Old 03-28-2012, 01:39 PM   #1
Dakota62 OP
Prime of Senility
Oddometer: 56
R80 Freeway buzz...
Still being new to this bike (R80RT) I was wondering if you could tell me if mine is typical of the brand and model. My bike vibrates up to around 3500-4000rpm and then up to 5000rpm I have what is best described as a buzz in the handlebars and pegs. Neither is annoying and the bike runs well but I haven't been in the saddle 2-3 hours at a time either yet. If I have the bike on the center stand and rev it up to 4-5000 I have the same buzz so it's not drive line related and maybe that's what they do.
Dakota62 is offline   Reply With Quote
Old 03-28-2012, 03:13 PM   #2
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,752
check to see if the carbs are synchronized
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-28-2012, 03:23 PM   #3
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,994
Actually I'd say you do need to synch the carbs.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 03-28-2012, 03:52 PM   #4
supershaft
because I can
Oddometer: 9,116
Also check your engine mount nuts. 56ftlb I believe? Somewhere right in there. I find them loose ALL the time. Carb sync and timing light check for double image. That's about the best you can do without taking the engine apart. They always vibrate most right around/under 4000 rpm.
That is unless it is something else like a broken frame or something but I doubt it.
supershaft screwed with this post 03-28-2012 at 03:59 PM
Old 03-28-2012, 04:09 PM   #5
Dakota62 OP
Prime of Senility
Oddometer: 56
Thanks for the info, timing is good with no double images. I'll borrow a sync tool and look at the carbs this weekend.
Old 03-28-2012, 06:39 PM   #6
lulu
Oddometer: 95
I don't think it's unusual. My r80/7 does it too, it slightly buzzes until ~ 3,800 rpms in 5th gear, then the mirrors get all clear. At first I investigated it, cleaned the carbs, replaced the diaphragms, balanced the carbs, tried points instead of electronic ignition. It did nothing, so now 4,0000 rpms is the "standard" cruising rpm.
lulu is offline   Reply With Quote
Times are GMT -7.   It's 05:55 AM.
