Old 03-30-2012, 09:11 PM   #1
sigpe57 OP
Oddometer: 342
R80ST Works Performance Shock Orientation
I just received this new shock today.
Which side should be up? Should the black spring be on top or bottom?
Thank you for the reply,
SIG
sigpe57 is offline   Reply With Quote
Old 03-30-2012, 09:21 PM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
My inclination is to put the spring, up, but since it doentt have a reservoir, I would say whichever way fits better. If either way fits fine and the mounting holes dont dictate fitting than I would go with whatever way looked best
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 03-30-2012, 09:45 PM   #3
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,700
I'd go with the way it's pictured.
Bi Tube designs (if it is one) generally work best that way.
It also reults in a slightly lower unsprung weight.
With the 50 lbs unsprung youthe S/T has a few grams ain't going to matter much
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 03-30-2012, 09:52 PM   #4
sigpe57 OP
Oddometer: 342
I checked the R100GS shock. It seems like the spring side is on top. That's way I asked.
Old 03-30-2012, 10:12 PM   #5
supershaft
because I can
Oddometer: 9,116
Is that the preload adjuster on the bottom? If so, it will be easier to get to on the bottom. Plus, less unsprung weight.
Old 03-30-2012, 10:39 PM   #6
sigpe57 OP
Oddometer: 342
The Allen screw is used to adjust rebound.
sigpe57 screwed with this post 03-30-2012 at 10:46 PM
Old 03-30-2012, 10:47 PM   #7
sigpe57 OP
Oddometer: 342
Sig
sigpe57 screwed with this post 03-30-2012 at 11:14 PM
Old 03-31-2012, 06:32 AM   #8
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,569
I prefer putting the cylinder up, shaft down. This way any dirt and water can shed off the top of the seal better, rather than just sitting on top of it. That and the lower unsprung weight, not that it makes that much of difference, just the way it "should" be in my mind.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 03-31-2012, 07:48 AM   #9
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
Well now, now that its on the bike it does look more righter with the spring at the bottom.
Old 03-31-2012, 07:53 AM   #10
Airhead Wrangler
Adios Mexico
Oddometer: 6,569
I like the bigass hex nut for adjusting preload. Better than the knotched rings most companies use.
Old 03-31-2012, 10:17 AM   #11
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 549
Cylinder up, shaft down:
Photobucket
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Old 04-01-2012, 07:41 AM   #12
sigpe57 OP
Oddometer: 342
The steel tracker for a r80st is different than the one goes on a r80g/s. Why did WP use this shock instead of just shorten a r80g/s shock model by 1/2inch?
Old 04-01-2012, 07:53 AM   #13
sigpe57 OP
Oddometer: 342
In the instruction, if the bike is too high, you would turn the adjust nut away from the spring ,make the spring longer, decrease the preloaded and lower the bike. I thought a longer spring would raise the bike height?
Old 04-01-2012, 04:09 PM   #14
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,078
Think about the wording - then delete the part about making the spring longer. What they mean is basically reducing preload by allowing the spring a longer space to reside in. That's "making the spring longer".
Yeah, grammatically it is a little confusing - but it is correct
I like that shock, BTW.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Times are GMT -7.   It's 10:42 PM.
