Old 04-23-2014, 02:39 AM   #1
Tigeritaly OP
Oddometer: 7
new air flows
new conveyors for cooling, they really work
Tigeritaly is offline   Reply With Quote
Old 04-23-2014, 04:25 AM   #2
OrangeV
OrangeV's Avatar
Oddometer: 578
That's a good looking 1190... well done my friend...
75° V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Old 04-23-2014, 04:34 AM   #3
Bigem
Bigem's Avatar
Oddometer: 2,549
What are we cooling?
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is offline   Reply With Quote
Old 04-23-2014, 05:37 AM   #4
Tigeritaly OP
Oddometer: 7
the heat under the seat and between the collector and rear suspension,sorry for my english by gogle translate
Old 04-23-2014, 03:05 PM   #5
jameslawson
Oddometer: 76
where from?
jameslawson is offline   Reply With Quote
Old 04-23-2014, 03:24 PM   #6
strider.deano
Oddometer: 333
Let me see if I understand this.....you're scooping more air back to hit the rear cylinder right?
Concept is good!
Should be cooler when the bike is moving, does it help much when the going gets real slow...5-15 mph?
strider.deano is offline   Reply With Quote
Old 04-23-2014, 04:15 PM   #7
kag
Wander Lust
kag's Avatar
Oddometer: 1,531
The scoop will help, other bikes have used an air scoop to help with cooling with success. Not a cure all but the bike is going to need something and the scoop seems like a good plan.
Where did you purchase it?
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 04-23-2014, 05:33 PM   #8
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 639
At best, isn't that mixing the hot radiator air with whatever ambient is?
At worst, you're directing the hot radiator air to directly under the seat.
I must be missing something.
HeatXfer is offline   Reply With Quote
Old 04-24-2014, 12:16 AM   #9
Tigeritaly OP
Oddometer: 7
the warm air flowing over the radiator air flows, they get fresh air and feed it right on the rear exhaust and moves the air is stagnant, over 30 degrees the seat became hot, I live in Italy near Maranello (home of the ferrari) and in summer it is warm enough
Old 04-24-2014, 07:36 PM   #10
dewaynehasty
Oddometer: 90
where?
I'll try anything! Where did you get them?
dewaynehasty is offline   Reply With Quote
Old 04-25-2014, 12:55 AM   #11
tinwelp
Professional Idiot
Oddometer: 136
Just a wild guess, but I suggest maybe he made them himself? Seems an obvious solution if there's nothing available on the market...
Cheers... Paul
tinwelp is offline   Reply With Quote
Old 04-25-2014, 02:13 AM   #12
jameslawson
Oddometer: 76
As above keen to know where you get them from
Old 04-25-2014, 04:34 AM   #13
Bundu
Oddometer: 634
https://www.youtube.com/watch?v=fwlbaqZAcks
Bundu is offline   Reply With Quote
Old 04-25-2014, 05:32 AM   #14
Bigem
Bigem's Avatar
Oddometer: 2,549
Makes sense. Just had the 'heat proofing' put on the underside of the seat, I reckon its worse on my legs than it was before!!
What are the scoops made of?
Old 04-25-2014, 08:11 AM   #15
ADVill
Oddometer: 607
Hey Wings it's... matte. Unless the guy that designed it is called Matt...
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Times are GMT -7.   It's 07:48 AM.
