Old 04-06-2012, 07:23 AM   #16
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,959
HiYa Blake,....... Can't wait to see her all shined up and running.............
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly".......
Boojum is offline   Reply With Quote
Old 04-06-2012, 09:27 AM   #17
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,629
[QUOTE=bmwblake;18353130a friend that was hanging out had used this method.[/quote]
I can't imagine that actually working for him unless his flywheel was already about to fall off.
mucky rear main seal
So, were you able to get the dang phillips screws off the oil pump cover? If I ever design a motorcycle, there'll be no screw (impact) drivers allowed except on the carburetors.
crazydrummerdude is offline   Reply With Quote
Old 04-06-2012, 11:05 AM   #18
bmwblake OP
upside down parker
bmwblake's Avatar
Oddometer: 3,274
in his defense, he did said that he doubled the license plate over when using it in this fashion.
i haven't attempted to remove the oil pump cover yet. i wanted to clean the area first. i began that work last night and it's going to take a few more sessions of scrubbing before i can see metal all around.
i hope i have an easier time than you did with the oil pump cover. i read your thread and enjoyed your use of oxy/acy torch to get the bolts out.
i placed a parts order early today for some replacement bolts for the clutch carrier as well as parts for the front end. i doubt i'll get much done this weekend but will be back to scrubbing monday evening.
bmwblake is offline   Reply With Quote
Old 04-07-2012, 05:32 AM   #19
rudolf35
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
Wicked Oil pump cover screws
When you are ready to remove the oil pump cover screws use a impact driver, the manual hammer kind. When I took mine loose the loosened right up without killing the slots and any >#%^%#} words.
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Old 04-15-2012, 06:59 AM   #20
bmwblake OP
upside down parker
bmwblake's Avatar
Oddometer: 3,274
oil pump cover screws were no problem. got the oil pump seal and the rear main seal replaced friday night and reassembled the clutch. the new bolts for the clutch carrier were allen head types and much easier to deal with.
in this pic things are back together. you can see joe's bloody thumb. i forget how that happened.
next i tackled the oil pan gasket. you can see there was a fair amount of sludge in the pan. i cleaned the screen and have a new gasket that will be going on hopefully today.
Old 04-15-2012, 10:25 AM   #21
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Full marks for creative use of sludge in order to show a condition to viewers.
datchew is offline   Reply With Quote
Old 04-16-2012, 08:59 AM   #22
bmwblake OP
upside down parker
bmwblake's Avatar
Oddometer: 3,274
sometimes art is worth suffering for.
Old 04-16-2012, 09:34 AM   #23
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,703
On the headlight bucket, those holes can be welded up. The big hole just cut a piece of metal to fill the hole then weld it in place. Might not be perfect once you grind down the excess, but that's what bondo is for. really just time, it would be pretty easy to do.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 04-16-2012, 10:47 AM   #24
bmwblake OP
upside down parker
bmwblake's Avatar
Oddometer: 3,274
i forgot to mention that i picked up a used bucket with the switch and all internals included. i was able to get it for cheaper than sourcing all the parts i needed for the ignition switch/cover/etc.
Old 04-17-2012, 07:00 PM   #25
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,813
.....speaking of impact phillips... I am re-doing a Yamaha XS650 with my son, and the clutch on that guy has BIG phillips head screws (most would replace with allens), and since I don't have a hit-it-with-a-hammer impact, I improvised with my $39 Home Depot air impact wrench... I drove the nearest-fit socket onto the top of the big phillips 'driver, and used the air impact while pushing down hard....worked slick as snot on a doorknob......
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 04-30-2012, 09:22 AM   #26
bmwblake OP
upside down parker
bmwblake's Avatar
Oddometer: 3,274
this weekend i made a lot of progress and found a good bit of unhappy news.
it seems that someone forgot to put in a wrist pin circlip on one side of the right piston. any thoughts on repair methods would be appreciated.
i'm not sure if it's related but there's also a good bit of slip in the connecting rod on that side.
in other news, i was able to get the front end apart and remove the steering head bearings and races. i welded beads on the races but they didn't contract enough to fall out, so i added enough material to the welds to get a punch through from the opposite side and was then able to drive them out.
bucket and wiring off:
so now i'm down to the frame and need to determine what i'm going to do for paint, etc.
on a side note, while cleaning up the bottom of the center stand with a grinder to fill in some holes, i managed to hit my left index finger with the flap wheel. it now looks eerily similar to the gouge in the right cylinder.
safety third. i'm renewed my policy on wearing gloves while grinding.
Old 04-30-2012, 01:53 PM   #27
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
Cool resto! Is the blue framer in the background a Montessa Cota 247 Trials bike per chance?
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 04-30-2012, 02:50 PM   #28
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,901
Looks to my eye like you will need to bore that cylinder out to the next oversize... given the pitting and scoring.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo screwed with this post 05-10-2012 at 02:19 PM
Solo Lobo is offline   Reply With Quote
Old 04-30-2012, 03:26 PM   #29
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,517
Boring to next oversize for the cylinders will be the minimum I believe. It may need taking to the second size. Those pits look pretty deep. What is the line we see in the bottom of the cylinder? The circlip was completely missing? Those pits were caused by water I think. If saving the cylinders by boring is possible they will have to have new, or another, set of pistons. You might do better with another pair of cylinders all together.
---Albert Einstein
Old 04-30-2012, 03:34 PM   #30
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,517
About your comment, "i'm not sure if it's related but there's also a good bit of slip in the connecting rod on that side." Do you mean the rod big end seems loose? After this much investigation and all the damage you have already found you should take the rods out. They can be checked for size at a machine shop and when reinstalled use new bolts and new big end bearings. When they are out you will be able to see the condition of the crank at the rod journals at least.
You need the special rod bolt tool to remove them.
Everything is related. Was water in that cylinder? What does the other side look like? If water got in the lower end of the engine there may be damage to the crank. you need to check this.
---Albert Einstein
Times are GMT -7.   It's 11:13 AM.
