Old 03-25-2012, 09:10 PM   #1
lockyv7 OP
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,065
R100GS Exhaust Weight
Anyone know the Difference between the Weight of a standard R100GS exhaust system and a system like this from Sibenrock. Will i save much.
Cheers Locky.
lockyv7 is offline   Reply With Quote
Old 03-25-2012, 09:31 PM   #2
walkingbear
walkingbear's Avatar
Oddometer: 3,602
Cheers Locky.
It will lighten you wallet for sure.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is online now   Reply With Quote
Old 03-26-2012, 02:14 AM   #3
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,621
Have you had a look on Motobins, or Motor Works web sites to check other exhausts? The Keihan brand is made very well and is cheaper than Staintune.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me screwed with this post 03-26-2012 at 02:45 AM
gsd4me is offline   Reply With Quote
Old 03-26-2012, 03:32 AM   #4
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,065
I may end up just replaceing the collector box with a 'Y' section and building a alloy or stainless can in the style like the system Sibenrock sells, i am looking at mounting at a certain angle and height to work in with a set of Panniers i have built. Just interested in the weight i would save.
I have a new set of the Keihan Torpedo style stainless mufflers ready to fit on a 60/5.
Old 03-26-2012, 05:13 AM   #5
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,701
About 3.5 kg is easily doable without resorting to exotic material or high noise levels.
I kept the junction box for performance and noise supression
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 03-26-2012, 06:57 AM   #6
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,065
Thanks, thats a start, a bit here and there all helps.
Old 03-26-2012, 07:02 AM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,577
According to the weights in the parts fiche, your stock system should weigh 21 pounds. Almost 10 kilos.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 03-26-2012 at 10:19 AM
Old 03-26-2012, 07:59 AM   #8
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,834
with the "Y" pipe you will loose a little bit of low end torque.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-26-2012, 10:10 AM   #9
Cigars&Scotch
My eyes are up here
Cigars&Scotch's Avatar
Oddometer: 1,858
I just received a Siebenrock exhaust kit on Friday. It is still in the box. Let me see what the weight of it is.
Mike
"Why don't you buy some flea collars for your ankles so the ants wont climb up you leg and bite your candy ass!!!" Kennyanc 07 H.Springs
38 BMW R71 w/sidecar Kung Fu version
77 BMW R90S Huh ?
90 BMW R100GS/PD "At last!"
NRA Life Member, Trout Unlimited Life Member
Drink till I'm Drunk Life Member
Cigars&Scotch is offline   Reply With Quote
Old 03-26-2012, 07:06 PM   #10
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,515
When I did the refresh of my old R80 G/S I replaced the stock exhaust with a Keihan. I did weigh it. It's in my old thread somewhere. I recall weighing the headers, collector, and muffler separately.
Tom
Infracaninophile is offline   Reply With Quote
Old 03-27-2012, 07:02 AM   #11
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,701
Best Kg/$ for me was a valeo starter and lighter battery.
Tossing the glass headlight and the brass speedo for a plastic headlight unit from Bursons Auto and a plastic instrument from VDO took care of another 1.2 kg
Old 03-27-2012, 06:01 PM   #12
Cigars&Scotch
My eyes are up here
Oddometer: 1,858
Came in a little over 11lbs. I am going to try to put it o this weekend
Mike
77 BMW R90S Huh ?
Old 03-28-2012, 02:20 AM   #13
lockyv7 OP
lockyv7's Avatar
Oddometer: 1,065
Thanks guys, i think i can get rid of a little weight with the different exhaust, starter and battery. From there i will just ride it for a while to think about what i think my need are going to be.
Chers Locky.
Old 03-28-2012, 02:39 AM   #14
advNZer?
advNZer?'s Avatar
Oddometer: 2,924
Chers Locky.
the collector box will rust out at about the same time the innards of the muffler collapse..i got a y pipe and the local exhaust guy cut my old muffler in half and rebuilt the insides with stainless this time(its got a wee bit more bark too)
aka BMWST?
advNZer? is online now   Reply With Quote
Old 03-28-2012, 07:47 AM   #15
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,701
http://www.musket.co.nz/musket.asp
These guys are in Taranaki and make a lighter replica at reasonable cost.
My OEM unit rused out in 18 month from new.
It was a dead heat between the skin and the internals.
The Musket has been doing duty for 7 years and is still going strong.
No junction bioxes
Times are GMT -7.   It's 10:29 PM.
