Old 03-20-2012, 06:55 AM   #1
tlux OP
tlux's Avatar
Oddometer: 22
Tank Liner
Hey Guys
In the next few weeks I will be painting the body work on my 1976 R90/6. While I have the current crappy paint, I have been advised to go ahead and reline/coat the inside, which makes sense. The process can get messy and I would hate to mess up my new paint in the future. However, I am not having problems with rust or the factory liner. So, do you think I should do the "preventative maintenance"? or "if it ain't broke, don't fix it"? If you recommend that I do it, what should I use? POR-15? Redcote? etc.
tlux is offline   Reply With Quote
Old 03-20-2012, 07:28 AM   #2
kantuckid
Oddometer: 3,091
No to Kreem! Yes to Por-15! If you decide to do it, but why if there's no rust? Keeping it full will avoid issues...my suggestion is to look inside with a device...
kantuckid is offline   Reply With Quote
Old 03-20-2012, 07:38 AM   #3
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,588
What ever you do, if you coat it, do it BEFORE you have the exterior painted.
+1 for RedKot.
Do not use KREME
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 03-20-2012, 07:50 AM   #4
Crazy_Dave
Back'in it in
Crazy_Dave's Avatar
Oddometer: 582
Por-15
It’s easier to apologize then it is to ask permission.
01 R1-01 CBR929-08 WR250R-92 DR650 (24-7 365)-07 F650GS-05 200 EXC-03 450EXC
Crazy_Dave is offline   Reply With Quote
Old 03-20-2012, 07:53 AM   #5
SpeedwayRN
Go Spies!
SpeedwayRN's Avatar
Oddometer: 80
Caswell
SpeedwayRN is offline   Reply With Quote
Old 03-20-2012, 08:33 AM   #6
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,436
Use the POR, or else we'll ignore.
Posting all the bikes you have or have owned in this spot is stupid.
squiffynimrod is offline   Reply With Quote
Old 03-20-2012, 08:39 AM   #7
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Why are you relining if the original is fine?
No offense, but stop listening to whoever told you to do it, that's the silliest thing I ever heard. Nothing worked as well as the original lining. Period.
Keep the original and take care of it by not letting water sit in it and keeping gas rotating through it.
If it is going to sit unused, drain it thoroughly first.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 03-20-2012, 08:51 AM   #8
bmwloco
bmwloco's Avatar
Oddometer: 1,460
Took a leap o' faith and cleaned an old BMW RS tank with PinSol, then rinsed it, dried it, and added gas.
In line filters look clean, and the bike runs... but fill the tank over 1/2 and it leaks. Looks like POR15 for this old beater.
Or just travel with a half a tank and a SIGG fuel bottle in the tail pack.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 03-20-2012, 10:39 AM   #9
chasbmw
Oddometer: 2,305
Better to drain down tanks every couple of years and remove all the crud and water that sits below the fuel pipes.
If the tank needs relining make sure that the liner manufacturer wil Gtee that the stuff will resist ethanol. Lots of problems in the UK with fuel eating either liners or Fiberglass fuel tanks.
Charles
Charles
1971 Commando Fastback
Old 03-20-2012, 03:34 PM   #10
danedg
Horizontally Opposed
Oddometer: 6,686
Moyers Tank Repair, PA
danedg is offline   Reply With Quote
Old 03-20-2012, 07:40 PM   #11
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,709
We want to see some photos down the filler neck!
Boon Booni is online now   Reply With Quote
Old 03-20-2012, 07:42 PM   #12
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,709
You have pinhole leaks or something? I'm not sure I'd expect a liner to plug a leak.
Old 03-21-2012, 04:24 PM   #13
AK Bob
AKAM
AK Bob's Avatar
Oddometer: 221
Por 15
Do the tank relining BEFORE the PAINT.
I LEARNED the Hard way.. Got traped by time gambeled and lost. May even have pics over on BMWMOA airhead rebuild link.
Wear over kill eye protection too! The plug popped, and I caught it with my face, and got real LUCKY. That stuff does burm!
It is great stuff.
Bob Coleman
AKAM
Fükengrüver
'84 R100rt
'88 R100gs
AK Bob is offline   Reply With Quote
Old 03-21-2012, 04:29 PM   #14
sebastianhammer
Oddometer: 33
+1 for Caswell
sebastianhammer is offline   Reply With Quote
Old 03-21-2012, 04:34 PM   #15
rambozo
rambozo's Avatar
Oddometer: 564
por 15
por 15 claims to fix pinholes if you paint it on inside and out, the kit i got had a mesh to cover holes on the outside, which you then paint over with por
my tank had no leaks so i cant verify if it works on that score but i was very impressed with the kit, it included a cleaner, acid etch and por 15, it was pretty dear but i'll definitely use it again
rambozo is offline   Reply With Quote
Times are GMT -7.   It's 08:59 AM.
