Old 03-22-2012, 09:08 AM   #1
ericrat OP
Oddometer: 1,203
K75 Question
I am working on my wifes '91 K75RT, about 50,000 miles . If it was MY bike, I would just plough right into it, but since it is HER bike, I figured I better double check myself with the wise denizens here.
She has had trouble with stalling at stop lights. Presumably when warmed up. Also reports increased use of the "choke" for starting and needing to leave it on longer than in the past. Fuel and air filters were replaced last year, inside of the tank is spotless.
I don't know if it has ever had a valve check and adjustment. I am going to do this first.
Valve adjustment questions:
I am planning on making the tool detailed here: http://www.ibmwr.org/ktech/k100-8v-adjust-tool.pdf . Anyone have a better suggestion? I don't see that anyone sells the tool, i.e. Cycleworks, etc. It appears the "holder" could easily be made out of aluminum. How about the prying tool? I have some 1/4 inch 6061 plate that would be perfect to cut out with the jig saw. Too soft?
It appears the valve shims are 29mm. I don't have a dealer near me. Can I use Kawasaki shims? If I use KLR parts will the world explode?
Is there really no way to check dynamic timing? The Clymer procedure with a dial indicator is rather... two strokish.
Lastly, outside of double checking vacuum lines, etc any other suggestions for a stalling bike that runs fine at speed?
Eric
ericrat is online now   Reply With Quote
Old 03-22-2012, 09:37 AM   #2
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,341
I had similar problems with my k75 years ago and it ended up being the throttle posistion sensor was out of adjustment. I cant remember the procedure but it only takes about 5 minutes.
I think I still have a K bike manual out in the garage if you cant find it on the net.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 03-22-2012, 09:47 AM   #3
Paul Mihalka
Old Fart
Paul Mihalka's Avatar
Oddometer: 877
Check the rubber crankcase breather hose. If split, it would do just that.
Paul Mihalka is offline   Reply With Quote
Old 03-22-2012, 09:50 AM   #4
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,180
Check the cam lobe clearance first as it may be OK.
These engines hold adjustment very well and for a long time... Gotta '91 K75s.
OldPete is offline   Reply With Quote
Old 03-22-2012, 01:43 PM   #5
Zagando
BMW uber alles!
Zagando's Avatar
Oddometer: 1,132
Tiny little Z-shaped hose kind of between the battery and airbox; they get old and brittle and thus crack easily.
Btw, there's a guy who makes and sells the valve adjustment tools a lot cheaper than BMW's; do some searching (BMWMOA site or the IBMWR site should turn up his name and contact info) if you ever need a set.
Good luck with sorting her out but hopefully it is something really simple as others have pointed out.
=Zagando=
2003 Honda Ruckus "Rucca"
ex: '94 K75S "Berlina" '92 R100GSPD
'85 K100RS '73 R75/5 '65 R60/2
Zagando is offline   Reply With Quote
Old 03-22-2012, 06:12 PM   #6
bmwrench
Oddometer: 2,134
The bike is probably running lean. This can be caused by air leaks, as others have suggested, throttle bodies out of synch (if one cylinder has lower vaccum, there's no way for these bikes to compensate), low fuel pressure, or the need for an idle mixture adjustment.
The K75 doesn't have a TPS; it has a switch which causes injection duration to drop off when the throttle is closed while decellerating and another switch which causes more injection duration at 3/4 throttle and up.
You don't need the picking/prying tool at all to remove valve adjustment shims. The best tool for this job is a blow-gun. Put the tip of the blow-gun into the slot in the lifter bucket and pull the trigger. It'll pop the shim out.
bmwrench is offline   Reply With Quote
Old 03-22-2012, 09:51 PM   #7
ericrat OP
Oddometer: 1,203
Sure enough
You guys are great. Sure enough, the hose is cracked on the backside where it is dificult to see. Replacement is on the way.
I will check valves. If they need adjustment I will tackle the method.
Eric
Old 03-23-2012, 07:16 PM   #8
Tripletreat
Oddometer: 581
blow gun?
If you can blow the shim out with air pressure, how does one insert the replacement?
For all we know, this may all be just a dream; we come, we go like the ripples in a stream.
Tripletreat is online now   Reply With Quote
Old 03-23-2012, 07:30 PM   #9
bmwrench
Oddometer: 2,134
I may have led you astray; you do need the tool that opens the valve slightly, as well as the tool that holds it open. Once the valve bucket is pushed away from the camshaft, you can pop the shim out with air. BMW supplied a bent set of needle-nose pliers to R&R shims, which didn't work very well. The replacement shim slips in, then the other tools are removed.
Old 04-02-2012, 01:59 PM   #10
ericrat OP
Oddometer: 1,203
Confirmed
Breather hose received and installed, no more hot stalls.
Thanks everyone!
Eric
Times are GMT -7.   It's 03:20 PM.
