Old 04-08-2012, 06:55 PM   #1
DrWez OP
Mad Scientist
Oddometer: 96
2010 GS Adventure Transmission and Final Drive Oil
This question has probably already been posted but I can never find anything with the search function. So can anyone give me some guidance on the proper oil viscosity to use in the transmission and final drive on my 2010 GS Adventure. The manual doesn't have the info and the dealer has given me several answers. I put Amsoil 80W-90 in both today because I thought the dealer said that was ok.
Wes
2010 R1200 GSA, 1976 MotoGuzzi 850 T3
BMW MOA 140210
BMW RA 32150
IBA 56882
DrWez is offline   Reply With Quote
Old 04-08-2012, 07:34 PM   #2
sanjaya_sugiarto
Oddometer: 209
Gear oil 75w-90 GL5 full-synthetics
Most important: GL5 grade oil
Recommended by BMW: Castrol SAF-XO
I myself use Castrol MTX or Motul Gear Competition (both are 75w-140)
sanjaya_sugiarto is offline   Reply With Quote
Old 04-09-2012, 02:48 AM   #3
ATCguy
ATCguy's Avatar
Oddometer: 284
Ummm... ok, even though i've turned my share if wrenches over the years, I realize that I'm still a newbie when it comes to the BMW world and these boxer engines... so I guess I need to be educated.
I'm familiar with the need to occasionally change/refill the final drive oil... but what the hell is transmission oil? What's its purpose, where's the level indicator, and how does one drain and/or refill it?
Tom
AMA - BMW MOA
'07 Honda GL1800A Gold Wing
'14 Ford F-450 PLATINUM
'14 Dutchmen VOLTAGE 3200 5th Wheel Toy Hauler
ATCguy is offline   Reply With Quote
Old 04-09-2012, 03:00 AM   #4
sanjaya_sugiarto
Oddometer: 209
On boxer BMW (R series), the transmission and the engine are separated.
Regarding How-Tos:
- Transmission: http://www.jimvonbaden.com/R1200_24K.html
- FD: http://www.jimvonbaden.com/R1200_Final_Drive.html
Old 04-09-2012, 04:12 AM   #5
ATCguy
ATCguy's Avatar
Oddometer: 284
Interesting... Thanks.
Tom
AMA - BMW MOA
Old 04-09-2012, 04:45 AM   #6
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,861
Lots of good info on the GSpot FAQ Sticky (top of the forum page) also: http://advrider.com/forums/showpost....10&postcount=5
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 04-09-2012, 05:24 AM   #7
klondike1
Nobody in particular
klondike1's Avatar
Oddometer: 481
I use 80w-90 in both. Make sure like said before with the GL 5 rating. Transmission/gearbox oil. Make a funnel with hose on it and fill it thru the side and fill till it starts to come out hole you are filling. Can take a long time to fill if oil is cold. id of hose i had on funnel was about1/4 inch
If you don't know where you're going
any road will get you there!
2009 BMW R1200GSA(Grey Boy)
2007 BMW F800ST(Blue Boy)
www.danieljenkins.ca
klondike1 is offline   Reply With Quote
Old 04-09-2012, 02:53 PM   #8
DrWez OP
Mad Scientist
Oddometer: 96
What is a GL 5 rating? Would Amsoil Gear Lube 80W-90 or Amsoil Severe Gear 75W-90 qualify?
BMW MOA 140210
BMW RA 32150
IBA 56882
Old 04-09-2012, 03:48 PM   #9
BMWRich
BMWRich's Avatar
Oddometer: 1,648
Set-It and Forget-It
Changed annually or @12-15K miles or (when changing tires).....trans and rear end both same oil....
Not a single leak,everyrthing nice an "tight" all in the last 55,000 miles....
Trans fluid looks almost brand new when dumped,rear end slightly darker....
2007 GS Adv
Everybody likes a little ass,..but nobody likes a smartass...
BMWRich is offline   Reply With Quote
Old 04-09-2012, 03:51 PM   #10
Gruesome
Alter Heizer
Gruesome's Avatar
Oddometer: 966
Originally Posted by klondike1 View Post
Make a funnel with hose on it and fill it thru the side and fill till it starts to come out hole you are filling. Can take a long time to fill if oil is cold. id of hose I had on funnel was about1/4 inch
You can fold a funnel from aluminum foil. As I mentioned in another gear oil thread, 'my' dealer still has the previously spec'ed BMW-branded $15/qt oil on the shelves, and that didn't suddenly become unusable just because BMW updated the spec to the $45/qt Castrol. So, to me the easiest seems to be to just go with the BMW branded stuff (which btw does not have the trademark stubbly guy on the label - I was wrong about that.)
Gruesome is offline   Reply With Quote
Times are GMT -7.   It's 08:45 PM.
