Old 07-26-2014, 07:37 PM   #61
AMAC1680
AMAC1680's Avatar
Oddometer: 771
Congrats you're gonna love it !
Be Big,
AMAC
"We live in a world designed for stupid and we have lawyers to help them"
www.SEGS4VETS.org
Kymco DT-300i
SYM RV200 EVO
Lance "Cali Classic" 125
AMAC1680 is offline   Reply With Quote
Old 07-27-2014, 05:11 AM   #62
klaviator
klaviator's Avatar
Oddometer: 6,444
Great scooter. Congrats!
I ride, Therefore I Am.
klaviator is online now   Reply With Quote
Old 07-28-2014, 11:39 PM   #63
Vertical C
Vertical C's Avatar
Oddometer: 2,785
I just picked up one of these as well. Got it back on the road for under $1500 aussie (about $1400) with 12 months registration so I was happy with that. Only 13000kms but its a bit scrapy looking, but I don't really care. Its pretty fast, I am going to be a hooligan on it.
One thing is that the previous has set the fan to stay on all the time. He said that it was overheating in Brisbane traffic (can be quite hot over 30 degrees C or in the 90s F). But then I notice that the temp gauge doesn't move from the bottom, its winter here now so I expect it to be low especially with the fan running but....
So do the inmates think I will burn out the fan running it all the time?
Should I remove the fan on all the time? I am tempted to put a switch in and just only have it run in summer, that seems cheap and easy. Bit worried about doing that if I don't really have a gauge?
Is the temp gauge the real problem of the fan not coming on, though not sure how he could tell it was overheating if that doesn't work.
What should I check?
Vertical C is offline   Reply With Quote
Old 07-29-2014, 08:07 AM   #64
blugg1
Oddometer: 501
I'm on the SYM forum. As the fan was not designed to run constantly, and if I owned your scooter, I would simply disconnect the fan, then observe your temperature gauge. If it starts running too hot in slow traffic I'd hook the fan back up and reset the control unit to the original factory setting.
I live in the Arizona desert and my fan has yet to come on. Once, going up a 4 mile grade wide open in summer (98F) the temp gauge climbed to the 1/4 mark. Normally it stays just off the cold mark.
Plus, with the fan on constantly could constitute an un-natural drain on the battery.
But do go to the SYM forum; there are real experts there, plus one SYM dealership owner.
2014 Kawasaki 300 Ninja, 2012 SYM HD200 EVO
blugg1 is online now   Reply With Quote
Old 07-29-2014, 08:21 AM   #65
DaBinChe
Oddometer: 1,156
The ceramic coated cylinder is what makes it run cooler. Put it back to factory setup. Change the radiator fluid and keep an eye on the temp gauge.
DaBinChe is offline   Reply With Quote
Old 07-29-2014, 10:53 AM   #66
Birdmove
Birdmove's Avatar
Oddometer: 1,745
My fan will sometimes come on if I'm in heavy traffic, like road construction, and I'm barely moving. In normal riding conditions, it never seems to get hot enough to actuate the fan. It's a 2008 with about 14,000 miles.
Jon in Keaau, Hi. USA
2008 SYM HD200 (wife's ride)
2009 Kymco People 150 and coming soon, another dual sport mc
Birdmove is offline   Reply With Quote
Old 07-29-2014, 01:16 PM   #67
JerryH
Oddometer: 5,069
I have wired a couple of bikes with toggle switches so I could turn the fans on manually, because I felt they did not come on until the engine was already too hot. Turning on the fan at a lower temperature did indeed keep the engine cooler. In the summer in AZ, no engine is going to run too cool no matter what you do to it. I have never seen a cooling system, car or bike, that wasn't marginal at best here. Of course not all places have that problem.
Hopefully the coolant is green ethylene glycol. If it has that OAT or HOAT coolant in it, it will definitely plug up the radiator, and everything else it touches.
Since the HD200 has a carb, it is almost certainly jetted way to lean, which will definitely cause overheating. I don't know what kind of carb it is, but going up one jet size might bring the temperature down.
JerryH is offline   Reply With Quote
Old 07-29-2014, 02:15 PM   #68
blugg1
Oddometer: 501
JerryH wrote: "in the summer in AZ no engine is going to run too cool no matter what you do to it."
Except for the HD200.
My temp gauge gets off the cold mark, but not by much. DaBinChe mentioned the ceramic coated cylinder contributing to cool running. My fan has never come on and this is its second summer. gitsum owned it before me so it may have spent the first summer in New Mexico, which is not much better.
Anyway, he adjusted the carb so it wouldn't be so lean. Which no doubt helps, also.
Old 07-29-2014, 03:13 PM   #69
Vertical C
Vertical C's Avatar
Oddometer: 2,785
thanks all. I might disconnect the fan then see what the gauge does woukd be nice to know if the gauge does work.
I wouldn't actually say that brisbane is as hot as Phoenix ever, at least not in outright temperature. Flushing the radiator might be a good idea as well so ill do that.
I'll ask on the sym boards once I do the above as I will have more information then.
Old 07-29-2014, 05:41 PM   #70
sealsam
Sam...I am.
Oddometer: 1,975
Careful around that plastic. Mine was loose and I found this...
My fix...
Good as new now.
Sam
1150RT R100S KLX250s SymHD200
Southern California from a scooter;
http://advrider.com/forums/showthread.php?t=941261
sealsam is offline   Reply With Quote
Old 07-30-2014, 06:12 AM   #71
sealsam
Sam...I am.
Oddometer: 1,975
Originally Posted by Dabears View Post
Disappointment- only two things that irk me so far (and yes, I will certainly survive). First is the lack of any storage except under the seat. My Vespa only had a glove box, but it was big, and accessible while sitting on the seat. Sunglasses, gloves, maps, earplugs, towels, flashlight, tools, all right there. I put a rainsuit in the SYMs underseat area and can barely crunch my open face helmet in now. Going to have to figure that out.
Second annoyance- I'm having trouble seeing the turn signal indicators when the sun is shining- Even my 30+year old Vespa's indicators are visible in sunlight.
Congratulations on adding to the fleet Dabears!
My HD has an 'audible click' when my turn signals are engaged. Do you not have this? I wonder if this was an add on by the p.o..?? Sure wish my other bikes had this feature!
I agree and would have hoped for some front storage also. I added a Givi Tech 30 tail box that is very handy, but having something up front would be nice.
Best of luck with it!
Sam
Old 07-30-2014, 11:13 AM   #72
Birdmove
Birdmove's Avatar
Oddometer: 1,745
Interesting. I have no problem hearing the turn signals, and seeing the TS dash indicators. Lack of storage? We do have a cargo box on the back of ours. The grocery bag hook is very stout. I haul lots of groceries and such on mine. My complaints about the HD200 are different than yours. Mine are:
1. No kick starter. And, I am starting to have intermittent starting problems. I hit the starter button, and nothing. Possible bad starter relay? But, if I had a kick starter, I wouldn't get stranded. Haven't been stranded yet, but the problem could get worse. Since you can't push start a twist and go scooter..........
2. It should be easier to add coolant to the surge tank. You should not have to get out your tools and go at it for this procedure. There should be a hatch with 2-4 screws you remove for easy access.
Other than those items, I could darn near sell my Toyota Tacoma pickup and use the HD200 for my only transportation. But I have to haul lumber, trash ect too often for that.
Old 07-30-2014, 11:17 AM   #73
Chillis
Land Barge Pilot
Chillis's Avatar
Oddometer: 3,982
Check your brake light switches.
Chillis is offline   Reply With Quote
Old 07-30-2014, 11:31 AM   #74
Birdmove
Birdmove's Avatar
Oddometer: 1,745
The brake lights work. But, when the starting malfunctions, I haven't checked to see if the brake are on or off. Whenever I check the brake lights, which is quite often, they work fine. I have to do the annual state inspection in August. I want to get that done, then plan on replacing the belt and rollers, as the scoots got almost 14,000 miles. Haven't done a belt before, so want to get that inspection sticker first, just in case I end up having to order tools or something. I checked the valves at 8000 miles, and they were perfect. Oil changes are a snap, and I also have a syringe I use when replacing the rear end oil, which is also super easy to do.
Old 07-30-2014, 11:40 AM   #75
blugg1
Oddometer: 501
The grocery bag hook is indeed stout. I have a Sierra Club smallish canvas back pack into which I stuff a 12 pack of soda (heavy) and other smaller items. Never a problem. To augment cargo-schlepping I fastened a medium-sized Seahorse hard case to the back rack (just like a Pelican case, but at about half the price). Pelican and Seahorse cases are waterproof - not that it matters all that much in the desert. Anyway, the case adds to carrying capacity.
I have no audible clicking sound when a turn signal is activated. It may be there, but I can't hear it with or without a helmet. And it is hard to see the blinking light during daylight.
Times are GMT -7.   It's 08:05 AM.
