07-27-2012, 10:23 PM
#76 |
I'm a Seoul Man...
So, what's the verdict, doc? Lambdas are likely not an issue?
Any other readily apparent issues? (all that geek talk about hex and values and stuff?) (I had to learn that stuff many moons ago, but I could not do a flippin' thing with it now if you held a gun to my head. Are we now all anxiously awaiting the receipt of my on-a-lark purchase of two primary coils? (Yesterday's test certainly made me wonder about them, kinda for the first time)
'07 BMW 1200GS and Yamaha WR250X/R (split personality) ![]() Save $5 on a Smugmug account, use this code: hVs9vtN9NsQRQ |
07-28-2012, 01:22 AM
#77 |
Oddometer: 1,131
This has been going on since 19th march, i and others have bet on stick coils since that day and i don't waver from that. If i'm wrong i'll buy you a beer, or two.
i just seek clarity
07-28-2012, 01:40 AM
#78 | |
Syndicated
Oddometer: 11,288
07-28-2012, 03:02 AM
#79 | |
I'm a Seoul Man...
Here's hoping you're right, man! Do keep in mind though, that between 19 March and today, I've had probably less than a week to play with the bike. Most of the time between then and now, it was either in port or on a ship, so though the time was long, actual troubleshooting time hasn't been that bad. I say that now, but if new coils don't fix it, it could get weird. Poolside, JVB, and others, you guys all thinkin' coils now? I won't know 'till at least Monday, the next day mail call is open (though I'm a contractor, I have an APO box on base).
07-28-2012, 02:21 PM
#80 | |
Syndicated
Oddometer: 11,288
Poolside screwed with this post 07-28-2012 at 02:31 PM Reason: Clarity |
07-28-2012, 03:27 PM
#81 |
I'm a Seoul Man...
Not sure if I'll get to that before they get here. I will at least try to avoid having to use both, unless both my primaries do indeed need to be replaced. Good test though...basically what I did in March.
The interesting thing is that when I conducted that test in March, there was very little change, and none when the primaries were tested. Now, it seems they're acting up. I am still a little confused by they whole thing, despite understanding the "what" was being tested and also the "how." Its as if the system runs poorly "no matter what" at this point. What's the "spark plug grease" for?
07-28-2012, 04:06 PM
#82 | |
Syndicated
Oddometer: 11,288
The 'spark plug boot grease' lets the coil and boot assembly slip easily on and off the spark plug insulator. By the way, do you have the nifty coil removal tool? Yes, now I see you did do the first part of the test. Going back to the first post in this thread... Quote:
I think that logics together right. |
07-28-2012, 04:38 PM
#83 | |
I'm a Seoul Man...
HUH?! I thought if it didn't change anything, it must not have been doing anything to start with? ARGH!!!
07-28-2012, 05:19 PM
#84 | ||
Syndicated
Oddometer: 11,288
Poolside screwed with this post 07-28-2012 at 05:24 PM |
07-28-2012, 06:01 PM
#85 |
I'm a Seoul Man...
In re-reading the thread and the threads I first read to try to diagnose this, I think I misunderstood the purpose of the "remove one coil at a time" test.
I still don't get it, but if what you're saying is true, then I misunderstood the purpose of the tests. So, with your logic (that sounds cynical, but I'm just dissecting the test further), if you have an issue like mine, disconnect a PRIMARY and there is no change, is the issue with the opposite side secondary? Obviously, I still don't understand the total logic behind this.
07-28-2012, 06:26 PM
#86 | |
Syndicated
Oddometer: 11,288
07-28-2012, 06:57 PM
#87 |
I'm a Seoul Man...
Because I'm studying for the pmp today. No time to ride and play.
07-30-2012, 02:01 AM
#88 |
I'm a Seoul Man...
No parts in the mail today. I am concerned that the BMW dealer I bought them from didn't put my whole address in. We'll see.
07-30-2012, 08:27 PM
#89 |
I'm a Seoul Man...
Coils came in today. I'll try them when I get home. You folks will just be waking up...
07-30-2012, 08:45 PM
#90 |
Oddometer: 780
Stick Coil Test....
They are the spark plug caps that go in the center of the head. The secondary spark plugs are on the bottom of the head. To check them first take of the bottom sparks plug caps to make sure they are not stuck and you can get them off easy. Then with them back on warm up the bike maybe even ride it a mile or two to make sure it good and warm and idling smooth. Then with the bike on the center stand and idling reach under one side and remove the secondary spark plug wire. If there no change in the way it is running still smooth. That means that that main plug is working good and it not that coil. If it changes stumbles, cuts out, bogs down that means that cylinder is only running on the secondary plug and the main one is not firing right. if no change is noticed then try the other side. As fro the cost it should be around $ 80.00 each. Okay. Those that voted "stick coil"... I think you may have got it. Bill in OR
Remember...a fertile mind can be an incredibly dangerous thing when mixed with alcohol! |
