Old 03-28-2012, 03:08 AM   #1
MaraBiker OP
Vozi Miško!
MaraBiker's Avatar
Oddometer: 97
). Does anyone recognizes this Boyer Bransen ignition
I found this used Boyer electronic ignition that was strip off from R60/7 (same as mine). Does anyone recognizes this series, because this ignition is some different from the one on Motobins. I presume it may be quite old. I have already send inquiry for additional information to the seller.
http://www.ebay.com/itm/170811837235...84.m1438.l2649
1978. BMW R60/7
http://www.youtube.com/watch?v=2rMVGtDBqwk
MaraBiker is offline   Reply With Quote
Old 03-28-2012, 04:01 AM   #2
PaulRS
Dutch fool
Oddometer: 801
Old, very old.
Probably one of the first BB sets.
I used them once, didn't like it.
P.S. Seller states; Die Teile sind teilweise 35 Jahre alt und gebraucht!
35 year old, used parts.
Paul.
Geht net, gibbet net.
PaulRS is offline   Reply With Quote
Old 03-28-2012, 04:47 AM   #3
MaraBiker OP
Vozi Miško!
MaraBiker's Avatar
Oddometer: 97
Thanks for info.
1978. BMW R60/7
Old 03-28-2012, 10:20 AM   #4
chasbmw
Oddometer: 2,253
its an old basic BB ignition, I would assume that the big box in the photo is a pair of coils with the police equipment radio interference reducing cover, but thats a bit of a guess.
I used lots of Boyers and liked them, and fitted one to my R80 about 33 years ago, but I would not expect one that old to be working properly.
Charles
Charles
1971 Commando Fastback
Old 03-28-2012, 12:21 PM   #5
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
I had the identical Boyer system in my R90/6 from about 1988 until 2005 and it lived up to it's reputation 100%.
It worked perfectly, good starting down to less than 20deg, and it cured the engines pinging with regular gas. In fact, I ended up selling it to another Airhead and I presume that it's still working.
Great system.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 03-28-2012, 12:35 PM   #6
Kai Ju
Kai Ju's Avatar
Oddometer: 1,868
I just installed one on my '77 R100/7.
Engine runs great but became a little hard to start in lower temps, i.e. 40's F, until I slightly retarded the timing.
pm me for a PDF of the installation instructions I got from BB if you go ahead and buy it.
They tell you to route the ground wire down into the front cover through the diode board grommet. I curled my harness up on the left side, in front of the left coil and used the coil mount bolt as the ground. The same one that BMW uses, btw.
Mounted the box to the rear of the coils against the frame with a rubber block and beefy zip tie.
Looks like all the parts are there, but I don't know what the bigger box is for. Caveat emptor, since it also says: Laufleisting unbekannt, which means that the seller doesn't know whether it actually works...........
Kai Ju screwed with this post 03-28-2012 at 01:04 PM
Kai Ju is online now   Reply With Quote
Old 03-28-2012, 02:22 PM   #7
MaraBiker OP
Vozi Miško!
MaraBiker's Avatar
Oddometer: 97
I'll keep an eye on this. But I think that I am going for the new one from Motobins. New=I know it's works.
1978. BMW R60/7
Old 03-28-2012, 07:18 PM   #8
bmwrench
Oddometer: 2,131
Why go to Great Britain for a Boyer? Many vendors in the states sell them.
bmwrench is offline   Reply With Quote
Old 03-28-2012, 11:48 PM   #9
Kai Ju
Kai Ju's Avatar
Oddometer: 1,868
Shipping cost.
Old 03-29-2012, 01:26 AM   #10
MaraBiker OP
Vozi Miško!
MaraBiker's Avatar
Oddometer: 97
Shipping cost.
1978. BMW R60/7
Old 03-29-2012, 02:57 PM   #11
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
'cos the buyer is in Herzegovina?
caponerd is offline   Reply With Quote
Old 03-29-2012, 05:53 PM   #12
bmwrench
Oddometer: 2,131
Whoops.
Old 03-30-2012, 01:24 AM   #13
chasbmw
Oddometer: 2,253
Mara,
If you go for the microdigital, remember to fit 5000 ohm resistance plug caps as made by NGK.
The earthing of boyers is fairly critical. Boyers used to use the coil earth, but the later instructions are to use the (removed) condensor attachment point. I would follow the instructions!
Charles
Charles
Old 03-30-2012, 11:22 AM   #14
MaraBiker OP
Vozi Miško!
MaraBiker's Avatar
Oddometer: 97
Yes, I live far far away
And chasbmw thanks for the info.
1978. BMW R60/7
Old 03-30-2012, 12:47 PM   #15
Kai Ju
Kai Ju's Avatar
Oddometer: 1,868
Originally Posted by chasbmw View Post
Mara,
Charles
Can you speak from a bad experience using the coil/frame ground ? I went that route because the grommet to get through to the condensor mount was so hard that I couldn't get the wire through it. That's when I started looking for an alternate ground.
So far so good.
Times are GMT -7.   It's 06:44 AM.
