Old 03-06-2013, 09:49 PM   #391
Nomad
High Speed Low Drag
Nomad's Avatar
Oddometer: 250
Originally Posted by Geek View Post
Here are some pics I just took of it mounted up:
yeah that is really nice! i like the carbon fiber decals...nice touch!
is that a hyde skid plate you have on there?
2012 KTM 500 EXC
NON SEMPER ERIT AESTAS
www.motoex.net
Nomad is offline   Reply With Quote
Old 03-06-2013, 10:19 PM   #392
David_Moen
David_Moen's Avatar
Oddometer: 1,292
Oh man, I think I just had an inappropriate response to those pictures! A little of that carbon decally stuff in the inter bits of the hand guard shields would be tasty too. I know it wouldn't last a minute in the bush, but it would be good for the beauty shots.
2013 KTM 350EXC-F, 2005 BMW R200GS, 1984 Kawasaki GPz 750
David_Moen is offline   Reply With Quote
Old 03-06-2013, 10:31 PM   #393
The Wolf
Among The Living
Oddometer: 345
geek what steering stabilizer are you using?
The Wolf is offline   Reply With Quote
Old 03-07-2013, 06:33 AM   #394
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
Thanks Yes, the hyde plastic plate.
Old 03-07-2013, 06:34 AM   #395
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
Scotts - mounted on the HDB mounting
Old 03-07-2013, 06:35 AM   #396
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,689
Cool thing is I have a huge roll of it from when I covered my 950's glove box lid with it.
I made a template.. so it would take me less than 5 minutes to peal it off and replace it depending on how much I tear it up in the woods
If I find myself shredding it every ride.. I'll probably just mask it off and paint it.
Old 03-07-2013, 07:40 AM   #397
DirtJack
DirtJack's Avatar
Oddometer: 1,596
Great look, you could use some on the tank insets too.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 03-07-2013, 07:43 AM   #398
The Wolf
Among The Living
Oddometer: 345
Anybody have the ohlins 2.1 on thier 500?
Old 03-10-2013, 10:13 AM   #399
David_Moen
David_Moen's Avatar
Oddometer: 1,292
I'm back in the garage this weekend looking to finish up the installation of my HDB hand guards and heated grips.
As already suggested I would like to use the fan connector under the tank to power the grips. The molex connector on the now unused license plate illumination light matches this connector and the wire is more than long enough to get up behind the headlight. How would I know which side of the fan power connector is power, and which is ground?
Old 03-10-2013, 10:30 AM   #400
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 448
I've just completed exactly what your doing, at least installing HDB setup with heated grips. I used a Battery Tender lead, (it's Fused) from the battery up to the headlight. Made my own male/female connector set up. Put the headlight on right side of the handlebar bracket and the heated grips on the other. I only wired the heated grips for the low side. Less amps and convenience, used the HWD push buttons for both. Turned out real good! Only problem I can see is leaving the grips on! I'll have to be very causes about that!
WRW9751 is offline   Reply With Quote
Old 03-10-2013, 10:41 AM   #401
David_Moen
David_Moen's Avatar
Oddometer: 1,292
I want to use a switched circuit so I know if the key is off, there is no power drain.
Old 03-10-2013, 10:51 AM   #402
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 448
My thought was not to use or rob power from another circuit, not really knowing just how many amps the grips would pull. My xc doesn't have a key.
Old 03-10-2013, 11:30 AM   #403
The Wolf
Among The Living
Oddometer: 345
has anybody lowered the pds?
im trying to find info on it and i cant find much. any advice would be greatly appreciated.
Old 03-11-2013, 06:52 AM   #404
woodzrider
Oddometer: 592
C'Shaft Bolt removal
Any got any ideas on the best way to remove the factory loctited c'shaft bolt to change sprockets? The first that come to mind are hotlips(torch)
or rattlegun. That oem stuff is brutal. I am ordering a new bolt and D/T washer for the next time..
Woodzrider AKA vetracer1
"If it can't kill ya-it's not a sport"......It ALMOST killed me tho.....
Check out my crash report:
http://www.advrider.com/forums/showthread.php?t=500314
Baja report http://www.advrider.com/forums/showthread.php?t=641219
woodzrider is offline   Reply With Quote
Old 03-11-2013, 09:10 AM   #405
240nekkid
Oddometer: 29
i used a bfw on my 500exc
240nekkid is offline   Reply With Quote
Times are GMT -7.   It's 03:40 AM.
