Old 04-06-2012, 12:40 PM   #1
marcing OP
marcing's Avatar
Oddometer: 75
Revs problem (990 adventure)
Hi All,
I decided to put this problem on this forum as the KTM UK forum has not given me an answer.
Last time I have a problem with a crazy revs.
I start the engine normally. The revs are about 2000 for w while and next goes down to about 1300-1500.
Jump on the bike and start my ride. After a short while I see that if I press the clutch lever the revs were swimming in the range 3500-4000... so controlling the bike during a slow ride was very hard. I had to use a clutch... so I stopped and turned engine off and on... revs 3500-4000.... so tried again and revs back to normal but when started ride it went crazy again.
This was happen first time about 1month ago when I was riding in the rain and cold day...
A couple days later when I used a bike all was ok (good weather).
Last time it happen again... rain and cold again.
I don't know is this a problem during a rain (bad connection somewhere) or it is just coincidence.
Bike has about 30000miles on the clock now... 2006year 990adventure.
Just an update:
I have found that I have a small leak (all is wet) under the left tank from under a fuel pump (I think it is a fuel pump)... But not sure has it got any connection to my problem with revs
marcing screwed with this post 04-06-2012 at 01:05 PM
marcing is offline   Reply With Quote
Old 04-06-2012, 02:04 PM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,676
Sounds like a TPS issue.
Dealer time
Or you need someone with an electric meter (or TuneECU) to check out the adjustment of the Throttle Position Sensors on the throttle bodies.
EDIT
I bet it's water getting into the TPS wiring, maybe at the ECU under the headlight.
Peanuts is offline   Reply With Quote
Old 04-06-2012, 02:54 PM   #3
Oli990
Oli990's Avatar
Oddometer: 88
Try bypassing the clutch switch. I had the same problem and it was a faulty clutch switch.
Oli990 is offline   Reply With Quote
Old 04-07-2012, 03:38 AM   #4
marcing OP
marcing's Avatar
Oddometer: 75
I have found some stories in the Fuel Pump Issues topic and maybe the faulty fuel pump cause this problems... Someone there wrote that the high revs or very low revs has been caused by fuel pump when the fuel level in tank was low..and that how it is on mine now. I have to refuel it and check.
Old 04-08-2012, 11:59 AM   #5
the foolish fellow
UP FOR IT
the foolish fellow's Avatar
Oddometer: 140
TPS -- Check and set this between .54 and .6 ( when engine is warm ).
990 adv
850 Le mans
Gl 1000
X5 3.0d
FE 450 BERG
the foolish fellow is offline   Reply With Quote
Old 04-13-2012, 02:48 AM   #6
marcing OP
marcing's Avatar
Oddometer: 75
Do you mean I have to use TuneEcu software ? sorry but I don't know anything about this so if you can provide some more details.
Old 04-13-2012, 02:50 AM   #7
marcing OP
marcing's Avatar
Oddometer: 75
Dealer time
EDIT
How exactly I can check it with an electric multimeter ?
Old 04-13-2012, 07:46 AM   #8
VG44
VG44's Avatar
Oddometer: 606
Ok, I have a question. My 990 started cutting out around 6K rpms. Bike acts like I cut the fuel switch once it hits 6K. Should I start with the TPS also?
'10 BMW R1200GSA
SmugMug Coupon - Ga3PqQ6TYbYKA
VG44 is offline   Reply With Quote
Old 04-15-2012, 07:34 AM   #9
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
High Revs
Not sure if this applies to your problem,
but one of my 990's has a high rev issue similar to yours
and while I have not found a resolution to it, I have narrowed it down.
It seems that the idle stepper motor is causing the over rev.
When I start the bike it jumps to 3500 + - rpms and after a short time
settles down to normal idle. But when the throttle is bliped it jumps back
up and stays high again settles down.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 04-15-2012, 09:13 AM   #10
Peanuts
Peanuts's Avatar
Oddometer: 1,676
Clean your fuel pump filters.
No need to buy new, remove them and swill about in a jar of fresh petrol, blow dry, swill again in clean petrol, blow dry, refit :)
Smear the tank and O ring in silicon grease to aid fitting.
Old 04-30-2012, 07:14 PM   #11
IBJim
WhoUB?
IBJim's Avatar
Oddometer: 333
Pissed
Max
Max- my 07 is now doing the exact same thing. Please post up if you find a solution (and what have you already ruled out?). I'm gonna check the clutch switch, see if that does it. I dropped some serious money last fall while the local dealer F'd w the (in spec!!) valves and basically stared at the bike for 3 wks. I noticed that I could turn the bike off and on multiple times and it would sometimes reset itself. Am I correct that you can't replace just the stepper motot--you need to replace the throttle bodies too?? This is bullshit!!!
IBJim is offline   Reply With Quote
Old 04-30-2012, 07:20 PM   #12
IBJim
WhoUB?
IBJim's Avatar
Oddometer: 333
I wondered about that. I know that there's a post about, and that I should just search for hours..but can you send a brotha the link??
Old 04-30-2012, 07:31 PM   #13
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Try this link:
http://www.advrider.com/forums/showp...58&postcount=2
AdvGa is offline   Reply With Quote
Old 05-01-2012, 07:42 AM   #14
Oli990
Oli990's Avatar
Oddometer: 88
Sorry I don't have a link. I to replaced my stepper motor because idle speed was going everywhere from 1500rpm - 6000rpm while riding. The bike didn't slow down with the throttle closed
Dealer told me the stepper motor could not be ordered separately so I had to by the entire FI system + work = 1300 euro
With the help of this forum I found a second hand FI system took of the stepper motor and replaced it with mine. No adjustment or calibration necessary. After a while the problem reoccurred. I installed a new TPS and everything was fine again... for a while After al this I bypassed the clutch switch and the problem was solved, for many miles now
Old 05-01-2012, 01:41 PM   #15
IBJim
WhoUB?
IBJim's Avatar
Oddometer: 333
Cool. Does the clutch bypass harm rideability or economy in any way?
Times are GMT -7.   It's 03:35 PM.
