Old 07-15-2013, 10:23 AM   #481
Jason Abbott
Long time Idaho rider
Jason Abbott's Avatar
Oddometer: 670
Leave forks in triple clamp for spring install?
Got a new set of fork springs to better match the big tank and HID lights. After watching a couple Slavens videos I don't see why I wouldn't just pull the handlebars off and pop the springs in on the bike. Am I overlooking something?
Photo ride reports: http://trailimage.com/ _
Jason Abbott is offline   Reply With Quote
Old 07-15-2013, 04:17 PM   #482
cross-country
cross-country's Avatar
Oddometer: 1,677
Nope, just keep a hand on the damper rod so it doesn't get out of reach. You will want to remove the front wheel to make things a bit easier.
cross-country is offline   Reply With Quote
Old 07-15-2013, 06:22 PM   #483
rotorhead511
Live and let live.
rotorhead511's Avatar
Oddometer: 482
Headlight
Can someone explain to me how the headlight works? When I first start the bike the parking light is on but then when I get out riding the headlight is on. Is this thing connected to speed-o or something?
Baffled
'12 450 XC-W
'11 300 XC
'04 GasGas TXT Pro 280
'89 Honda Transalp XL600V
rotorhead511 is offline   Reply With Quote
Old 07-15-2013, 08:06 PM   #484
Jason Abbott
Oddometer: 670
Thank you. That was easy.
Old 07-15-2013, 09:30 PM   #485
heavy_-j
Need me some Adv!
heavy_-j's Avatar
Oddometer: 31
Man i want me one of these.....this has been a fun thread to peruse...I need to quit before I find myself at a KTM dealership!
Currently on an FZ6 with some big bags = Long and fast trips!
PNW riders...hit me up! I'd love to tag along and learn the the area better and get some riding in with good peoples...I can just cruise or ride WOT all day...I'm game for anything.
heavy_-j is offline   Reply With Quote
Old 07-16-2013, 07:00 AM   #486
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 667
Me too.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 07-16-2013, 09:21 AM   #487
WRW9751
7th Day Adventurist
WRW9751's Avatar
Oddometer: 450
Baffled
I have a 12" xc-w 500. My light has a switch, on or off no hi-low. I don't have to run with it. If the switch is on the light doesn't come on unless the engine is running. Sicass makes some options.
WRW9751 is online now   Reply With Quote
Old 07-16-2013, 09:58 AM   #488
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 284
Overheating Resolved
My 2013 XC-W boiled one day on a slow tight climb at 80F. Not acceptable.
Here is what i did:
I removed the louvered plastic rad guards.
Installed Flatland Racing radiator guards.
Replaced the crap radiator fluid with Engine Ice.
Installed an overflow tank for the rad fluid.
Just returned from 3 days of climbing around in Montana in the same temps as above. The fan was running regularly on climbs but the fluid did not get as hot. The fluid never made the boiling noise. There was fluid passing into the catch bottle and being drawn back into the radiator on a regular basis.
I am satisfied with the fix.
JB
jonb is offline   Reply With Quote
Old 07-17-2013, 10:44 AM   #489
CamelBill
Ride It!
CamelBill's Avatar
Oddometer: 518
Baffled
Stock headlight does not work very well, if at all, on mine either,. Even with the switch on. The bulby is fine, lights right up when hoooked up direct to a battery. Me thinky these things are just sucky
Camel
KTM 1190R, 950S, 500XC-W
FJR, Wing
CO Single Track RR http://advrider.com/forums/showthrea...0#post24875020
CamelBill is offline   Reply With Quote
Old 07-17-2013, 12:46 PM   #490
guns_equal_freedom
Oddometer: 5,578
Buy the aftermarket bulb from Sicass.
http://sicassracing.com/store/bulbs/...m_upgrade_bulb
guns_equal_freedom is offline   Reply With Quote
Old 07-17-2013, 12:50 PM   #491
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,180
Here is what i did:
Where did you put the overflow tank? I have one, but can't find a spot for it!! Thanks
I don't have to be right to argue.
NICO
unaweep is offline   Reply With Quote
Old 07-18-2013, 10:02 AM   #492
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 284
Location of the overflow container
I installed mine up front on the outside edge of the right radiator tucked between the plastic radiator shroud and the radiator guard. It is tie wrapped to the rad guard with three tie wraps. It makes for a super easy install as all you do is run your tubing from the top of the right radiator, around the front and up to the bottom of the tank keeping the tube inside the rad guard. Then run out of the top to the catchment tank to the plastic fitting in the frame where the fuel overflow hose went.
Mine worked really well this trip. didnt budge.
JB
Old 07-18-2013, 10:14 AM   #493
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 284
Idle RPM adjustment; is there any?
I assume on the 500XCW there is no way to bring the idle down a little without going into the KTM dealership and having them check your TPS and seeing if its where it should be...right?
My 500 idles faster than any other bike i have owned but its not outrageous. If i could, i would lower it.
Are others finding their XCWs idle a little high?
Thanks.
JB
Old 07-18-2013, 10:25 AM   #494
CamelBill
Ride It!
CamelBill's Avatar
Oddometer: 518
Really? Like i said my bulb works, just not in the stock housing. I'd be a happy camper if this actually works, much cheaper than an entire new assembly. Anybody else had this work for them? Thanks!!
Camel
FJR, Wing
Old 07-18-2013, 11:01 AM   #495
wsmc831
wsmc831's Avatar
Oddometer: 773
Thanks.
Really, the xcw doesn't have an idle control on the throttle body like the exc? Have you looked?
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Times are GMT -7.   It's 09:53 PM.
