Old 03-24-2012, 05:10 PM   #1
Strongwater OP
Strongwater's Avatar
Oddometer: 23
1975 R75/6 box of parts..
started thread as a poll by mistake . . . can't figure out how to edit to change it not to be a poll. http://advrider.com/forums/showthread.php?t=769703
Long story short got this:
Missing at least:
rear subframe keys/locks ignition switch handlebars handlebar mounts steering damper, knob left rider footpeg right and left control perches rear light lens spring clips for front headlight exhaust pipe gasket front axle 1975+ choke lever/assembly throttle assembly air filter voltage regulator starter wire
brake cables
clutch cable
no title
Have been able to get a bunch of above parts from a friend, a fellow BMW enthusiast.
There is a Zundapp, a Hoske /2 Tank and a Belgian Police R69S in this picture:
I have been buying parts as time and $ permits.
starting with the front brake Master Cylinder:
Yeah, I know, UGLY! I'm committed to trying to re-use everything I can for now.
more to come.
"It's life Jim. But not as we know it."
"Hey, easy man, I've got a beverage here."
1988 FLHTP - Caddilac pearl white road sofa. 1975 R75/6 - in boxes.
Strongwater is offline   Reply With Quote
Old 03-24-2012, 05:37 PM   #2
Strongwater OP
Oddometer: 23
forks...
Ok, I have a front brake perch on the way, and a front axle that works. time to think about triple tree.
Pretty dirty, dried up grease encrusted triple trees.
Wait a min - this guy has a question.
After a thorough scrubbing in laquer thinner, (the forks, not the kid!)
Good enough. . . gotta find time for assembling front end. Still working on getting a title.
Old 03-24-2012, 05:43 PM   #3
wmax351
Oddometer: 740
Looks fun. I did one of those, but a '71 R75/5.
Title should just be a matter of inspection at the DMV or Highway Patrol office. Its easy on the old bikes that have sat since 1980.
wmax351 is online now   Reply With Quote
Old 03-24-2012, 05:48 PM   #4
Foot dragger
beat up ex flat tracker
Foot dragger's Avatar
Oddometer: 6,924
Most of that will buff right out,Settle in for some fun,the devil is in the details.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-24-2012, 06:17 PM   #5
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 3,470
You have a nice project ahead of you. All the parts you're missing are readily found and not that expensive via IBMWR, EBay, etc, etc....
[QUOTE
QUOTE]
Makes me sad seeing such rare machines sitting ......
http://jupiterhack.blogspot.com
Living proof you shouldn't play with matches
Old 03-24-2012, 10:17 PM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 4,003
Don't feel bad. Mine started as a crate of parts 38 years ago and it's still a work-in-progress. You'll finish eventually.
'73 R60/5 Toaster
Old 03-25-2012, 06:34 AM   #7
Strongwater OP
Oddometer: 23
Thanks everyone for the encouragement. I know this is going to take a while . . .
BMWHacker - i know what you mean, maybe someday they'll get the attention they deserve, but one can only do so many projects at a time . . .
Next update in a week or two . . .
Old 03-25-2012, 05:26 PM   #8
Strongwater OP
Oddometer: 23
Surprise, fixed two minor frame cracks
If I recall correctly . . . this is pretty common to see cracks like this:
Went and had them welded up . . . had to go back because he didn't successfully repair one of them.
Ground down and a little primer to keep any rust away:
I keep telling myself I'll get the main front end components together one of these weekends. I'll be sure to post pictures when I do. . . .
Old 03-26-2012, 11:57 PM   #9
knary
sunshine and puppies
knary's Avatar
Oddometer: 28,982
Go Jane Go - Analog Jane and her three chamber heart
www.scottconary.com | Oil & Piston : Motorcycle paintings and prints | The Punk's Bike
knary is offline   Reply With Quote
Old 04-28-2012, 09:11 AM   #10
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,238
bmwblake is offline   Reply With Quote
Old 04-28-2012, 05:05 PM   #11
Hawk Medicine
Coyote's Brother
Oddometer: 3,299
Don't worry, those gussets will probably crack again.
Plate them with 1/4 plate steel and they'll never crack again and your bike will handle a lot better.
JAMHIK!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Times are GMT -7.   It's 10:13 PM.
