Closed Thread
Old 01-01-2012, 08:56 AM   #211
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,496
Laugh
In this situation just leave it in the "Blue" position
Thanks for the business!
Originally Posted by RedRiderofMA View Post
I do have a question about the switch.
It's not a problem now but in the warmer weather as I start out on a ride it maybe below 85, or even riding in the hill towns the temp may change from higher elevation to lower elevation, so the temp can vary from below 85 to over 85 rapidly, do I have to stop and flick the switch every time the temp goes up and down over 85 ?
Thanks again for a very cool product.
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline
Old 01-01-2012, 02:52 PM   #212
gpracer171
Kodak Courage
gpracer171's Avatar
Oddometer: 361
So if it is over 85 degrees, leave it on red, if below place it on blue? I now understand what it is doing, but can you tell me practically how/when to use what setting? Also, if I am using the wrong setting, who will the bike act/manifest this problem?
Originally Posted by HighTechCoonass View Post
Good question to go over again.....
Blue position- this setting it tells the ECU that the air tempature is 36 deg cooler than it is. The ECU enriches the fuel (on increase throttle movement and decrease throttle movement only)
Red position- this setting it tells the ECU that the air tempature is 18 deg cooler than it is. The ECU enriches the fuel (on throttle movement only)
Less enrichment is needed when air temperature is above 85 deg F.
Steady state throttle- the O2 sensor controls enrichment!
Mike
2010 BWM F800GS
2007 Triumph Dayton 675
2013 Husqvarna Nuda
If you are not moving forward, you are falling behind...
gpracer171 is offline
Old 01-01-2012, 04:10 PM   #213
nytrashman
old and in the way
Oddometer: 593
took my second ride today after installing the power controller and i'm still loving it.
nytrashman is offline
Old 01-01-2012, 07:06 PM   #214
Spinalcracker
former redriderofma
Spinalcracker's Avatar
Oddometer: 1,096
Great day for a ride in Western Massachusetts today.
I was out for about 2 hours and the controller is amazing. I was looking for a steep gravel road that I always have to feather the crap out of the clutch to have control going up. Today it was muddy and slippery but with the controller I was able to do a slow climb in 1st and second without all the feathering. It was very smooth.
I have a little popping with decelerating and down shifting but I would say it was reduced by about 85%. I also have the Leo Vance carbon fiber slip on. The popping never bothered me, I kind of liked it.
Unless we change direction, we are likely to end up where we are headed.
It's county Fair time in New England
TET MA to NC
Vermont Covered Bridges
Spinalcracker is offline
Old 01-01-2012, 07:29 PM   #215
Spinalcracker
former redriderofma
Oddometer: 1,096
My bike is a 2010
TET MA to NC
Old 01-01-2012, 07:37 PM   #216
HighTechCoonass OP
Oddometer: 2,496
Over 85 Deg F? set on red
Under 85 Deg F? set on blue
Left on Blue....with outside air temp 90 deg F- you now have a "Accelerator Plug" or a "Booster Plug" .... IMO over compensation..... this level of enrichment not needed.
Left on Red... with outside air temp 50 deg F - the throttle response will be a little less jerky but not as bad as factory setting.
Old 01-02-2012, 04:45 AM   #217
Steveman
Steveman's Avatar
Oddometer: 471
Can anyone explain to a F8 newbie what this power controller exactly does? And does it work on 2011 European models? Pricing and shipment to Europe? Whats the effect on overall power?
Many thanks
Steve
Steveman is offline
Old 01-02-2012, 06:47 AM   #218
gpracer171
Kodak Courage
gpracer171's Avatar
Oddometer: 361
Perfect
Perfect, thank you.
Mike
2010 BWM F800GS
2013 Husqvarna Nuda
Old 01-02-2012, 10:00 AM   #219
itsatdm
itsatdm's Avatar
Oddometer: 4,979
All these devices work on the same principle but first you need to know how the BMW ECU works. Booster plug long version has a decent explanation:http://www.boosterplug.com/shop/cms-24.html.
Next there are hundreds of pages of discussion on all three. Go to the twins sticky thread titled "'thread index and links" and scroll down to the appropriate threads.
The short version is the ECU has the ability to change fuel mixture to address riding conditions. That change is directed by electrical current from sensors located on various componants of the bike.
The devices change the current from the air temp sensor to cause it to direct the ECU to supply a richer air fuel mixture then it otherwise would.
itsatdm is offline
Old 01-02-2012, 05:29 PM   #220
HighTechCoonass OP
Oddometer: 2,496
Laugh
grab a beer, pull up a chair, and read up!
http://advrider.com/forums/showthread.php?t=709574
Many thanks
Steve
Old 01-03-2012, 12:37 AM   #221
Steveman
Steveman's Avatar
Oddometer: 471
Thanks guys, took me a while to read all that stuff. Got a severe headache now
Steveman is offline
Old 01-03-2012, 09:19 AM   #222
markymcd
markymcd's Avatar
Oddometer: 887
Ordered mine yesterday... at least I think I did. Either that or some lucky guy got my paypal money.
My solution to the snatchy throttle for off road was to run a front sprocket 1 tooth smaller and do most of the technical riding in 2nd gear and use 1st for crawling. Worked just great although you do lose some top end and fuel efficiency on the road and I switch the sprocket back for super long road trips.
It would be great if this was a viable solution to switching sprockets.
cheers,
Mark
www.adventuredecals.com
markymcd is offline
Old 01-03-2012, 10:15 AM   #223
HighTechCoonass OP
Oddometer: 2,496
Laugh
Got it! going in the mail tonight!
cheers,
Mark
Old 01-05-2012, 06:09 PM   #224
HighTechCoonass OP
Oddometer: 2,496
Laugh
your welcome.... all orders shipped .. still have a few in stock!!
Perfect, thank you.
Old 01-10-2012, 02:44 AM   #225
Kiwi Dave
Beemer Boy
Oddometer: 122
Got it in the mail today!
Just got the PC in the mail today. Install in the morning. I'll take the bike for a spin around the town for a quick warm up for something to compare the install of the PC to. Looking forward to this. So is the wife (my pillion).
Just a quick Q&A regarding install. I see where all the wiring harness goes but where would recommend I mount, what I assume is an ambient air temp sensor, the copper tipped thingy?
Cheers,
Kiwi Dave
New Zealand
PS. even with the mayhem of holiday shipping mail backups and all, your box of goodies arrived in just eight days. Sweet!!
Kiwi Dave is offline
Closed Thread
Times are GMT -7.   It's 01:49 AM.
