Adventure Rider
Welcome, lurker!   Even if you don't post, the system can help you find the good stuff faster if you register.
Register Members Pics Search Today's Posts Mark Forums Read
Old 05-01-2005, 09:38 PM   #1
Guaglione
down-n-out in Mill Valley
Guaglione's Avatar
Oddometer: 2,217
Cry GPS = dead
I left my GPS276c on for an extended period of time, by accident, and now it won't turn on, even with external power attached. The manual and the Garmin website are of limited help. I think I'm going to have to send it back, but if anyone has any information to the contrary, I'd appreciate the help.
doh.
2003 BMW K1200RS
http://www.MotoMarin.com
"This is the sort of pedantry up with which I will not put."
Winston Churchill
Guaglione is offline   Reply With Quote
Old 05-01-2005, 09:51 PM   #2
batfink
squid vicious
batfink's Avatar
Oddometer: 186
That sucks. I think someone else was complaining of the same problem recently. I have a 276c too. Have you tried taking the battery/memory card out and then after putting them back in try it again?
batfink is offline   Reply With Quote
Old 05-01-2005, 10:01 PM   #3
stevenknapp
stevenknapp's Avatar
Oddometer: 1,214
Send a message via Yahoo to stevenknapp
Yup. Take it all apart. No battery, no memory card.
Hook up the external power, it should power on.
Then put the battery back in.
stevenknapp is offline   Reply With Quote
Old 05-01-2005, 10:27 PM   #4
johnbo
Oddometer: 12
I had a GPS III+ that did the same thing to me. I found on the Garmin website, buried in some obscure corner of the website, that there is a small rechargable battery on the main board. This is supposed to allow you to change batteries without loosing all of the memory in the unit.
It said that if this battery is discharged, connect the unit to a external supply and allow it to sit for several days. I tried to hurry the process and rode with it the next day and had all sorts of really bizarre things happen to the unit. After about 3 days of riding, the problems stopped (the GPS was being powered by the bike during all of this).
The reason for the long time is likely that they've put a fairly large valued resistor in between the supply voltage and the rechargable to keep it from discharging the main batteries when idle.
Put everything back together, and let it sit for a couple of days. Resist the temptation to use during this time.
Good luck,
johnbo
John D. Bowne
Cornelius, Oregon
johnbo is offline   Reply With Quote
Old 05-01-2005, 11:09 PM   #5
Wings
highly unlikely
Wings's Avatar
Oddometer: 11,785
Mine died and wouldn't turn back on either, except it just died while it was in use. Tech support tried to talk me through turning it back on, zip, zilch, nada. I sent it back to Garmin. Their techs couldn't get it turned on again either. Didn't know what went wrong in it. Sent me a new one right quick and I'm back in business.
Advanced Dualsport Riding Techniques - The DVD
Jonah Street Dakar 2010
"And in the end, it's not the years in your life that count. It's the life in your years." --- Abraham Lincoln
Smugmug coupon code: CKZQ0vLPlmLFw
Wings is offline   Reply With Quote
Old 05-02-2005, 05:00 AM   #6
Taki
Waiting for Godot
Taki's Avatar
Oddometer: 901
Call tech support and see if the can help. If not send it in and Garmins excellent service will make it right. I had problems with my 276c and wasted two weeks trying to figure it out, finally sent it in and it was exchanged.
No matter where you go, there you are
Taki is offline   Reply With Quote
Old 05-02-2005, 08:33 AM   #7
Infracaninophile
Simplifying My Life
Infracaninophile's Avatar
Oddometer: 4,736
276c
Mine's back at Garmin right now. I really love Garmin products, but this 276C has been a piece of shit as far as reliability. It's the first unit that I've had that has a re-chargeable battery. All of my other units, including my favorite, the 176 Mono, had AA batteries. At least I could stop at the store and get fresh batteries if something happened.
My 276C has constant power/on-off issues. It was replaced completely almost a year ago by Garmin. Now it's back again.
My issues:
1. Even when plugged into 12V (car or bike) it would turn itself off at least 3-4X per day.
2. Sometimes the screen would go wacky and show blue and redding smears instead of a readable screen. No reason why.
3. On power up: After pressing the power button it would simply turn itself off about 50% of the time, or, it would sort of grow dim and then turn itself off later. Especially on the first cycle of the morning or when it was cold. Cold being defined as < 70F or so. Which is 90% of the mornings in Colorado.
Got my RMA from Garmin and included a note asking them to fix it RIGHT or throw the fucking thing away and give me my money back. 276C are NOT cheap devices.
Tom
My 1993 R100GS thread is Here
My 1981 R80 G/S thread is Here
Infracaninophile is offline   Reply With Quote
Old 05-02-2005, 11:34 AM   #8
Guaglione
Guaglione's Avatar
Oddometer: 2,217
Thumb Kudos to Garmin and Cycoactive
I called Cycoactive here in Seattle, and they called Garmin on my behalf. Garmin said they would have to look at it and that the wait was at least two weeks. Cycoactive knew I needed the unit for a trip I'm doing in a week and a half, and told Garmin as much. Garmin said give him a new one, and we'll replace the bad one.
wow.
2003 BMW K1200RS
Winston Churchill
vB code is On
Times are GMT -7.   It's 08:17 PM.
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ADVrider 2007
