08-21-2006, 09:05 AM
#1 |
Oddometer: 2
Engine overheating slow moving
Hi, r1200gs 2006, 700km still running it in, my first BMW motorcycle.
Traveling home I got stuck in heavy traffic, the motor overheated and low oil pressure indicator. After leaving the motorway and picking up some speed again all return to normal. Now my question: is this normal for the GS to overheat when standing still or slow moving in heavy traffic, is this because of the air cooled motor? Thank, Andre |
08-21-2006, 09:22 AM
#2 | |
Earth Wanderer
Save $5 when you open a SmugMug account. Use the following coupon: 7ztkgApOHBurY
08-21-2006, 10:41 AM
#3 |
Oddometer: 228
I have never had my 1200GS overheat, even in standing Boston Traffic at 98 degrees (I overheated though!) I have also never had my oil warning light come on. Your bike is both air and oil cooled. These things consume vast quantities of oil when they're new. Make sure you check your oil level very frequently as you can't cool the engine oil if it doesn't have any. If it happened again, I would have the dealer make sure your oil cooler under the headlight is not blocked in any way.
05 1200GS with everything I can buy or build for it, ridden in places it was never meant to go! |
08-21-2006, 10:54 AM
#4 |
Old Guy nOOb
Oddometer: 2,686
I have had my R1200GS in stop and go traffic in over 100 degree temperatures and the temp guage never got higher than its normal (about 1/3 of the way up) reading.
It isn't the conditions its the decisions Don't bring a motorcycle to a car fight |
#5 | |
"Cool" Aid!
Oddometer: 41,488
Jim
08-21-2006, 10:55 AM
#6 |
The further the better!
Oddometer: 5,252
I'm not so sure if that is normal for the new 1200. Many have reported the 11xx's over heating but I have yet to read one report of a 1200 over heating. Myself personally I have ridden my bike through Kansas City in 110 degree heat. The traffic was stop and go for over 50 miles and it took 3 hours to cover that distance. My RID never even moved from the normal heat measurement.
Karl 2007 BMW R1200GS Adventure 2009 BMW G450x IBA 9231 http://karlmarsh.smugmug.com Smugmug rules! Use this coupon to get $5 off your own Smugmug account T3cUNv3ktrGFQ |
#7 |
Sure, why not?
Oddometer: 16,129
I have to agree with bobcopro on this one. It is NOT normal for a 1200GS to overheat. Even in the hottest weather and slowest traffic, I have never seen my temp guage go more than half way up. Get the bike to your dealer and have it checked out.
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
08-21-2006, 11:19 AM
#8 |
Earth Wanderer
I should have read his post better, but it was kind of hard since the lettering was in black. Since I have a 1150 GS I assumed he had one to.
(Being the better model and all that ).
08-21-2006, 11:26 AM
#9 |
Oddometer: 169
If it *ucks, flies, or floats...rent it! --my dad |
08-21-2006, 11:27 AM
#10 |
Oddometer: 178
I'll chime in and concur that this is not normal for an R1200GS. I really had to watch this with my old 1100's but my 1200 seems to run much cooler for some reason. I also found with my 1100's that any movement, even 5-10 MPH helped to avoid overheating.
09-26-2009, 09:02 PM
#11 |
overheating GS 1150
Lets hear some REAL answers from the "proffessionals" and save a bike and calm down a rider
06-20-2010, 07:07 AM
#12 |
Rehab is the new black
Oddometer: 46
I was stuck on I-80 (stop and go traffic for about 1/2 hour) in 80 degree heat and riding thru NYC in same temps. Temp indicator started climbing ('08 R12GS) but never got into the "red" (past the little hash mark near the top) - normally at 4 bars but went to 5 for much of the ride then up to 7 as I got lost in Manhattan. Crossing the the Brooklyn Bridge brought the temp down a bit. Does this sound normal? I usually ride where I am free of traffic and my commute is only 10 miles or so. Taking the bike on a long tour of EU - Am I just being paranoid or is my bike telling me something?
Thanks |
06-20-2010, 08:41 AM
#13 |
Oddometer: 595
I would think they have a thermostat in the oil system.
06-20-2010, 09:02 AM
#14 | |
Beemers Uber Alles
Oddometer: 603
. Looking further the oil cooler was dry also. As it turns out BMW did not drill an oil passage in the block for the oil to go to the cooler. Since the bike was still in warranty (35500 miles on it) we ordered a new short block. To check you thermostat get a digital laser temp probe and read the oil cooler lines when the bike hits "normal" operating temp the lines should begin to warm. If they stay only a few deg above ambient temp. you have found your problem. Hope this helps.
Beemers Uber Alles 9248 Mike Garcia Drive Manassas Va 20109 (571) 318 2472 Indie BMW Maintenance www.beemersuberalles.com |
06-20-2010, 02:24 PM
#15 | |
Tuscan rider
If should be hot as in "ooops". It will not be hot as in "funny smell - is that black thing my hand?". I don't know on the 12GS, but on the 1150 (best model and all that) the oil starts to flow at three or four bars. How hot the oil is? That is, in fact, a rather frequently asked question. And, luckily, you will find the answer in the "GSpot FAQ". [TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here. Renting out motorbikes in Toscana, Italy Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index. IBA: 33616 |
