Old 03-31-2012, 06:43 AM   #1
WESLEY BIERY OP
Oddometer: 3
Question alternative speedo tach set up
Could someone give me some info on speedo /tach setups for an 82 R100 /7 .Mine is rougher than grannys legs. I would use analog or digital I see a lot of different things out there,but would like some first hand knowlege. How do you know the ratios? Any help would be much appreciated. Wes
WESLEY BIERY is offline   Reply With Quote
Old 03-31-2012, 08:20 AM   #2
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,280
Welcome to the forum Wesley!
Are you saying your gauges are trashed? What's wrong with them?
I think there are only a couple of choices in aftermarket gauges, only one of which I recall at the moment - Acewell. I've never gone that route, instead rebuilding the stock ones. But the electronic gauges are small and look good when set up right - and you don't have to worry about matching the final drive ratio because they take the reading off the front wheel like a bicycle speedometer.
It might be possible to graft some other speedometer to your bike, but I have no idea how to tell if it's the correct ratio or not. Our speedos have a number on the dial that tells us which speedo matches which drive, but that's not so with other makes.
How about filling out your profile and letting us know where you hail from? And definitely show us the object of your attention!
Wirespokes is online now   Reply With Quote
Old 04-01-2012, 09:33 AM   #3
batoutoflahonda
Oddometer: 1,386
As mentioned above:
http://www.advrider.com/forums/showthread.php?t=527749
I've also installed the trail tech instruments before and they worked well.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda screwed with this post 04-01-2012 at 09:41 AM
batoutoflahonda is offline   Reply With Quote
Old 04-01-2012, 11:04 AM   #4
WESLEY BIERY OP
Oddometer: 3
Wicked Thanks
The only thing worse than my computer skills are my keyboard skills . I will try to get a picture or two up. I also ride a 95 1100GS and a DRZ400 I've been lurking for yrs. Wes
Old 04-01-2012, 01:19 PM   #5
Wirespokes
Wirespokes's Avatar
Oddometer: 8,280
Glad you unlurked! Sounds a bit like that story of the kid who didn't talk till he was five...
Times are GMT -7.   It's 09:02 AM.
