old 09-29-2013, 04:57 PM   #6413
joints4sale
Oddometer: 3,127
I'll be dining on Lobster.
Old 09-29-2013, 05:01 PM   #6414
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,492
MMM, raw lobster
BlastOff Adventures
Old 09-29-2013, 05:33 PM   #6415
EOD3MC OP
What will break next
EOD3MC's Avatar
Oddometer: 4,876
So after some great riding Friday and Saturday, I figured I'd knock out some maintenance on the KTM
Oil change took about 20 minutes thank to the drain hose installed on the oil tank.
Don't have to pull the left side tank anymore to swap the oil and main filter. Occasionally, I'll have to pull the hose fitting to check the screen located at the tank.
Pulled the air filter and cleaned it up, replaced the prefilter and installed a filterskin over that.
Thank I pulled the tank anyhow to change out the fuel filters. The last time I changed these out was just shy of a year ago.
Looks like they needed it.
Here are the T-bag filters for comparison
Close up of the old filter...actually had debris from the tank attached to it
Here are the secondary filters...
I got this new filter kit from an inmate in Greece for a fraction of the KTM price. The only difference to be seen was the height of the secondary filter. Everything fit well and seems to work fine.
Then the problems started...
First I get everything back together and the bike won't start. Troubleshoot a bit and the fuel pump doesn't seem to be working. Checked all the plugs and connections...no luck. Off with the tank again and pull the pump assembly. Found the problem there easy enough, one of the pump's electrical connections came loose inside the housing. Fixed and back together again. Working fine, started right up
But that's not all...
Apparently the fuel pump housing wanted more attention since it was weeping gas...
Off with the tank again, out with the pump assembly....again...checked the gasket, looks good. Cleaned up the edge around the pump mating surface...put a bit of grease on the O-rings to help them slide into place...
Put it all back together again...
Looks like it's fixed...took it for a short little ride tonight. It's amazing what a difference the new fuel filters make. Power you never notice loosing is suddenly restored.
EOD3MC is offline   Reply With Quote
Old 09-29-2013, 05:54 PM   #6416
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,492
Silly Dave, the Katoom goes ontop of the lift...
Like this:
BlastOff Adventures
Old 09-30-2013, 03:18 AM   #6417
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,492
Things to wanderlust about doing..
Fri Oct 4-6 Nottarally - Hot Springs, NC
Fri Oct 4-6 Color in the Catskills - Hunter Mountain Resort
Sat Oct 5-6 Shenandoah 500 - George Washington National Forest
Sat Oct 5 Oktoberfest - Mortons BMW
Sun Oct 6 Virginia British Motorcycle Club Rally - Manassas, VA
Mon Oct 7 Baltimore RTE (Hosted by LoPL) Dixie Eatery - Smithsburg, MD 21783
Tue Oct 8 Pridmore CLASS - Virginia International Raceway
Thu Oct 11-14 BWDR 2013 Camp Out and Interpretive Dance Festival - Elkton, VA
Sat Oct 12-13 Void Rally - Fredericksburg, VA
Sat Oct 12 Beemers & Warbirds Rally - VA Beach, VA
Sun Oct 13 Rattlesnake Harescramble
Sun Oct 13 RORR dual sport event - Pine Grove, PA
Fri-Sun Oct 18-20 Shane Watts Riding Class(Hosted by Dual Sport Armory) - Northern VA
More information all post #2 calendar (click on each event)
Got ideas/events for calendar? Send them in
BlastOff Adventures
Old 09-30-2013, 04:26 AM   #6418
gastone
R.I.P. sweet Angus
gastone's Avatar
Oddometer: 2,416
Dave,
how was the camping this past weekend?
Bruce,
sorry that I won't be able to make it on the 10th.
Originally Posted by VACommuter View Post
I'd be cranky too if I had to blow 500 horses!
VAC
You can bet your sweet ass and half a titty...
gastone is online now   Reply With Quote
Old 09-30-2013, 04:35 AM   #6419
blaster11
I'm back!
blaster11's Avatar
Oddometer: 7,051
Originally Posted by gastone View Post
Bruce,
8th but ok.
Old 09-30-2013, 05:22 AM   #6420
lakota
Geeser
lakota's Avatar
Oddometer: 3,156
more Gail
http://www.horizonsunlimited.com/tstories/baillargeon/
IBA #42016
my ride reports
follow my ride
Times are GMT -7.   It's 03:34 PM.
