Old 03-20-2012, 11:43 AM   #1
rotten OP
LOST AGAIN
rotten's Avatar
Oddometer: 670
Repairing Clear Plastic
I was wondering if anyone had suggestions for repair. I was considering using epoxy but I fear how ugly the outcome will be. I also thought of cutting square and using black epoxy or bondo since I don't need it clear it doesn't interfere with sight of the gauges. I'd love to buy a replacement however Not possible unless I'm lucky enough to find on on ebay. For Yamaha GTS1000
Ideas?
rotten is offline   Reply With Quote
Old 03-20-2012, 11:51 AM   #2
pdxthmper
pdxthmper's Avatar
Oddometer: 408
epoxy will turn yellow, unless its uv stablized. Clear packing tape?
KTM 990 ADV MAKING GROWN MEN ACT LIKE HOOLIGANS
XR 650"L"
pdxthmper is offline   Reply With Quote
Old 03-20-2012, 11:53 AM   #3
P B G
Oddometer: 10,001
If you can remove the piece, I'd get some plaster, a double layer sheet pan, some clear thermoplastic, and I would pour out the cover, pop out the plaster, heat and vacuum new plastic over it.
It may be a bit optically abherant depending on the quality of plastic you use.
If you repaired that corner with epoxy/bondo etc. and then masked over what you did need to see and shot the whole thing black, it'd probably look pretty nice.
Old 03-20-2012, 01:40 PM   #4
rotten OP
LOST AGAIN
rotten's Avatar
Oddometer: 670
What I was thinking good idea to spray out rest.
Old 03-20-2012, 02:52 PM   #5
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 5,001
no ideas on repairing that. Anything will look like shit unless you replace it......Sorry just the honest truth
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Old 03-20-2012, 03:40 PM   #6
sparkymcgee
sparkymcgee's Avatar
Oddometer: 337
$94 bucks to replace I think...
http://www.yamahapartshouse.com/?gcl...00AE_-_1993%29
2008 VFR800
2012 Super Ténéré
sparkymcgee is offline   Reply With Quote
Old 03-22-2012, 09:02 AM   #7
rotten OP
LOST AGAIN
rotten's Avatar
Oddometer: 670
Originally Posted by bunghole View Post
Holy S**T I have looked at several OEM suppliers including calling Yamaha everyone of them reports out of stock or no longer available. I'm calling on this one!
Old 03-22-2012, 09:03 AM   #8
rotten OP
LOST AGAIN
rotten's Avatar
Oddometer: 670
No problem with that! I agree I was just looking for lesser degrees of shit..
Old 03-22-2012, 10:40 AM   #9
sparkymcgee
Oddometer: 337
Wow! I just googled Yamaha OEM and checked the first link. Must have got super lucky. I hope they have it. Good luck.
2008 VFR800
2012 Super Ténéré
Times are GMT -7.   It's 02:21 PM.
