Old 03-25-2012, 08:24 PM   #1
matteo OP
HPM
matteo's Avatar
Oddometer: 498
Stuck Piston - help
I have a R51/3 engine that I am tearing apart. The engine is the same as the /2 engines. One of the pistons is stuck in the cylinder. The engine does not turn over. I got one of the cylinders off, but the other has the piston completely stuck.
I can unbolt the cylinder from the case and turn the crank, but again the piston will not move within the cylinder.
I tried soaking it with some penetrating oil for a couple of hours. I also applied heat to the cylinder (got it to the point it was too hot to touch), but absolutely no luck. I tapped the cylinder lightly with a mallet to see if I can get it to break loose, but it did not work.
Any suggestions?
matteo is offline   Reply With Quote
Old 03-25-2012, 08:49 PM   #2
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 44,982
I know a guy who freed one like that by bolting the head on, pouring a half cup of penetrating oil down the plug hole, then chucking an air line to the plug hole and letting it sit with about 25 psi on it. The next morning he heard a muted "pffft" as the loosened piston made its way down the bore.
There may be better ways, but it was effective and safe.
Hedge36 is offline   Reply With Quote
Old 03-25-2012, 08:54 PM   #3
elite-less
As above, so below
elite-less's Avatar
Oddometer: 540
I used this simple tool to remove the stuck piston on my r75. I tapped the metal bar for a threaded rod and bolted it to the head. Double nutted the threaded rod and wrenched away. Popped the piston free in a few moments.
Not sure how the head is on a /3... but you might glean an idea from this.
IMG_3854
Slash 5 Revive
elite-less screwed with this post 03-25-2012 at 09:02 PM
elite-less is offline   Reply With Quote
Old 03-25-2012, 09:33 PM   #4
knary
sunshine and puppies
knary's Avatar
Oddometer: 29,413
IMG_3854
That cylinder is the prettiest shade of rust.
Artist, Father, Etc | Oil & Piston
Go Jane Go - Analog Jane and her three chamber heart
Goodbye Toolfan
knary is offline   Reply With Quote
Old 03-25-2012, 10:01 PM   #5
fishkens
Further...
Oddometer: 5,147
I hear it never sleeps.
fishkens is offline   Reply With Quote
Old 03-26-2012, 09:14 AM   #6
mykill
odd
mykill's Avatar
Oddometer: 1,162
My buddy has used Coca cola successfully in stuck Hondas. You need to be more patient than a couple hours. I like the sound of the penetrating oil and compressed air trick.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 03-26-2012, 09:18 PM   #7
matteo OP
HPM
matteo's Avatar
Oddometer: 498
IMG_3854
Thanks. I'll try a similar setup.
Old 03-26-2012, 09:58 PM   #8
knary
knary's Avatar
Oddometer: 29,413
Like my hunger for doughnuts.
Goodbye Toolfan
Times are GMT -7.   It's 11:24 AM.
