Old 03-27-2012, 06:14 AM   #1
oldroadie OP
Two wheel addict
Oddometer: 467
/5 speedometer test
Anyone have a easy test for the cable. No needle movement except from vibration on yesterday's first test ride, and we all know the mess that getting to the input is inside the headlight bucket.
oldroadie is offline   Reply With Quote
Old 03-27-2012, 07:47 AM   #2
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
Maybe take it off the speedo side and see if it is twirling when you ride...
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 03-27-2012, 08:35 AM   #3
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,191
If you remove the cable from the transmission end and spin it, you won't know if it's the cable or speedo if still nothing happens. I'd think there's no way around it, the best test is removing the cable from the speedo end and try to rotate it. If it won't, then most likely it's good. Or, start up the bike on the center stand, put it in fourth and watch for the turning end.
I'm sure cables break, but it seems more often to be the gauge.
Old 03-27-2012, 01:30 PM   #4
oldroadie OP
Two wheel addict
Oddometer: 467
A trip into the headlight bucket reveals the last eight inches of the cable to be broken off. Cool, maybe a new cable and that's all she needs <:-)
Old 03-27-2012, 03:52 PM   #5
east high
east high's Avatar
Oddometer: 955
In my case it was the gauge that broke the cable. The gauge seized up which stopped one end of the cable from turning while the other end kept going. You might want to bench test the gauge before heading back out on the road.
'71 r75/5
east high is offline   Reply With Quote
Old 03-28-2012, 10:50 AM   #6
Wirespokes
Wirespokes's Avatar
Oddometer: 8,191
Try turning the input to the speedo counter-clockwise. That's its normal direction of rotation, though I'm sure if it's jammed, it won't turn either direction.
Old 03-28-2012, 11:14 AM   #7
oldroadie OP
Two wheel addict
Oddometer: 467
Feelin' pretty lucky here, the cable spins freely and the needle blipped to 10 mph...
Times are GMT -7.   It's 02:44 PM.
