Old 03-27-2012, 05:20 PM   #1
OhioAirhead OP
OhioAirhead's Avatar
Oddometer: 69
Removing the Cylinders on an R90S
I am attempting to remove the cylinders on my '76 R90S in order to have them bored. The problem is, they are stuck on with Yamabond or some equivalent and won't budge. Does anyone know any tricks to getting them off?
OhioAirhead is offline   Reply With Quote
Old 03-27-2012, 05:38 PM   #2
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,358
Crowbar. Slowly, pry all around the cylinder. Work it SLOWLY.
Sometimes it's necessary to re-bore ... but if you don't absolutely have to I wouldn't. Hone, new rings and go. Prices and maintenance go up for one over's. Just my opinion of course.
Good luck.
Fred * '85 R80RT G/Sified * '73 R75/5 LWB
"Simple" with a Goal of "Ludite"
Beater is offline   Reply With Quote
Old 03-27-2012, 05:44 PM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,524
A couple years ago when I was working on the pistons for my R90/6 all I could find was second over size. Nobody had 1st over size. Of course the S bike uses a different piston I think but I did think this was strange.
There is a 3M product that is sprayed on sealing compounds and frees them. the only place I've every seen it is in boat stores, West Marine. Maybe check on line or something. It's a spray on. Boats use heavy sealing compounds for sea-cocks that go through the hull.
---Albert Einstein
Old 03-27-2012, 06:18 PM   #4
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,735
Make a cylinder and head puller tool. 1/4 or 3/8" x2" steel, M8 nut on the valve cover stud, M10 nuts behind the tool on the studs. Use it to pull the heads and/or cylinders off. If you are just pulling the heads, take off the cyl head nuts @ 12 and 6. If you need to pull the cylinders, leave the two head nuts on.
'73 R60/5 Toaster
Old 03-27-2012, 06:34 PM   #5
JonnyCash
turd polisher
Oddometer: 1,589
^Those center valve cover studs seem to pull out on their own, much less under this torture. I wouldn't do that. I have made some wooden wedges to go between the engine case and the first set of cooling fins. I really like the way wedges can exert a great deal of force, and not chowder things up. Also the spray product mentioned above is called "De-Bond", and it works great, but I don't think you'll need it.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 03-28-2012, 10:22 AM   #6
chasbmw
Oddometer: 2,255
use a rubber mallet.
Charles
1971 Commando Fastback
Old 03-28-2012, 10:49 AM   #7
Bill Harris
Oddometer: 7,735
Modeled after BMW tool No. 209 thrust bridge, it rarely strips the center bolt. If the center bolt goes, it needed to be repaired anyway.
Wedges, crowbars and mallets on the fins are not good on fins.
'73 R60/5 Toaster
Old 03-28-2012, 11:33 AM   #8
supershaft
because I can
Oddometer: 9,116
+1
Old 03-28-2012, 11:53 AM   #9
mykill
odd
mykill's Avatar
Oddometer: 1,166
+2. Hitting the barrels will induce enough wiggle to break the seal free. If you aren't comfortable hitting the fins hit the exhaust or intake.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 03-28-2012, 04:55 PM   #10
OhioAirhead OP
Oddometer: 69
I finally got them off. I was being a bit too timid with them the first round. Thanks for the replies.
Old 03-28-2012, 05:25 PM   #11
danedg
Horizontally Opposed
Oddometer: 6,644
danedg is offline   Reply With Quote
Times are GMT -7.   It's 07:12 AM.
