03-06-2013, 11:22 AM
#571 |
Oddometer: 2
Michael,
Thank you very much for the helpful info....I'll give it another shot and see how it goes. Didn't mean to be negative; just got a bit frustrated (and I wasn't thinking I'd have to use the alternate means of attachment on the rear--though obviously I will). On the tankbag adaptor, I'd actually tried threading the clips through, but I'd attached them to loops on the bottom of the bag, rather than the straps themselves. Your solution seems like it would work better. Thanks |
03-06-2013, 11:26 AM
#572 | |
Recoverin speedfreak
Oddometer: 540
Just want you to be 100% happy with your gear. Cheers, Michael
Go big, or go home. BritKit LLC US Distributor of Kriega Motorcycle Luggage www.kriega.us / Facebook / vendors thread |
03-06-2013, 12:19 PM
#573 | |
Oddometer: 540
Congrats on settling your luggage dilemma. You sure did your homework, so I'm convinced you won't regret opting for the Overlander 30. Thanks for trusting Kriega! Before I throw down with my recommendation, I have a few questions for, if you don't mind:
![]() Kube 4: ![]() Stash: ![]() Kube Pocket on R25: ![]() So, if hydration is a key function for you, the R20 might be the way to go. However, based on what you need to carry, it does look like you would need the R25's 25-liter (with Kriega gear, the number in the name always denotes the capacity in liters) size. The heavier duty R25 harness might also be good too. Usually I recommend the smaller R15 /R20 for off-road riding, but - based on the pack you have been using - I am sure you would be fine with the R25. More than fine in fact - the way Kriega packs distribute the weight and enable total freedom of movement, not to mention easy on and off, will be a revelation after riding with a hiking backpack! But if you were to go for the R20 for the reasons stated above, I would supplement its 20 liter capacity with either a US-5 or US-10. Probably the 5. Oh yeah! And there's always these if you go for the R20, which is short enough to wear one with. Great for stuff you want to keep very close. R3: ![]() R8 (with removable tool roll): ![]() Let me know your thoughts / comments. Cheers, Michael
Go big, or go home. BritKit LLC US Distributor of Kriega Motorcycle Luggage www.kriega.us / Facebook / vendors thread amanlikemike screwed with this post 03-06-2013 at 12:33 PM |
03-06-2013, 12:20 PM
#574 | |
Oddometer: 540
... And I prefer the term 'enthusiasm' to 'brainwashing'.
03-06-2013, 01:36 PM
#575 |
Aaron S
Oddometer: 6,106
Once again, Michael prooves why he is Mr. Kriega.
03-06-2013, 02:17 PM
#576 |
Oddometer: 540
That's what Mrs. Kriega said!
03-06-2013, 03:57 PM
#577 |
Oddometer: 252
Is there some kind of key ring/clip in the Hydro-3 that I am blind to? Considering I never noticed the strap in my R25 for the hydration bladder (it is just a buckle in mine?), it is entirely possible I just don't see it somewhere
![]() One of the things I liked about my old camelbak was not worrying if my keys were going to randomly fall out while digging around in the pocket. It isn't enough of a concern to go back to it though
02 drz 400s/m 09 Husky wr150 |
03-06-2013, 08:04 PM
#578 |
Oddometer: 829
Ready for the RTW trip;
US10 on the tank.....US20 on the tail and OV30 on the sides............. ![]() ![]() ![]() ![]() It might be better with a US5 on the tank and the US10 on the tail?? It's nice that I have a few options. Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat |
03-06-2013, 08:23 PM
#579 |
Aaron S
Oddometer: 6,106
Is there a bike under there?
03-06-2013, 09:02 PM
#580 |
Oddometer: 829
Yeah............I usually just put the Hodaka inside my US20 and strap it to the back rack of my KTM 640!
Cheers
03-06-2013, 10:32 PM
#581 | |
Befuddled Adventurer
Oddometer: 1,210
The R20 then would be a better choice assuming i could get my goods loaded into it properly. Soooooooooooooo a couple questions. How much room is left in the R20 once a full 3 liter bladder is installed and a 13 X 9 X 1 laptop do you think? Is it a true 6" depth the full length of the pack or does it taper a lot? Another option you mentioned is adding a R3 below the pack, Would this work for someone with a torso measurement (from the top of the hip bone to the top of my trapezoid) of only 17"? If an US 5 is attached, is access to the side zip pocket still possible? I would order the R25 without a doubt for the bomber suspension set-up if it had a hydration sleeve. Why Kriega chose to omit such a basic feature I'm not sure. OK now onto another potential mod of mine of a Kreiga product. Is there any reason why I could not use the sleeve in the R25 for a hydration bladder and then punch a port through the top of the pack for the hydration tube? Tell me why this would be a poor idea? Again thanks for your time.
Cheers, Team FTB ------------------ Team "Fingering The Bean" Looking for the woman that takes the wheel when I'm seeing double. |
03-07-2013, 12:21 AM
#582 |
Oddometer: 443
Since we are all in the mood for sharing, here are some pictures of R25.
My first complaint about it was for lack of pockets and compartments, but I adapted. It's also a bit heavy - 1500g empty. FTB, Here are some pictures to give you an idea of the size. I think the size is just right. 13'' laptop with a pair of gloves for reference. This one will not fit in the sleeve. ![]() With the 2l bladder (puffy one) and a pair of gloves. A lot of room left. There is a hook to tether the bladder or some other load, but everything stays in place when you compress it with outside straps. You can thread the the water hose trough one of the metal rings in the front. Works well enough. A new hole on the top of the pack would be nice, though. ![]() Same load compressed down. ![]() This pack has a thick foam padding in the back (and a sort of plastic spine that gives it rigidity). So you'll get hot wearing it. Really hot if you wear a back protector. Chest harness also restricts air flow and cooling. ![]() Pack hangs pretty low on your back. Depending on your hight it may interfere with aggressive off road riding. I'm 190cm and it's about right.
Balkan Boy screwed with this post 03-07-2013 at 12:33 AM |
03-07-2013, 03:49 AM
#583 |
Oddometer: 273
Hydro 3
Question for those using the Hydro-3 with no addons like the US5 or Kube
In the advertised 1 liter storage space, what are you carrying. I'm just after some real world ideas on what can actually fit in the storage space when the 3 liter bladder is full |
03-07-2013, 05:32 AM
#584 | |
Oddometer: 252
I carry a small pelican case with my gopro batteries and memory cards, keys to my truck, and some snack bars. I can put my gopro in there too and still have some room left for small stuff. I shoved a 30 oz MSR fuel bottle in there before also, but I only had the bladder about 2/3 full. And for shits and giggles, US-5 as a number plate bag. Main purpose was to hold the batteries for my light (they are in the mesh back pocket)
02 drz 400s/m 09 Husky wr150 gots_a_sol screwed with this post 03-07-2013 at 10:27 AM |
03-07-2013, 04:27 PM
#585 | |
Oddometer: 273
I'd be looking to carry a light rainjacket in there. Seems like it should fit going by your post. bill1960 screwed with this post 03-07-2013 at 05:09 PM |
