Old 04-02-2013, 09:33 AM   #1
FiveG OP
Oddometer: 150
Slippery Dirt Riding for Pavement Riders and Bikes
My riding (at least at present) is predominantly on pavement, on pretty hefty bikes (FJR and a Monster 1100). I have recently found, however, that a portion of my rides are on a mile or so of dirt road. When dry, no problem. But, when wet, it's that lovely slime that only Vermont can do so well.
While I'm sure many will suggest I get a dirt bike or adventure bike, I'm interested in input from those who spend a lot of time on dirt as to how, a pavement-guy like me, should/can handle the slime. Easy on the throttle and little or no front brake seem to make sense.
BUT, in the event of a rear tire slide, what suggestions?
Even better -- what's the best technique to make turns in those conditions?
Thanks, from a dirt neophyte.
I hope you succeed, but no matter what happens, Godzilla will win.
"Steve Martin," Godzilla (1985)
FiveG is offline   Reply With Quote
Old 04-02-2013, 09:41 AM   #2
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,305
The biggest thing is to accept the fact that the bike is going to move around under you. The death grip is not your friend.
In the event of a rear tire slide, I don't back out of the throttle all the way. Instead, I use just enough to keep the tire spinning slightly faster than the bike is moving, because it seems easier to control when under power.
If you aren't in the market for a dirt bike, there are tires that can help make your street bike handle the dirt better. The Pirelli Scorpion Trail looks and acts like a sport bike tire, yet has slightly deeper tread and a tougher carcass. Still not great in the slime, but an improvement nonetheless. The TKC-80 now comes in sport bike sizes, and will handle that wet stuff like a champ, but will drastically reduce dry tarmac cornering.
I'm not great at cornering, so I'll let someone else answer that.
High Country Herb is offline   Reply With Quote
Old 04-02-2013, 10:28 AM   #3
hscrugby
"That guy"
hscrugby's Avatar
Oddometer: 4,099
No high speed cornering in dirt on a street bike.
Like he said, expect it to wiggle some, if you hit mud, more throttle.
in dirt the saying, "when in doubt, throttle out" is VERY true especially with slick tires.
I took my old CBR954 in a LOTTTTT of places it should have never gone. (Jeep trails, mt bike trails, muddy fire roads, etc) It almost always had the GPA's that were either track take offs, or track left overs on it.
PLAN on locking the back tire up, let it slide. So what? you're in dirt, not pavement, it's fun.
If it's a rough trail, plan on having to go slow cause the suspension is NOT right.
here are some examples of the wrong bike:
http://www.stbaldricks.org/participants/mypage/585928
Feel free to donate money either to my page, or their general fund.
hscrugby is offline   Reply With Quote
Old 04-02-2013, 02:32 PM   #4
randyo
randyo's Avatar
Oddometer: 1,776
remember that surface does not change the weight distribution on your bike, primary stopping power is still the front brake
learn to use it
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Old 04-02-2013, 08:56 PM   #5
BanjoBoy
BanjoBoy's Avatar
Oddometer: 878
Yeah, PRIIs do fine on the dirt, butt are a handful in da mud. Pirelli Scorpions are a little better.
learn to use it
first day ride'in or iz this a joke?
2007 FJR1300
2007 FZ6 (Dirt bike)
BanjoBoy is offline   Reply With Quote
Old 04-03-2013, 04:41 AM   #6
foxtrapper
Oddometer: 880
Stay vertical. Lean and it becomes much more likely the bike will squirt out sideways and go down.
It's very much like riding on snow or ice.
foxtrapper is offline   Reply With Quote
Old 04-03-2013, 10:05 AM   #7
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 2,360
Best advice is to buy a dirtbike to play on or take a dirt riding course of some sort. Too many people start riding late in life on pavement without the benefit of riding dirtbikes. If you can be comfortable when you get all crossed up in slick ruts on knobbies, the little moving around a street bike will do is trivial. If you can't find a course or similar, find a friend with a dirtbike and go ride deep sand all day. Nothing develops your sense of balance more than deep sand. And when your arms get tired of fighting the bike to stay upright, that's when you start to understand about gripping with your legs and holding on loosely with your hands. (and you start to go faster)
Regardless of whether it's a street or dirtbike, grip the tank with your knees when you feel it move. Your leg muscles are much stronger than your arms and by gripping your bike you are essentially making "one" with it. Bad things happen when you and the bike start going in opposite directions so you need to stay with the bike no matter what. Also, by adding your weight to the bike by gripping it, you slow down movements such as rear slides and absorb oscillations that could result in headshake. Do not grip the bars tightly, your hands are only there to use the controls basically, not steer the bike. (This is a generality but it's more true than most realize) If your bike starts to slide and you are trying to force it, you'll crash. A bike is self-correcting, let it self-correct.
Braking: Use both brakes when riding on slick surfaces. This is hard to test because most people don't like to drop their bikes on purpose but I have done it on dirt and the principles are the same as slick pavement. If you apply enough front brakes on sandy pavement to lock up the front tire, there is a good chance it will tuck under and you will go down. When you add rear brakes to the same amount of front brakes, the bike becomes more stable. Even though the front wheel may still lock up, you will have added reaction time to catch it and modulate to avoid sliding that front tire. No I don't understand the physics, I just know it works. Both brakes at all times.
If you panic brake and get the rear end sliding out, do not let that rear tire start to rotate again until it is swinging back behind you. It is much better to risk having a low-side from the rear sliding out completely than to have a high-side because the tire suddenly started turning again and regained traction. Low-side= scuffed bodywork or broken bike parts. High-side=separated shoulders and broken bones + scuffed bodywork and broken bike parts.
I have been riding dirtbikes since I was 6 and a lot of that knowledge has saved my hide on the streets. That's why a lot of streetbike racers ride/race dirtbikes also.
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK screwed with this post 04-03-2013 at 11:03 AM
GR0NK is offline   Reply With Quote
Old 04-03-2013, 05:36 PM   #8
dirty_t
dirty_t's Avatar
Oddometer: 153
You could always spend a couple bucks and take a class with these guys: http://americansupercamp.com/
I did and learned a lot, but I still suck at real powersliding - working on learning how to do it better. Their class does a great job of helping get the technique going, and learning what it feels like. Highly recommend.
dirty_t is offline   Reply With Quote
Old 04-03-2013, 05:55 PM   #9
NJ-Brett
Brett
Oddometer: 6,732
Slick mud on street tires with a heavy bike?
Plan on going down.
Ride gently, very gently...
Smooth hard dirt can be a blast tho..
NJ-Brett is online now   Reply With Quote
Times are GMT -7.   It's 08:09 AM.
