Old 04-02-2012, 10:24 AM   #1
Colorado Uli OP
Motociclista Non Elegante
Colorado Uli's Avatar
Oddometer: 2,550
950 SE Regulator/Rectifier SOLUTION
FINALLY! We have a non-OEM solution for the old reg/rec issue regarding heat-caused failures.
Rick's Motorsports Electronics have built us a SE specific mosfet-based unit that does away with the sensitive (and high heat generating) diodes.
I gave them the specs and they went right to work building what I believe is a great solution. (I've gone through two OEM units already) A few days ago I received it in the mail and bolted it onto the old beast. Installation was super simple as everything matched right up to the existing mounting point.
Rick though it better to change the connection configuration a bit: Now, instead of using the white OEM connector to plug the reg/rec into the positive side of things, Rick's unit wires directly to the positive battery terminal -- 30 amp fuse is already wired into this changed configuration.
So, it comes with the standard brown KTM plug for direct connection to the stator (them there three yellow wires), a battery terminal connector to negative, and one battery connector to positive (again, this one has the fuse built in).
What do you do with the now-unused white positive connector (two red/white wires going into it)? I just covered the openings with electrical tape and tucked it out of the way.
After yesterday's five hour trial run I can report that it's working great.
Where: http://www.ricksmotorsportelectrics.com/index.php
Part number:10-014H
Cost: $150 (vs. about $135 for the OEM unit)
NOTE: I have zero personal or business affiliations with this vendor (other than I gave him the specs and he built and sold me one) and have no financial stakes in his company. I'm only providing the above because it's about time someone made an alternative available to us.
Something, something, something ... in latin.
"Now with more SE then ever!"
Das KTM520
2004 KTM 625 SXC - Sick. Getting better
Colorado Uli screwed with this post 04-02-2012 at 02:20 PM
Colorado Uli is offline   Reply With Quote
Old 04-02-2012, 10:52 AM   #2
Ramv
Ramv's Avatar
Oddometer: 464
Very cool!
I am hoping my single de-cat can is enough to help with the temp, but if not, this seems like the perfect upgrade. I monitor mine using an Advmonster voltage guage, so I can keep track.
'10 Multistrada 1200 Std ('11 - current) for sale
http://advrider.com/forums/showthrea...2#post23383292
'07 Super Enduro 950
'96 KLX250R - kind of street legal
Ramv is offline   Reply With Quote
Old 04-02-2012, 11:01 AM   #3
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,161
I have had one for over a month now and it works great. Plug and play installation.
My voltage went from 14.1 to 14.7v at idle after the swap.
Good guy, good company.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 04-02-2012, 11:09 AM   #4
Navin
Navin's Avatar
Oddometer: 7,652
Ricks is an awesome business, they cured a few hi output Electrosport KTM stator/regulator issues that Electrosport couldn't/wouldn't fix. A+++ vendor.
Navin is online now   Reply With Quote
Old 04-02-2012, 11:09 AM   #5
Colorado Uli OP
Oddometer: 2,550
You got one from them for a SE or Adventure? But then again, they are probably the same except for wire lengths.
Das KTM520
Colorado Uli screwed with this post 04-02-2012 at 04:15 PM
Old 03-30-2013, 10:55 PM   #6
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,832
Question
Whats the difference in RICK's SE & ADV reg rect ?
is it just wire lengths ? if so then ADSV be better to get it located further up front ?
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 04-03-2013, 10:28 PM   #7
nattyMo
Oddometer: 569
Works great on the 950sm and smr as well. I've been running a Ricks VR since last year on my SMR. Replaced two stock VR's, wasn't going to try a 3rd. Thanks for having these built. Mounted mine on the LH side of the airbox to keep it away from the exhaust heat.
nattyMo is offline   Reply With Quote
Old 04-03-2013, 10:35 PM   #8
veetwo _tls
RENOVATIO:
Oddometer: 1,832
i've bought one of the Shindengen FH020AA Regulator/Rectifier kits
http://www.roadstercycle.com/
CHEERS: brett
MY07 950 SER
Old 04-03-2013, 10:47 PM   #9
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,686
Yep, mine is good so far.
traveltoad is offline   Reply With Quote
Old 07-15-2013, 03:55 PM   #10
Colorado Uli OP
Oddometer: 2,550
Update
Just a quick note to let y'all know that my Rick's regulator/rectifier is still running strong in the hot deserts of the southwest after about 15 months.
Das KTM520
Old 07-16-2013, 12:46 AM   #11
mousitsas
mousitsas's Avatar
Oddometer: 2,728
My R/R started playing up at 25,000km.
I relocated it on the nitrogen tank of the rear suspension, so it can be exposed to cool and clean airflow.
Stopped playing up.
Airbox relocation does not tick the box 'cool airflow'.
Old 07-29-2013, 07:07 PM   #12
D K
Oddometer: 466
Ricks Vreg on order after bike left me stranded in Mexico.
Great customer service from them!
'13 EC300 Racing
07 950SE - sold
08 950SE - sold
09 FE570 - sold
D K screwed with this post 07-29-2013 at 07:55 PM
D K is offline   Reply With Quote
Old 07-30-2013, 07:11 AM   #13
wilso122
Oddometer: 183
You probably are but keep that battery on trickle charge if you can whilst you wait, last thing you want is that dying in the mean time
Other than that hows the trip so far?
525 exc rally lite project
950superenduro.com For those who own the best bike!
wilso122 is offline   Reply With Quote
Old 07-30-2013, 10:18 AM   #14
D K
Oddometer: 466
So far so good.
Had 2 massive setbacks, but it's going allright.
I was lucky I was on top of a mountain range and had the luxury of coasting down hill 40kms with the bike deader than a doornail....
Then found a bloke with a truck and now just waiting. I even procured a solar panel to help keep the battery charged, but that's not working so well
Part should be here by friday hopefully, so will have to see how it goes from there.
D
'13 EC300 Racing
07 950SE - sold
08 950SE - sold
09 FE570 - sold
Old 07-30-2013, 07:41 PM   #15
Colorado Uli OP
Oddometer: 2,550
Happy to hear Rick's is being cool to you. Sucks it had to happen in a remote place like that. My last OEM unit died in Utah's desert near Lake Powell -- of course I was all alone. Swore to myself I was never going to let that happen to me again.
Das KTM520
Times are GMT -7.   It's 02:45 PM.
