Old 05-07-2012, 09:03 AM   #91
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 10,139
Send a message via Skype™ to enduro0125
Between Kevin and Jeff I had my own guided tour of Southern PA and a little bit of Maryland.
The fog was thick at elevation and messed up our vision a bit.
One of the only stops
Trying to catch the Aprillia
As Promised 12:00 finish for the 5 hour ride home.
Jean Bonnet
Stopped at the flight 93 memorial on the way home
Thanks to Jeff for organizing this,
Kevin for the company and all the PA guys for the great ride.
Nice to have met you all and look forward to doing it again.
AMA 487807A
enduro0125 screwed with this post 05-07-2012 at 09:12 AM
enduro0125 is offline   Reply With Quote
Old 05-07-2012, 09:04 AM   #92
Jeff B OP
Checks in the mail.
Jeff B's Avatar
Oddometer: 3,064
Originally Posted by eddie bolted View Post
was just out doin' maintance on the bike and noticed the clip on my masterlink is GONE! I dodged a bullet there,don't know when it came off!
Closed end of the clip needs to be facing the direction of foward rotation. Keep in mind on this pic, the chain is on the opposing side of your KLR.
Go ahead, pull my finger.
Jeff B is offline   Reply With Quote
Old 05-07-2012, 09:08 AM   #93
eddie bolted
Oddometer: 1,822
YEA,i had it on the right way!
If it stops raining now, i,ll be pissed!(BEANTOP)
eddie bolted is offline   Reply With Quote
Old 05-07-2012, 09:13 AM   #94
enduro0125
enduro0125's Avatar
Oddometer: 10,139
Where you using synthetic chain lube?
AMA 487807A
Old 05-07-2012, 09:13 AM   #95
Mark_O
Drain Bamaged
Mark_O's Avatar
Oddometer: 9,853
The last time I replaced my chain the clip was missing also. Every other time I've used a regular link. I have a master link for emergency use only from now on.
Sarcasm, just one more free service I provide.
Mark_O is offline   Reply With Quote
Old 05-07-2012, 09:25 AM   #96
eddie bolted
Oddometer: 1,822
No, Dupont multi purpose teflon spray. Why do you ask?
that's the first time EVER i lost one.
I have a spare one on now(saftey wired)
Jeff,what kind if silicone do you use on your clip(assuming the picture is your bike)
Old 05-07-2012, 09:29 AM   #97
Mark_O
Drain Bamaged
Mark_O's Avatar
Oddometer: 9,853
He uses a multi-purpose lube that's good on and off the bike.
Sometimes I just crack myself up.
Old 05-07-2012, 09:31 AM   #98
eddie bolted
Oddometer: 1,822
Old 05-07-2012, 09:51 AM   #99
enduro0125
enduro0125's Avatar
Oddometer: 10,139
Eddie,
Sometimes the chain guide wears the clip paper thin and then it falls off.
Check that first.
AMA 487807A
Old 05-07-2012, 10:08 AM   #100
Jeff B OP
Checks in the mail.
Jeff B's Avatar
Oddometer: 3,064
Not my bike in the pic.
Whatever silicone you have will work. It's how well it's cleaned/preped that matters.
Good call on the Teflon stuff. The thinner lubes are less likely to attract contaminates but don't last as long. So lube it often. Better for dirtier rides.
The heavier lubes and waxes are better for long cleaner street rides. They last longer.
Remember, it's impossible to overlubricate a chain.
Old 05-07-2012, 10:12 AM   #101
Jeff B OP
Checks in the mail.
Jeff B's Avatar
Oddometer: 3,064
Eddie,
Check that first.
Ding, Ding, there's your answer. And wasn't your guide or guard rubbing?
You said it was making noise.
Old 05-07-2012, 11:16 AM   #102
eddie bolted
Oddometer: 1,822
No it wasn;t that,that was the rubber guide that wraps around the swingarm by the front sprocket, i think Dan means the chain guide that hangs off the swingarm in front of the rear sprocket.Plus my clip wasn't rubbing on anythig when i checked it after breakfast that morning.
Old 05-07-2012, 03:12 PM   #103
rh2yadv
Ow!
rh2yadv's Avatar
Oddometer: 38
GPS data?
I wasn't able to go -- does anyone have a GPS track log from the trip they can post?
Russ
rh2yadv is online now   Reply With Quote
Old 05-07-2012, 04:23 PM   #104
Jeff B OP
Checks in the mail.
Jeff B's Avatar
Oddometer: 3,064
Russ
The tracks are on my Garmin Zumo, but I don't know how to post them.
Like this.......... http://www.youtube.com/watch?v=ZkwrIZQDt50
Old 05-07-2012, 04:40 PM   #105
Jeff B OP
Checks in the mail.
Jeff B's Avatar
Oddometer: 3,064
Originally Posted by Mark_O View Post
Meaning you had to wear the ball gag.........again?
Had to Google that one.
Times are GMT -7.   It's 11:41 PM.
