Old 03-30-2012, 10:33 AM   #1
lake_harley OP
Oddometer: 687
2-Stroke Pipe Question
Does the exhaust system on a 2-Stroke ever need to be cleaned out? I'm tinkering with a couple F7 175 Kawasaki enduros ('74 and '75 if I recall correctly from the titles). One of the pipes that I have off seems a lot lighter than the other and just wonder if they build up deposits, similar to the combustion chamber, that should be cleaned out? If yes, then how or what do you do or use to clean them?
I've had a few 2-stroke bikes over the years, but none that were this "mature", and I never kept them all that long.
Thanks, in advance.
Lynn
lake_harley is offline   Reply With Quote
Old 03-30-2012, 10:38 AM   #2
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,374
Stick a torch in and let her rip... Burn it out
JeffS77 is offline   Reply With Quote
Old 03-30-2012, 10:55 AM   #3
lake_harley OP
Oddometer: 687
Hmmm. Propane, Oxy/Acetylene or?? Since I haven't done this before, will it "light off" and continue to burn and then the ashes can be tapped out?
Lynn
Old 03-30-2012, 12:28 PM   #4
gloud
Oddometer: 158
Yes they need to be cleaned out if they are that old. Any torch should get them going do it outside as it will stink. You can also use oven cleaner I have been told but you need to be careful of the lye.
gloud is offline   Reply With Quote
Old 03-30-2012, 12:50 PM   #5
brendonb11
brendonb11's Avatar
Oddometer: 186
absolutely they need to be cleaned out!
Torch and scrape (if you can get a brush in there). Some older models have baffles in the end of the pipes that you can yank out as well...
brendonb11 is online now   Reply With Quote
Old 03-30-2012, 01:19 PM   #6
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Yank the baffle (if you can) clean it. I like to heat the pipe and stick a broken cable in a drill,insert cable in pipe (after heating/cooling) and let the cable knock as much carbon loose as possible. Do that from both ends if possible. Empty the debris and repeat.
you don't see luggage racks on a hearse..........act accordingly
Old 03-30-2012, 11:37 PM   #7
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
It will do wonders for your bike. However your neighbours will hate you for the tons of smoke you will create.. Just did mine. Oxy torch and compressed air. What an environmental freak show.
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME.
Hunsta is offline   Reply With Quote
Old 03-31-2012, 05:41 AM   #8
lake_harley OP
Oddometer: 687
Sort of a mini flue fire maybe? Now you have me looking forward to it!
Lynn
Old 03-31-2012, 02:28 PM   #9
lake_harley OP
Oddometer: 687
Well, I used a propane torch from the "engine" end of the pipe. Let it burn in that end for quite a while. Got some smoke, but not as dramatic as I had actually hoped for. I wonder, since all of the bikes had been sitting quite a while, could everything sort of dried up that it wasn't all that flamable anymore? This 2-stroke stuff is rather new to me. I did manage to get a layer of soot out of the curved end of the pipe, so I guess at least I did some good. Anyone put any "accelerant" in the pipe, like gas, to get it burning? You're probably thinking now, "Man, I'm glad I'm not his neighbor!"
Lynn
Old 03-31-2012, 03:22 PM   #10
Euromad
Oddometer: 306
Putting gas in the pipe prolly give you an unexpected BANG
you may blow the pipe apart and give yourself a reason for a hearing aid and plastic surgery
Euromad is offline   Reply With Quote
Old 03-31-2012, 07:42 PM   #11
lake_harley OP
Oddometer: 687
Yeah, I'll probably search for dramatic effects elsewhere. Hearing aids and plastic surgery would cut into my motorcycle habit budget too much
Lynn
Old 03-31-2012, 07:45 PM   #12
sieg
sieg's Avatar
Oddometer: 2,880
I just throw them in the trash barrel and light it.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is online now   Reply With Quote
Times are GMT -7.   It's 05:19 PM.
