Old 05-02-2012, 11:35 AM   #46
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,133
Send a message via Skype™ to tagesk
385 mm; does not depend on the preload.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 05-02-2012, 11:58 AM   #47
Jazz62 OP
Oddometer: 628
[TaSK]
Thank you very much.
Jazz62 is online now   Reply With Quote
Old 05-08-2012, 04:03 AM   #48
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,133
Thumb Here you are!
Here you are.
The threading starts right at the opening of the hole.
As you can see the bolt extends a little just as it leaves the threads.
Hope this helps.
[TaSK]
IBA: 33616
Old 05-10-2012, 02:40 AM   #49
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,133
Are you there?
How did it go?
As I was installing mine this morning I noticed that my bolt was a tiny little bit bent.
I noticed because it was hard to get in.
You bolt might also be bent; then you would start to unscrew without problems.
But when the bent part arrives at the "leftmost hole" it gets stuck.
If this is the case for you (too), you need to apply force as you twist it out.
[TaSK]
IBA: 33616
Old 05-10-2012, 05:46 AM   #50
Jazz62 OP
Oddometer: 628
How did it go?[TaSK]
Yes, it finally came out. In my case it appears I had applied too much thread-sealer (loctite 2xx) and the excess was causing problems. Of course I was doing this without removing exhaust so had limited space/force to work with. I think the problem with the excess loctite would not even have been noticeable if the exhaust was removed. My special tools finally got it un-stuck. Special tools in this case were two asparagus knives placed under the bolt head and then slight prying force.
I see your pretty blue Wilbers there in the photo.
I sold the Wilbers set which created this thread just yesterday to a gentleman that wanted to lower his 1150GS.
So my search begins! I can't afford a new front and rear set of shocks so will just get the rear first. The prices are astonishing. Even a Hyperpro with just the remote preload adjuster is almost $900!
I'm waiting to hear a price for similar Wilbers. It's hard for me to justify spending that kind of money on a 12 yr old bike with 65K miles but the stock units are useless.
Old 05-10-2012, 10:46 AM   #51
mcstark
Oilhead convert
mcstark's Avatar
Oddometer: 930
Jazz - If you still have the original shocks, give Sasquatch a holler. He's an inmate on here and does a top-notch job rebuilding/upgrading OEM shocks. I had him revalve and respring the rear shock on my old F650 and it did wonders for the bike. It should only run the price of one new shock.
Here's his website: http://www.sasquatchrider.com/.
His name is Jay.
Regards,
Mark
2003 BMW R1150GS
mcstark is offline   Reply With Quote
Old 05-10-2012, 05:18 PM   #52
Jazz62 OP
Oddometer: 628
His name is Jay.
Thanks Mark - Yeah I've heard about Jay before but I don't want to miss out on any riding having the shocks off the bike. Maybe I missed something in your post but what would be the benefit of having the oem shock revalved and resprung if it's the same cost as a new shock? Or did you mean it's the same cost as a new oem shock?
Old 05-10-2012, 06:20 PM   #53
mcstark
Oilhead convert
mcstark's Avatar
Oddometer: 930
Jazz - The pair should cost what one aftermarket shock would. It was $450 for the rear Showa on my F650. Might be a little more for the 1150 shocks. Jay swapped the spring out to match my riding weight, then swapped the stock internals for all Race Tech components and put a tap on it for nitrogen so it can be serviced again.
Call Jay. He turned my shock around in two days, so I only missed a week of riding.
Regards,
Mark
2003 BMW R1150GS
Old 05-10-2012, 06:36 PM   #54
Jazz62 OP
Oddometer: 628
Ah OK - gotcha. Just sent him an email through his site.
Times are GMT -7.   It's 12:42 PM.
