Old 03-26-2012, 09:02 AM   #1
n8mojo OP
Oddometer: 76
Third gear issue 71 R75/5
Hey Old Cools, I have a question that maybe some folks that have been around the airhead transmissions for a while can help with.
My '71 shifts great up and down from all gears, EXCEPT 2nd to 3rd. I'd say 75% of the time (perhaps less so when the bike is cold), the transmission doesn't engage very smoothly. It doesn't grind, but sort of rattles and I can feel in the shift lever. It's not super alarming or horrible sounding, but I want to make sure I'm not approaching some kind of failure.
I changed the transmission oil recently, and noticed a decent dab of soft fuzz around the drain plug, but I don't know when the last change was. According to the last owner, and the odometer, the bike now has 30k. I replaced the oil with Valvoline 80w-90. I have not adjusted the clutch since I got the bike.
I also noticed a description of a similar problem in the 5 united forums about 8 years ago here http://groups.yahoo.com/group/5united/message/22178. Both of his bikes were also '71.
The bike stays in gear fine once there, and once in a while I get a nice clunk when shifting into 3rd, but nothing like the other gears. It's a bit unnerving and unsatisfying hitting 3rd, so I thought I'd check here.
Nate
n8mojo screwed with this post 03-26-2012 at 01:53 PM
n8mojo is offline   Reply With Quote
Old 03-26-2012, 09:33 AM   #2
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,044
Nate,
The first (and cheapest) thing to do is to check that your clutch is adjusted in per the factory method to the factory specifications....
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 03-26-2012, 10:46 AM   #3
supershaft
because I can
Oddometer: 9,116
Chances are you need a new dog plate and your shifter fork adjusted.
Old 03-26-2012, 05:23 PM   #4
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,285
The 2-3 shift moves both forks, while the other shifts only move one. Normally this isn't even noticeable, but that might be at the root of the problem. If one of them (probably the 3-4 fork) is out of adjustment you'll get some difficulty.
Unfortunately, the trans has to come apart for that to be adjusted.
Does 4th seem to engage too eagerly?
Old 03-30-2012, 10:31 PM   #5
n8mojo OP
Oddometer: 76
Got out for a good ride today, and noticed that if I preload the shifter it is much less likely to have difficulty engaging. Makes all gear shifts a bit smoother actually.
I can't really say it's eager to get into 4th, If my memory is serving me correctly, it does seem 3rd requires a bit longer of a shift "throw" before engaging. Or perhaps it just feels that way because it's not that confident going in.
Was actually hoping for an "oh ya, that's an airhead" but looks like I *might* have trouble on the way. I'm going to try to learn to shift it smoother and keep my eyes/ears on it. I've only had this bike since November.
Nate
Old 03-31-2012, 06:01 PM   #6
Cam3512
Cam from NJ
Oddometer: 39
My '71 does the EXACT same thing. I need to put some more "toe" into the 2-3 shift than the others, not always a smooth "clunk". No issues on down-shift.
Cam
'67 Guzzi Stornello Scrambler
'74 Guzzi V7 Sport
'78 Guzzi 850 LeMans
'14 Guzzi V7 Special
Cam3512 is offline   Reply With Quote
Old 03-31-2012, 08:34 PM   #7
n8mojo OP
Oddometer: 76
Well that makes 4 of us, if I count the guy that had the same problem on 2 of his '71s from 5united.
Old 04-01-2013, 09:07 AM   #8
n8mojo OP
Oddometer: 76
I just finally learned to work around it by adjusting how I shift. If I'm careful, it engages perfectly. I guess every bike has it's personality and maybe we just need to work with their quirks. A blip, then release, then a quick shift up, a little voodoo, and it's all good :)
Nate
Old 04-01-2013, 02:11 PM   #9
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,150
If it seems to rattle or clunk into 2nd or 3rd that may not be abnormal. Have you tried preloading the shift lever when you shift? I wouldn't worry about repairs til it starts jumping out of gear...
--Bill
'73 R60/5 Toaster
Times are GMT -7.   It's 08:01 PM.
