Old 04-01-2013, 08:05 PM   #436
RSinBC
Oddometer: 183
Flame outs
For the EXC's some have luck with the JD, mine still dies! I am going to have the XC-W un-restricted map installed on Wednesday, but I have a feeling the TPS may be partly to blame. I am going to find put where it is set at, hopefully it is out, a smoking gun is nice to find when chasing these types of problems.
You might want to check your TPS setting to see where it's at. KTM calls for 0.601v closed. Some are having good luck with 0.640v closed. Also engine should be at operating temp.
Good luck
Richard
RSinBC is offline   Reply With Quote
Old 04-01-2013, 08:08 PM   #437
The Wolf
Among The Living
Oddometer: 346
Good luck
Richard
here some good info for the tps:
http://www.ktmforums.com/forums/offr...flame-out.html
The Wolf is offline   Reply With Quote
Old 04-01-2013, 08:29 PM   #438
RSinBC
Oddometer: 183
Tps
Good info on adjusting the TPS. I want the bike hooked up to the Dealers computer so i can be sure of the final setting. I will most likely set it to 0.64 and see how it runs.
Old 04-02-2013, 02:39 AM   #439
team ftb
Befuddled Adventurer
Oddometer: 1,761
Originally Posted by The Wolf View Post
its an xcw. usually happens when the clutch is pulled in or in neutral
Try raising the idle to the point its idling higher than the usual carbed bike idle. Worked for me.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 04-02-2013, 09:51 AM   #440
Turbo
used to be XC700116
Turbo's Avatar
Oddometer: 4,744
This is one I saw with the carbed bikes alot, seems a lot of people think the idle should sound like the bike is barely running. Should be at 1800 RPM on the old RFS's and it made a world of difference. New 500 XC-W specs 1800-1900. Until you get used to the sound of it at that idle it sounds kinda fast. I haven't dug into the new one but on the RFS motors with the auto de-comp it was especially important as the Auto Decomp was working at below 1500 ish. So not only was your motor consuming less air/fuel, it also was partially opening a valve on the compression stroke.
That's one of the first things I did with mine is to check it and it was at about 1200 and would stall easily just starting out on pavement. Up to 1800 and not so much.
ΜΟΛΩΝ ΛΑΒΕ
Turbo is offline   Reply With Quote
Old 04-02-2013, 10:29 AM   #441
CamelBill
Ride It!
CamelBill's Avatar
Oddometer: 527
Headlight bulb not working
'13 XC-W, the small running light burns, but not the stock headlight bulb. The bulb is good, glows fine when wired direct to a spare battery. I have seen mentionof this as a recurring problem, but have not come upon the fix. Where do I start looking, or is the stock headlight just worthless crap that needs to be replaced.? I really use it as a dirt bike, but it is licensed for occasional trail connector use, so would like some kind of working headlight.
If I do go aftermarket, looking for suggestions for a rugged headlight the stock electrics can handle - since it is a dirt bike mainly, I don't really need any deer burners. Thanks.
Camel
KTM 1190R, 950S, 500XC-W
FJR, Wing
CO Single Track RR http://advrider.com/forums/showthrea...0#post24875020
CamelBill is offline   Reply With Quote
Old 04-02-2013, 01:17 PM   #442
woodzrider
Oddometer: 607
The stock bulb is merely a candle!
I sprung for the SAR light kit for my '13 XC-W 500 and love the kit. However the stock headlight bulb is absolutely worthless! I ordered a halogen replacement bulb and it works a lot better, although it could be worlds better yet. The stock bulb is also prone to early retirement (measured in minutes depending on trail conditions). Make sure the rubber o-ring that is on the bulb socket is still there-it serves as a vibration damper otherwise the bulbs just vibrate into oblivion. Hope that helps.
Woodzrider AKA vetracer1
"If it can't kill ya-it's not a sport"......It ALMOST killed me tho.....
Check out my crash report:
http://www.advrider.com/forums/showthread.php?t=500314
Baja report http://www.advrider.com/forums/showthread.php?t=641219
woodzrider is online now   Reply With Quote
Old 04-02-2013, 09:40 PM   #443
RSinBC
Oddometer: 183
Idle Speed
I got off on a tangent from the KTMforums link above and somewhere it was mentioned that Blaise Racing de smog kit recommends setting the idle speed by unscrewing the idle speed knob, CCW, all the way till it stops. Then screw back in 17 CLICKS CW. the person that posted said they found 15 CLICKS in to work better for them.
So i tried it at 16. The bike started instantly and idled much smoother and seemed stronger. I did not need to pull the choke knob out either, the bike would never start and stay running without the knob pulled. No chance to ride it yet, but i will tomorrow. I am pretty sure this will help the stalling at traffic lights and flame outs. I am off to the dealer in the AM to re-map to XC-W spec and will have them check the TPS and actual idle speed while it is hooked to the diagnostic computer.
Richard
Old 04-02-2013, 10:02 PM   #444
The Wolf
Among The Living
Oddometer: 346
well done GS
Old 04-03-2013, 11:46 AM   #445
roadracer
roadracer's Avatar
Oddometer: 343
If anyone is looking for an ohlins 2.1 I took one off my 350exc when I sold it and it won't mount on my 450xc-f. pm me.
Anybody have the ohlins 2.1 on thier 500?
roadracer is offline   Reply With Quote
Old 04-03-2013, 11:58 AM   #446
The Wolf
Among The Living
Oddometer: 346
Pm sent. also send me some pics plz.
Old 04-03-2013, 08:52 PM   #447
RSinBC
Oddometer: 183
Follow up
i know this is the XC-W thread but they all seem to have similar issues, so here is how it went today.
I took the bike to my dealer and had them re-map to the XC-W map, check the TPS and idle speed.
My TPS was at 0.610V so we left it there.
The idle speed as i had adjusted it was 2300, so it was dropped to 1900 RPM
And the Map for the XC-W with ending with 601was installed. Looking at it now i need to call them and ask if it was the US map or the EU map.
I also asked about the 701 Map, and they had not heard of it before so they called KTM Canada and were told no dice! you cannot have this map! and you really should not put the 601 map on an EXC!
Bottom line, the bike does not seem to stall anymore and will lift the wheel in 4th without really trying. If the flame outs are really gone i will be extremely happy.
So if you adjust the idle screw as outlined above, 17 clicks may be too fast an idle.
Old 04-07-2013, 12:11 AM   #448
The Wolf
Among The Living
Oddometer: 346
anybody have a broken kickstand they want to sell me?
Old 04-07-2013, 05:56 AM   #449
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,221
I have a stock kickstand that is not broken that ill sell ya.
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 04-07-2013, 05:06 PM   #450
Jason Abbott
Long time Idaho rider
Jason Abbott's Avatar
Oddometer: 670
Question Run heavier wire for heated grips, GPS, etc.?
Been in the garage all day adding Sicass light kit, heated grips and Lynx fairing with USB and dual HID. Nearly killed my brain but it's all working now. This is on a 2013.
Question: is it really just the thin brown and white wires bringing power up front? The Lynx ran it's own dedicated power from the battery but I'm far from clear about which wires will carry the load for heated grips, GPS, phone. I'm no electrician but I'm handy with a multimeter if anyone has pointers ...
Photo ride reports: http://trailimage.com/ _
Jason Abbott screwed with this post 04-07-2013 at 05:46 PM
Jason Abbott is offline   Reply With Quote
Times are GMT -7.   It's 07:45 AM.
