Closed Thread
Old 01-26-2012, 07:50 PM   #241
jireynolds67
Oddometer: 5
Went for a Test Ride today
I received and installed my new Power Controller yesterday but did not finish doing something else until today, I put the left side fairing back on this afternoon and it was late when I finally took it out for a test ride. When I started it, I noticed the idle seemed smoother and instead of dying a couple times, which usually happens, it kept running. Running in the lower gears was also smoother. I headed out for the open road and rode out over fifty miles before turning around and heading back home. As I was coming back into Las Vegas, the traffic was heavy and had slowed down a bit. I was in sixth gear and looked at both the speedometer and tachometer. I was doing about 55 and the RPM's was less than 3000. My 1150RTP had never before ran smoothly in sixth gear at any speed less than around 70, yet here it was, running like that was completely normal. The traffic speed picked up a bit and I opened the throttle a bit and the acceleration was immediately and smooth. Best ninety dollars I have ever spent, when adding something to my 2003 R1150RTP!
I keep track of my gasoline mileage on a spread sheet, so shortly, I will know if the mileage has increased, decreased or stayed the same. When I have filled up a few more times, I will have a good comparison of the mileage before and after installing the Power Controller and I will let you know the results. Jim
jireynolds67 screwed with this post 01-26-2012 at 07:53 PM Reason: Put a capital C in Controller
jireynolds67 is offline
Old 01-27-2012, 10:05 PM   #242
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by jireynolds67 View Post
I read the whole thread and did not find another response to the question about one for a 1150. I have a 2003 R1150RTP and would like to install one of your Power Controllers on it.
Originally Posted by HighTechCoonass View Post
My PC will work on the 1150 - and it comes with a money back guarantee. Thanks!
Not that anyone asked me, but a courtesy response say. The -36C setting is too much temperature offset.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 01-29-2012, 06:53 PM   #243
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,503
Laugh
it is -36 deg F. not -36 deg C . Thanks....I made notes in my original post! Thanks Poolside!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline
Old 01-29-2012, 06:57 PM   #244
HighTechCoonass OP
Oddometer: 2,503
Laugh
Please PM me also when you paypal! Thanks mates!
Old 02-06-2012, 04:15 PM   #245
MotrSklz
MotrSklz's Avatar
Oddometer: 129
Order placed!!
Looking forward to trying this little beauty out... more importantly, since it's going on my wife's F650GS, she is looking forward to the snatchy throttle being taken care of
Cheers
MotrSklz
MotrSklz is offline
Old 02-07-2012, 05:04 PM   #246
mreich77
GUNIVY
Oddometer: 162
Order placed via pay pal at 4:14.....
Order shipped at 4:55!!! Now that's some sweet service. Thanks!
mreich77 is offline
Old 02-19-2012, 03:02 AM   #247
Steveman
Steveman's Avatar
Oddometer: 471
has anyone installed in on F8GS European specs? Are these bikes different?
Steveman is offline
Old 02-19-2012, 07:34 PM   #248
veloct
veloct's Avatar
Oddometer: 41
Switch Mounting Options
Just curious if anyone has used a handlebar-mount switch for easier access? I was thinking of something like THIS
I used to dress up as a Pirate, now I dress like a Spaceman!
Harley FXR > 1150 GSA > F800GS
veloct is offline
Old 02-23-2012, 03:58 AM   #249
RobertAmsterdam
www.twbastards.com
RobertAmsterdam's Avatar
Oddometer: 194
Why use your design and not this one?
http://www.novitech.nl/modelleneng.html
okay there is a switch what are the facts about this being better, its twice the priceof a Recyclizer
2010 F800GS + TWBASTARD TW200
www.twbastards.com
RobertAmsterdam is offline
Old 02-23-2012, 07:44 AM   #250
HighTechCoonass OP
Oddometer: 2,503
Laugh
Recyclizer does not have an external temperature sensor...(it is built into the unit). My Power Controller has an External temperature sensor- that is better... on an 800 the temperature gets very hot under the airbox cover. I tested this with a digital thermometer.... It is cheaper to build the internal...but in the long run when it heats up the effect will be null.
The switch.... One does not need -36 F (-20 deg c) offset to the ECU when the air temperature is above 85 deg F. Only -18 deg F (10 deg c) is needed.
IMO - There is no better tuning device on the market today - and the cost is under $100.
l
HighTechCoonass screwed with this post 02-23-2012 at 07:56 AM
Old 02-23-2012, 07:50 AM   #251
HighTechCoonass OP
Oddometer: 2,503
Laugh
The switch i use is a waterproof single pole double throw switch (in case one would like to change it)
position 1 - -36 deg F air box temperature offset to the ECU (blue position)
position 2 - -18 deg F air box temperature offset to the ECU (red position)
Old 02-23-2012, 08:04 PM   #252
kdumbril
Oddometer: 4
G650x
Can you confirm it works on the g650's
kdumbril is offline
Old 02-25-2012, 08:30 AM   #253
HighTechCoonass OP
Oddometer: 2,503
Laugh
yeap.... all of my research says yes!
I have 5 in stock now! ready to ship!!
Old 02-27-2012, 02:22 AM   #254
Moptop
Moptop's Avatar
Oddometer: 78
Money send
Just ordered my Power Controller.
Moptop is offline
Old 02-27-2012, 04:04 PM   #255
HighTechCoonass OP
Oddometer: 2,503
Wink
Going in the mail tonight!! Thanks!
Closed Thread
Times are GMT -7.   It's 02:31 PM.
