03-27-2012, 04:56 PM
#1 |
Two Wheeled Addict
Oddometer: 5,247
somethin went
Ridin home to Santa Cruz and pulled off in Scotts Valley. Pulled up to the light and the clutch didn't disengage with the lever. Then the oil pressure light came on. Pushed it to the side of the road and now im headed to get my truck/trailer. Oil level seemed okay, coolant is unchanged, and clutch had fluid still. Ideas?
Speed bumps never seem to make me go any faster |
03-27-2012, 05:11 PM
#2 |
More Ride, Less Google
Oddometer: 5,752
Burn it right where it sits. These bikes are evil, ya know.
2003 Kawasaki KLR650 "Reality" 1993 Ducati 900SS "L'evento" |
03-27-2012, 05:23 PM
#3 |
Two Wheeled Addict
Oddometer: 5,247
Yup. That's what the BMW guys all say.
03-27-2012, 05:40 PM
#4 |
Unbunch yer panties!
Oddometer: 1,106
So the clutch didn't disengage when you pulled the lever in...did you hit neutral or stop in gear?
'Cause if you stopped in gear, and it stalled, the oil light would go on.... I vote --optimistically, I know-- for a simple clutch failure of some sort. Let us know... S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. |
03-27-2012, 05:42 PM
#5 |
KOTW 2010 Finisher
Oddometer: 3,007
When you pull in the clutcj, does it feel normal? Does it come to the grip like normal, have proper tension, etc? I cant relate the clutch not disengaging to the oil system...
Brents347 Truckee, CA. 07 Yamaha R6 07 KTM 950 Super Enduro 04 KTM 250exc- plated two-stroke |
03-27-2012, 05:44 PM
#6 |
Oddometer: 5,752
Sounds to me like the slave went and the oil light was just a coincidence.
03-27-2012, 05:53 PM
#7 |
Dans le doute...gaz!
Oddometer: 1,723
I'd agree with the clutch slave that went.
but you did change your clutch plates last month. Could it be related? I have a spare clutch slave. If you'd like, come on by. If you need help, let me know as well.
The race is long and, in the end, it's only with yourself...
03-27-2012, 07:09 PM
#8 |
Two Wheeled Addict
Oddometer: 5,247
With the bike in neutral I am getting a rattle and low pressure indicator light (As if I needed the light when I can hear the rattle)
03-27-2012, 07:11 PM
#9 |
Oddometer: 1,106
Hmmmm......
03-27-2012, 07:17 PM
#10 |
oot & aboot
Oddometer: 25,819
Clutch jet clogged for a while?
Sorry Qwik
www.motogeek.com |
03-27-2012, 07:19 PM
#11 |
Two Wheeled Addict
Oddometer: 5,247
And of course its pourin rain and I dont have a garage.
03-27-2012, 07:25 PM
#12 |
Oddometer: 281
03-27-2012, 07:40 PM
#13 |
Two Wheeled Addict
Oddometer: 5,247
May end up at My Old place or Bikyto's house to check it.
03-27-2012, 07:59 PM
#14 |
Oddometer: 1,723
yes Qwik. give me a call if you want to bring it over.
03-27-2012, 08:05 PM
#15 |
Two Wheeled Addict
Oddometer: 5,247
Thanks. I will. Hoping the rain stops instead so I can do it here.
