Old 04-27-2005, 06:38 PM   #1
irlsanders OP
Panamaniac
irlsanders's Avatar
Oddometer: 559
KLR Electrical Gurus?
I'm making plans to do some electrical upgrades to my 2003 KLR650, as follows :
New Electrex G451 Stator and Regulator/Rectifier (400 watts at 2000 rpm)
Upgraded headlight harness, feeding HID conversion
Power outlet in the left side panel for battery charging or jumpstarting
Power outlets at the bars for a five-way volt/temp meter, heated vest,
,GPS , ipod, and a yet to be determined bike-to-bike comm system.
Heated Grips
Louder horn
My questions are :
Can the stock wiring harness harness all this draw?
What devices require switches and/or relays and fuses? What ratings?
If many relays and fuses are needed, where do they all go?
Is there such a thing as multiple relays in a single housing?
What connectors to use - Molex, spades, bullets?
What is a soild state relay? How reliable?
http://www.comagination.com/relay-kit-motorcycle.htm
Am i leaving out any other cool mods?
Thanks in advance for any advice.
Irl Sanders - KI6APE
Los Angeles, CA
KLR650, FZ1
irlsanders is offline   Reply With Quote
Old 04-27-2005, 07:02 PM   #2
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
Yes there are such things as "multiple relays in a single housing" but I'd advise you to use single relays - all of the same type as presently used on your bike. Why? Because it means you only have one type for relay - they can be swaped around to find a fualt. If you have more than one type of relay you will have a fault where the relay is the only one of that type you have. Keep them all the same and seperate. Might be more money but it is a lot less frustration!
Solid state relays don't have a 'points' type contact - they use a semiconduuctor to do that part of the job. They should be more reliable. They are also more expensive, will fail totaly if overloaded (think a short to the frame) and harder to get in the never never. Some old fashioned relays can be pulled apart and cleaned if you are desperate to get them going so you can get home, you cannot do that with a soild state relay.
Don't think - cool - think "Less is more, less is more" Hell it is a KLR not a crotch rocket, pan earth tourer or lowrideing crusier.
Regards Frank Warner
motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S
http://www.geocities.com/fwarner_au/
Frank Warner is offline   Reply With Quote
Old 04-27-2005, 07:06 PM   #3
irlsanders OP
Panamaniac
irlsanders's Avatar
Oddometer: 559
Good point about individual and identical relays, Frank.
Thanks. I am planning on riding it to Panama.
Maybe not "pan-earth", but pan-peninsular, at least!
Los Angeles, CA
KLR650, FZ1
Old 04-27-2005, 07:26 PM   #4
Frank Warner
Traveller
Oddometer: 6,593
I'd not do the HID conversion. You should not be riding at night - you'll miss the views. Spend the money on panniers, fuel and/or beer.
For power outlets at the bars I'd have one each for
heated vest,
GPS and
ipod.
You may like to put the heated vest outlet under the seat near your thigh to keep the lead shorter. This would also do for the battery charging .. but not jump starting - you need something capable of 100 amps for that.
I'd hard wire the volt/temp meter and a yet to be determined bike-to-bike comm system.
Old 04-27-2005, 08:47 PM   #5
irlsanders OP
Panamaniac
irlsanders's Avatar
Oddometer: 559
I commute pretty often at night, and have gotten off a trail far later than expected, and better lighting seems worthwhile for those times.
Are any sockets rated for a jump, ir should that only ever be doen straight to the battery terminals?
Los Angeles, CA
KLR650, FZ1
Old 04-27-2005, 11:21 PM   #6
fixer
KLR-riding cheap bastard
fixer's Avatar
Oddometer: 7,439
Anderson Power Poles. the large versions are used for QD jump cables on wreckers and some cop cars. also used for reciever mount winches. there's a smaller version that should work well for jumping a bike. i have a 1KW genny that uses them for jumping/boosting batteries.
Sit tall in the saddle, Hold your head up high
Keep your eyes fixed where the trail meets the sky
And live like you ain't afraid to die
And don't be scared, just enjoy your ride.
"... in my version of Heaven you get all your dogs back." Mista Vern
"Old dogs don't die, they just wait for you in another place." Twilight Error
I'll show you a place, high on a desert plain, where the streets have no name.
fixer is offline   Reply With Quote
Times are GMT -7.   It's 02:43 PM.
