Old 04-08-2012, 01:23 PM   #1
craftsmanracer OP
craftsmanracer's Avatar
Oddometer: 235
2 stroke experts!
I am completely stumped as to why my old enduro is misbehaving...
It is a 1977 Kawi KE-175 rotary valve, and it has starting issues.
It will sit for a month at a time, and start on one kick, but if I let it sit for less than a day, it will take AT LEAST 50 kicks to start it. It is like it doesnt like being used on a regular basis.
The carb is clean, the plugs are fine, and the gas is fresh. I just removed carbon from the head and gave it a new head gasket, as well as cleaned out the exhaust. The bike also didnt come with a choke, and I removed the oil tank and run a 32:1 premix.
I make sure to shut the gas off when it isnt running.
oh, and it has always done this, even before I did the work to it.
Current fleet: '82 Toyota Pickup 4X4, '99 Suzuki DR650, '97 Yamaha Zuma, '86 sears-craftsman racing lawnmower (guinness world record mower).
craftsmanracer is offline   Reply With Quote
Old 04-08-2012, 09:25 PM   #2
willis 2000
neo-quixote
Oddometer: 3,624
try this
A poorly-sealed bottom end will cause this and other odd symptoms. Remove the carburetor and crank the engine slowly until the cylinder transfer ports are closed by the piston, but the rotary valve is somewhat open. Stick your face into the area previously occupied by the carburetor and blow into the carburetor mounting stub. Listen to where the air is escaping. Coming out the exhaust? Move the piston, your transfer ports are open. It will probably show the LH crank seal needs replaced. Face too big for the carb area? Get a kid, make 'em earn their keep. DAMHIK
willis 2000 is offline   Reply With Quote
Old 06-10-2012, 04:11 PM   #3
dooder
Oddometer: 28
Did you try Willis' advice Craftsmanracer?
Any update?
dooder is offline   Reply With Quote
Old 06-15-2012, 07:27 PM   #4
craftsmanracer OP
Oddometer: 235
Yes! i had a cracked carburetor boot, and extra air was leaking into the engine, causing the air/fuel mix to get all screwed up.
I also think it would start after sitting because it gave the carb time to leak gas into the motor wich "choked" it.
Unfortunately though, 2 days ago, I was doing a very aggressive sprint down a dirt road, and the bike lost power, and wouldn't start up again.
Took it home, and blamo!
So now I got to get a new piston, and probably split the cases to get the pieces of smoked piston out of the crankcase.
Unless anyone else has an idea????
Old 06-16-2012, 03:22 AM   #5
AC Swank
AC Swank's Avatar
Oddometer: 9,641
Running a bit lean there.
Turn the motor over and flush out the bits with kerosene, there is no need to split the cases. All that is going to wash out is pepper sized bits, anything bigger was already blown out the exhaust.
AC Swank is offline   Reply With Quote
Old 06-16-2012, 03:36 PM   #6
craftsmanracer OP
Oddometer: 235
Thanks for the advice! I was scared that I would have to deal with full blown surgery, and disassembling the rotary valve system, wich I am sure needs special tools to do.
So I just take the cylinder off, pour some kerosene in the motor, and turn it back upside-down?
Old 06-16-2012, 10:17 PM   #7
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,064
I'd suggest figuring out why it was running lean, otherwise you'll just end up the same way again.
LasseNC is online now   Reply With Quote
Old 06-16-2012, 10:53 PM   #8
AC Swank
AC Swank's Avatar
Oddometer: 9,641
That's it.
Back in the day, it was normal to remove the head after each race to check the condition of the top of the piston and change it before he hole got too big. Many of us who also rode 2 strokes on the street did the same every other month.
Old 06-17-2012, 09:03 AM   #9
Shocktower
Shocktower's Avatar
Oddometer: 9,474
If I recall the rotory motors need the injector system to lube it correctly, you may have more problems, than you think, I would stick with the stock set up JMHO
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 06-17-2012, 02:15 PM   #10
AC Swank
AC Swank's Avatar
Oddometer: 9,641
Shocktower is correct, rotary systems require the oil injection or say good-by to the bottom end bearings.
Old 06-17-2012, 02:49 PM   #11
craftsmanracer OP
Oddometer: 235
Nope, that is if the bike had injecto-lube, that only came on the bigger bikes, mine has super-lube, wich can be bypassed.
Got a new piston in the mail, I will put it in soon.
I am wondering about the seal behind the magneto being blown out too though, so I was thinking about sealing up the magneto cover so that extra air can't get in there.
I plan on taking marine 5200 sealer and going to town on the thing.
It is a $300 beater bike, so I just need it to run, not be pretty.
Old 06-22-2012, 12:56 AM   #12
willis 2000
neo-quixote
Oddometer: 3,624
I am wondering about the seal behind the magneto being blown out too though, so I was thinking about sealing up the magneto cover so that extra air can't get in.
Don't even try it, the seal is leaking and you'll blow another piston if the seal is not replaced.
Old 06-23-2012, 03:46 AM   #13
AC Swank
AC Swank's Avatar
Oddometer: 9,641
I was kinda hoping he was going to do as he says, he'll be back for more advice.
Old 06-23-2012, 06:26 AM   #14
Shocktower
Shocktower's Avatar
Oddometer: 9,474
Originally Posted by Armchair View Post
I was kinda hoping he was going to do as he says, he'll be back for more Ashtray artwork.
Fixt
'08 KTM 530 EXC
79 RD 400 Daytona
Old 06-23-2012, 06:43 AM   #15
AC Swank
AC Swank's Avatar
Oddometer: 9,641
Fixt
Yes, a blown piston does make a good ash tray.
Times are GMT -7.   It's 09:50 AM.
